Old 09-29-2010, 07:38 PM   #1
TheJeffers
Default Installing Ecodes on your 940 with foglights, step by step
Use this guide to install Ecodes on your 940 with foglights.
1. Who this guide is for
You will find this guide useful if you've got a set of Ecodes with fog lights that you just want to put into your car and get going. If you are going to run high-power bulbs with relays or some other non-standard setup, this guide is not for you.
2. What you will need
  • A 940 with fog lights integrated into the headlight assembly
  • A pair of Ecode assemblies with corner lights
  • Appropriate connectors (keep reading)
  • Basic soldering supplies (soldering iron/gun, heat-shrink tubing, electrical tape, rosin-core solder)
  • Wire strippers
  • 2x H4 bulbs (I used 55/60W ones from Susquehanna Motorsports)
  • 4x H3 bulbs for fog lights/driving lights
  • 1-2 hours of time
I found it very helpful to have an alldatadiy.com subscription for my car. It's only $20 and may prove worth it if you need to look at wiring diagrams, etc.
The proper connector for the Ecode housing is identical to the radio suppression/electric fan relay connector on 740s and 940s equipped with them. The easiest way to get them is to find a suitable car or two in the junkyard, remove the connector from the relay, and clip out the connector, leaving a generous pigtail.
3. Wiring
Before doing any work on your car, disconnect the negative battery terminal and place it in a Ziploc bag (or similar) so that it cannot ground out on anything in the engine bay.
Step 1: Remove the main headlight bulb and foglight bulb from their housings. Disconnect each bulb from its connector, and set them aside in case you need them again for whatever reason.
Step 2: The main 9003 bulb uses a large black plastic connector. To remove it, simply pull it away from the wire; it should snap off. Clip the foglight connector from the black-and-white and solid black wires leading to it. Remove the soft rubber boot from the headlight branch of the wiring harness.
Step 3: At the end of each wire for the headlight bulb, there will be connectors for the old 9003 style bulbs. Clip each one off its respective wire and discard.
Step 4: Remove the old headlights from the car. There should be five bolts/nuts: two in the fender, two inside the grille that hold an air guide on, and a nut connected to a stud on the core support. Be careful with the nut, as it may have rusted to the stud and will break it upon removal. To remove the corner light and gain access to the fender bolts, push in the white plastic retaining tab on the turn signal and pull the turn signal housing out. Remove the turn signal bulb socket from the housing if you haven't already.
Step 5: The wires for headlight power are as follows, relative to standing at the rear of the car and looking forward:
LEFT HIGH BEAMS: Blue/white
LEFT LOW BEAMS: Solid green
RIGHT HIGH BEAMS: Red/white
RIGHT LOW BEAMS: Green/white
GROUND (both sides): Solid black
Foglight power on both sides is black/white.
Pinout for the connector on the Ecode housing is as follows and is identical on both sides of the car. H = High beam power, L = Low beam, F = Fogs, G = Ground.
Using a wire stripper, remove a length of insulation from both the headlight wire you're attempting to splice and the wire leading to the corresponding pin on the connector. Use the "Butt Solder" technique as demonstrated here: http://www.mmxpress.com/technical/connections.htm, with the stipulation that you should place a length of heat-shrink tubing on one of the wires before soldering them together.
Perform this step for each wire to be spliced, until each connector has been spliced into the wiring harness. You may want to wrap the wires in electrical tape at this point.
Step 6: Install the H4 and H3 bulbs into your Ecode housings. Replace any protective covers removed in this process.
Step 7: Install the new Ecode housings and connect them using your newly spliced connector.
Step 8: Test high beams/driving lamps, low beams, and foglights. If they all come on as they should, you are finished.
Step 9: Reinstall your turn signal bulb into the top of the Ecode corner lamp housing.
That's it!
Wiring diagram, for reference:
Post if you have any suggestions/corrections.
TheJeffers is offline   Reply With Quote
Old 10-01-2010, 09:20 PM   #2
Volvolcano
Volvolcano's Avatar
Awesome, thanks, I've got a set of e-codes that I was procrastinating getting to, 'cause of the wiring.
'89 745t -- 306k, faded paint but solid
'91 940t -- world's best car until a tree took out the C pillar and rear glass... parts car now
'04 Prius -- (200k, salvage title) -- concession to $4.50/gallon
'97 Dodge Ram Van 2500 -- $400 hauler
Volvolcano is offline   Reply With Quote
Old 10-04-2010, 01:21 PM   #3
stylngle2003
stylngle2003's Avatar
those pics look familiar
nice writeup
-Billy
1990 Mazda Miata (track toy)
Old 10-04-2010, 08:36 PM   #4
davashcow
Got V8?
davashcow's Avatar
Thanks for the writeup!
davashcow is offline   Reply With Quote
Old 10-04-2010, 08:49 PM   #5
davashcow
Got V8?
davashcow's Avatar
Question...are the bulbs that you specify in your write-up the ones that actually come with used E-codes pulled from a typical junker in Europe?
Also, I've got some 960 relay connectors but a few of the wires look a little wimpy/skinny. Is there a way to release them from the square connector so I can use heavier gauge wire?
Old 10-05-2010, 06:43 AM   #6
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
OH man its so nice somebody made this.
I'll refer to this for tb'er who get e-codes from me if you dont mind.
Current:|760 Turbo *White-Rice* '86|Volvo 242 |Volvo 780 86|Porsche 986 02|
My Seller Feedback
Old 10-05-2010, 06:39 PM   #7
TheJeffers
nice writeup
Yeah, they were really helpful in getting mine on the car, but I couldn't remember who provided them in the first place. Thanks!
The wiring/plugs inside the Ecode housings is designed to use H4s and H3s, so yes, the lights I used are identical in form factor to what you would get from a Euro car. H4/H3 refers to a standard bulb type that is made by a number of manufacturers. You might be able to get H4s at your local AutoZone/Advance Auto Parts, but I don't recall them having H3s. I hope that answers your question.
I wouldn't worry about the wiring in the connectors-I just used what came with them. It's not like the headlight wiring is super-heavy in the first place. If you do want to try getting them open, there should be a hinged portion on the outside of each pair of wires that just pops open with a little force. Be careful that you don't break it, though.
Nope, that's why I made it. This info was never centralized before, now it is.
Old 01-13-2011, 07:18 PM   #8
WindowsBreakerG4
ALDORF THE DESTROYER OF WHITE SHIRTS
WindowsBreakerG4's Avatar
FCP says they only offer e-code corners that fit non fog cars, anyone know the difference? Or if it's just FCP being silly?
ovlover: Its an auto. Problem found, Manual swap. Problem solved
Originally Posted by cosbySweater View Post
She was pretty damn hot. And she folded my clothes and made me breakfast in bed
Towery wants to get me drunk but doug already is. Don't trust a drunk Towery he will slip you the old stiff one eye
I AM ALDORF THE DESTROYER
1985 744ti M46 -3rd, 15g, 3" exhaust, Ported Head, 333,333 miles
91 945 Turbo 3 pedal auto, DD
83 242 Turbo Flathood
15 Golf TDI 6 Speed
Doug <3 me. Not scottyd. doug was here again
WindowsBreakerG4 is offline   Reply With Quote
Old 01-13-2011, 08:11 PM   #9
davashcow
Got V8?
davashcow's Avatar
I believe they're talking about the newer 740's and 940's that don't have the fogs next to the headlights. I had such a 740 and converted it to e-codes by grabbing some 940 head and fog lights and all the hardware and brackets that held them in. Then the e-codes swapped right in...not sure about the older gen 740's like you have in your sig.
Old 01-13-2011, 08:29 PM   #10
WindowsBreakerG4
Oh I am buying a 940, it has ecodes (with fogs) but 1 of the corners is broken so I am trying to figure out what the difference is. Also I found they do offer both corners so I guess it's not an issue but I am still kinda curious
Old 01-13-2011, 08:37 PM   #11
davashcow
Got V8?
davashcow's Avatar
yeah the non fog cars have several different brackets and fasteners between the grill and lights. Easily swapped stuff that shouldn't prevent any 740 owner who wants e-codes from doing the conversion.
Old 01-13-2011, 08:47 PM   #12
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
Id be interested in a source too....but I have read that non ecode fog markers can be made to work.
962j 815/692@27psi
THIS IS FORSALE V
Old 01-13-2011, 08:55 PM   #13
davashcow
Got V8?
davashcow's Avatar
I missed the bit about the corners...yep they're different...mainly cause the e-codes have a housing that accounts for the corner lamp with two lamps. I've never tried to modify a stock 940 side marker.
Old 01-14-2011, 12:31 PM   #14
Natural244
F1 Junkie!
Does anyone know the part # of those relay connectors or the name of them? Trying to find a source for the other than the JY.
Thanks - Tim
Natural244 is offline   Reply With Quote
Old 01-14-2011, 12:51 PM   #15
davashcow
Got V8?
davashcow's Avatar
They're really part of the wiring harness, so the jy is the way to go. Easy to find and probably free from LKQ, with your $2 admission fee.
Old 01-14-2011, 12:53 PM   #16
davashcow
Got V8?
davashcow's Avatar
Grab twice as many as you need, and you can disassemble them and use the heavier-gauge wires.
Old 01-14-2011, 02:48 PM   #17
EvanSargent
Board Saint
EvanSargent's Avatar
Thanks - Tim
http://www.volvopartswebstore.com/pr...9/1259830.html
Note. It says the windshield wiper uses the same connector.
EvanSargent is offline   Reply With Quote
Old 01-14-2011, 05:09 PM   #18
BrianB
BrianB's Avatar
On this topic, I noticed that the headlamps on my 940 are connected through a factory relay block immediately forward of the battery.
I'm really curious about this.
Brian Bradford
Tri-Cities, WA
Present Cars:
A 1997 Volvo 965
"Dan'l Webster"
BrianB is offline   Reply With Quote
Old 01-14-2011, 05:32 PM   #19
Natural244
F1 Junkie!
Thanks, that is very handy!
-Tim
Old 01-16-2011, 07:13 PM   #20
EvanSargent
Board Saint
You're probably seeing the relay for the elec. fan
Old 01-17-2011, 06:52 PM   #21
davashcow
Got V8?
davashcow's Avatar
-Tim
+1
Very cool diagram.
Old 01-18-2011, 03:20 AM   #22
jerryc
jerryc's Avatar
The foglight type headlight, which the ecode FCP sells replaces, has a different angle than the non-fog, so the turns are different in at least that way. I have some and while I haven't spent any time on it, I don't see an easy way to make the stock turn fit the ecode light bracket.
Also, the e-code turn has two sockets, one clear and one amber. No one has come up with a good way to make them both work correctly AFAIK, only to put the one, two filament bulb in one of the sockets and leave the other blank. I have not put mine in yet because I want to do it that way, and make the bulb out light not come on.
What's the female equivalent to a dick pic? twat shot?
There isn't one because dudes aren't grossed out by unsolicited vaginas.
jerryc is offline   Reply With Quote
Old 01-19-2011, 09:16 PM   #23
ryank
ryank's Avatar
I'm going to be installing a set soon, converting my 94 non-fog 940 to e-codes with fogs. My understanding about the corner lights is that a single filament bulb goes into the top and bottom holes. The clear takes a 5w bulb that comes on with the signal from the parking lights (city lights in Europe), and the amber section takes a 21w bulb that is only activated as a turn signal.
'94 945T | '70 Alfa GTV 1750 | Ducati M800S | feedback
ryank is offline   Reply With Quote
Old 01-19-2011, 10:58 PM   #24
jerryc
jerryc's Avatar
Well you have clearly spelled out what I sort of came to, so thanks! But, I have not discovered if there are bulbs in that wattage with the correct offset pins for the sockets. Do you know?
Old 01-20-2011, 03:21 AM   #25
EvanSargent
Board Saint
If the lamps are anything like the ones in earlier Ecodes, yes there will be options with the correct offset pins. Up until recently, they actually stamped the info on the base of the lamp. It was very helpful when trying to find the correct lamps for my early ecodes
