Old 11-29-2010, 02:14 PM   #1
BDKR
Section 9
BDKR's Avatar
Default Holset hotside question
Holset noob here with a question.
Do the 9 cm and 12 cm hot side housings use the same turbine wheel?
For all you Dijkstra fanboys:
Old 11-29-2010, 02:18 PM   #2
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
Is your actual question "Do the HX35 and HY35 turbine housings interchange?" If so, then no. Otherwise, I've never seen a 12cm housing for an HY or a 9cm housing for an HX.... so I'm not sure what you're planning here... but an he351 with a 12cm twinscroll HX35 turbine housing would be a sick turbo.... but I think it's a lot of work to swap.
-Kenny
Old 11-29-2010, 02:33 PM   #3
BDKR
Section 9
BDKR's Avatar
Too much of a Holset noob to know Capt.
That said, it sounds like the right question.
I'm not really planning as much as I'm just looking at options at this point in time.
Thanx!
Old 11-29-2010, 02:56 PM   #4
Captain Bondo
Thanx!
Yeah it's a bummer. The HE351's got a very nice compressor wheel with a 60mm inducer but are somewhat choked by the hotside. A 12cm or even 14cm twin scroll housing on one of those turbos would be a potent combo.
Old 11-29-2010, 03:45 PM   #5
MrBill
fige=500Dollar Mistake
MrBill's Avatar
On a stock motor I couldn't imagine having a 12cm housing unless it was an automatic that was sprayed out of the hole and intended to be drag raced. Maybe with something that reved to 8000rpm, something with more displacement or really tight gearing.
I have an he351 and it's great. I would not autocross with it. I have 3.91 gears and with the v6 t5, 2nd gear is too tall for the turbo at an autox. I'm still going to do it, but I expect mediocre results.
It made reasonable power with the 1990 b230f, k-cam, MS2, etc.
Someone say crazy rays?
Old 11-29-2010, 04:07 PM   #6
Captain Bondo
The assumption on my part is that the twinscroll aspect of the housing would be utilized via a pulse paired header. At that point it should spool pretty well, IMO... you'd be talking about a turbo capable of close to 500whp at that point, so everything is relative. Admittedly, it'd probably be a bit of a dog with an undivided manifold though.
Old 11-29-2010, 04:57 PM   #7
BDKR
Section 9
BDKR's Avatar
So hot side HX35 housings are twin scroll?
Sending PM.
Old 11-29-2010, 05:00 PM   #8
BDKR
Section 9
BDKR's Avatar
So let me ask another question. What would the 9 cm and 12 cm housings be equivalent to in Garrett-landia?
Old 11-29-2010, 06:30 PM   #9
dhallilama
dhallilama's Avatar
9cm2 = 0.65 A/R
12cm2 = 0.89 A/R
in intarweb folklore, anyway... but I reckon it to be pretty damn close.
-'72 volvo 142e b20, holset, ms, etc.
- III -
dhallilama is offline   Reply With Quote
Old 11-30-2010, 09:43 AM   #10
BDKR
Section 9
BDKR's Avatar
Originally Posted by dhallilama View Post
9cm2 = 0.65 A/R
12cm2 = 0.89 A/R
Thanx!
