Chubfest 2009 Survivor
![]() Join Date: Nov 2002
Well put a new master cylinder on and pulled the rear reduction valves off.
All I can say is... you'll need 5pt belts now Let me put it this way, theres a strip of road by my shop where I ussualy can go from 5-120 and then JAM on the brakes to get it slowed in time. First time, I stopped COMPLETELY, probably a 100' short. Second time, still about 50' short third time I about shate myself from diving into it so deep and I STILL coulda waited longer. Its insane. Gotta box those a-arms now Doug
off |
nice
2006 VW Passat 2.0t 6 Speed - Current 2005 Dodge Magnum R/T - Sold 2005 Dodge Ram 2500 - Sold 1998 Dodge Ram 1500 - Sold 1990 Volvo 760 Turbo - Sold |
any more details on the install, i would love to hear some details, this sounds like it is a worthy upgrade...did you need to modify anything significantly to make them fit right?
1989 740 turbo... k and n ram air, tdo515g at 15psi, homemade mbc, 3 inch exhaust( 3 inch high flow cat, with side exit right in front of the right rear, no mufflers, nothing but flow) |
#4 |
Im going to say you'll have to do a search.
#5 |
thought so, you are based out of sacramento right?
i am right down the street... |
#6 | |
#7 | |
Bored Member
Let me know if you happen to locate any aftermarket pads for that "R" caliper. I have the EBC Greens on mine, but it would be nice to have a couple other options beside stock pads, like maybe some Mintex or PBR. Dave B.
'84 242ti, daily driver, B21FT, SDS EFI/IGN, 15G, M46, G80, Unitek&ST Phase One cam. '84 245ti, 2.6 stroker, T5, currently hibernating. SoCal VCOA Homepage Dave's personal homepage Dave's Used Volvo Parts |
#8 |
SWEET!!!! As soon as I find that 75, it's on.
Hey Doug or Dave, could one of you post a picture looking in straight at the brakes through the wheels... do they fill them completely? nick
'98 V70R 5spd, '68 140S, 780 BERTONE lemons race car. |
#9 | |
Bored Member
Dave B. |
#10 |
![]() on your peggies Nick ;) Dave, if it is indeed the same caliper (well will atleast accept the same pads) there are tons of choices. SCC magazine had a big article about EVO/STI brake setups (the OEM discs look identical inside as well too) ... I believe they had absolutely rave reviews on Feredo's (sp?) I'll dig it up |
#11 |
TheSlovo
![]() Join Date: Dec 2003
thats just awesome, doug and dave! im glad to hear the test feedback... thats what i was waiting for... sounds good. are the brakes starting to overpower the tires at all? and everything is smooth not grabby? sounds good! later,
ben |
#12 |
please tell me you took pics for a article, pppppppppppllllllllllleeeeeeeeeeeeeaaaaaaaaaasssss sssseeeeeeeeee!!!!!!!!!!!!!!!!
my cars (click me) I'm not here, Please leave a message after the tone........(or email me). |
#13 | |
Aaron, I did take plenty. Its really straight forward, you could probably knock it out in about 4 hours. I got crazy and involved, but I always do |
#14 |
thanks guys! great pics.
nice wheels doug ;) nico |
#15 |
doug are those 18" pegasus or the 17s? it looks like it says 17 on the sidewall but its hard to tell with the bottle of tire shine you used ;)
_____________________________ 1991 780T... 0-60 curvy roads COMING SOON: 19T, proturbo header, 16v head, stroker crank, redesigned 3" exhaust1988 240.... 0-60 curvy roads ![]() daily driver TOTALED anybody selling a sweet car? Last edited by gecko; 07-29-2004 at 02:39 AM.. |
#16 |
The Sirius/Nova Police
Mike 1998 V40 2.0T CD |
#17 | |
is that something that doug photoshopped or did he change rims again? |
#18 | |
Yes, I CHANGED wheels AGAIN |
#19 | |
only if these brake's fit inder 16's... (sigh)
-Elliot -adrian Really needs a turbo, now that he's megasquirting... Quote:
#20 | |
#21 | |
Bored Member
Exact dimensions are difficult, but essentially I think you need about 1 inch clearance between the original brakes and wheels in order to clear these brakes since the R brakes will be more outboard (unless of course you go with custom hats and redesign the brackets). Polaris are very tight to the original brakes, so they will not work without adding spacers. Most shallow dish front drive type wheels will work, such as those Doug put on (with spacers of course). So it means your wheel choices will be limited with this setup. Dave B. |
#22 |
the calipers do NOT stick out past the hub + 25mm spacers. Your milage may vary.
I measured them roughly (forgot the exact measurements) but it looks like Titans would clear,they have a pretty flat inside detail to the rim. |
#23 |
You guys haven't been bending control arms?
With big brakes I bent control arms such that the tires rubbed the inner fender the first time I applied them hard. DO box your control arms. One flat plate across the bottom is enough. Good for you Doug!! JL.
Overkill is consistently more fun. Impossible numbers guy!! |
#24 |
thanks doug and dave, that's exactly what i figured......hmmmm guess its time to go pick up some of those c70 5 spokes
#25 |
No Logo
I may be getting the "do a search" reply here, but is this only workable on the 200s? Any idea of 700 application? Or am I gonna have to get 200 series spindles?
| Thread Tools | |
| Display Modes | |
