Old 09-23-2010, 12:14 PM   #1
Default cleaning pcv on b230ft?
So my pcv valve is clogged...how do I clean it out?
Old 09-23-2010, 03:29 PM   #2
242 glt
242 glt's Avatar
Blast it with carb cleaner, poke it with screwdriver, whatever you can to get all the stuff outta there and cleaned.
1984 242ti I has turbo again
1985 volvo 244dl
1989 volvo dl
1967 Plymouth GTX HT, 4spd, 360, 391 posi, daily driver.
1964 Plymouth Valiant 2d post, Welded frame conn, torque boxes, super slant 6 project, now daily driver.
242 glt is offline   Reply With Quote
Old 09-23-2010, 04:07 PM   #3
I would order the IPD relocation kit. It's such a pain in the ass to get to the stock setup. It's only like $15 and they give you a new flame trap and all the hoses and everything. I took off the intake manifold to get at it, because I was doing the coolant temp sensor under intake #3 and cleaning the leaking PCV box seal. If you can reach under there and pull the old one off, it's easy to put the IPD kit on. Actually, I had to use a little silicone lube to slide the top hose over the trap housing... that thing is really tight!
Old 09-23-2010, 04:19 PM   #4
is there a valve?
or just the box?
I cleaned from box the lil fitting with vac line and hose out...
I didnt clean box itself due to jiggle test passing! lol
do people add catch cans to these cars? the recirc to intake?
I have nissan turbo motors and we all run catch cans then back works great.
Carbomb is offline   Reply With Quote
Old 09-23-2010, 05:40 PM   #5
Oh yeah, I didn't use carb cleaner because it might ruin the plastic. I used degreaser, let it sit, do it twice or more, use a round poker brush thing, then maybe MAF or electronics cleaner that is plastic safe. Get a new seal too.
Old 09-23-2010, 05:53 PM   #6
smart dumbass
chriselalto's Avatar
hey im going to be working on my pcv system and already asked.
I got this link from someone and its a good detail.
1983 245 turbo my first volvo
Originally Posted by UTAHGTBRICK View Post
Tb solves more problems than a therapist.
chriselalto is offline   Reply With Quote
