![]() Join Date: Jul 2009
MOD LIST:
ENGINE: 1982 B21ft shortblock, 7.5:1 compression Unitek stage 4 head and cam with massive valves major chamber and port work Stock 8v N/A exhaust manifold with Up pipe twinscroll GT35 3 inch turbo back no mufflers 2x 40mm V-band external wastegates big ebay IC 3 inch intercooler piping MS2 V3.0 Wasted spark Oil filter relocation kit and RX7 oil cooler wastegate set at 20PSI mBENZ v8 kjet pump under car and whinebro 255 in tank both with upgraded wiring SUSPENSION/DRIVELINE: Shortened coilovers up front 250lbx10inch springs saab bilstiens -1 degree camber up front trunk mounted electric power steering wagon springs 1.5 coils cut chevy s10 4X4 shocks Aw71 with big external cooler and accumulator mod 3.73 gearing 18x9 OZ ultraleggeras with 245/40/18r bridgestone potenzas 30mm spacers up front 37mm out back Mazda RX7 brake kit 25mm bar up front and stock 240 bar in the back Stock torquerods with poly bushings adjustable panhard bar INTERIOR: Momo steering wheel 3 pod gauges, oil temp/ pressure and voltage from a audi 5000 aem wideband vdo boost gauge 30psi all black leather panels black fabric rear seat 1989 honda prelude si seats up front ms box in the glovebox cheapo laptop for ms in there too COSMETIC: Fully Tucked and painted engine bay Ecodes 92+ black door handles 92+ Black trim perfect front bumpercover and airdam broken rear taillights LOL mismatched hood and passenger fender :( relocated hood release SE side markers So this whole build started out with me needing another car for my girlfriend, i had just bought a v70 xc that was in extremely good shape. Obviously i was going to buy her a Volvo 240. I stumbled across this diamond in the rough. ![]() Well i got it for the total cost of 643 dollars with new plates and everything. and she drove it in the hot Sacramento sun for 3 weeks before she wanted out of it. No AC is unacceptable for a girl these days! So i gave her my v70 i hated that car, abs modules going out, blew the head gasket, just alot of work. so i started getting into the 240, i couldnt contain myself. ![]() I had the pegasus from my old 245, they looked great on the white sedan! ![]() ![]() ![]() First off i swapped in a Electric fan, IPD sways, Adjustable torque rods/Panhard rod. Gt upper strut plates, diesel front springs wagon rear springs. bilstien touring shocks up front. Heavy dutys in the rear. ![]() ![]() Then i got a engine, tranny, turbo, a crap load of steel braided lines, Full LH2.4 harness and chippable computers. ![]() ![]() ![]() So as the car sits right now it has a Super lowmileage 1993 AW71 and B230FT, it has a chinabay .50/.63 turbo with a stock garrett wastegate (that isnt working worth a damn right now for some reason) it has the full LH2.4 harness swap in it, 850 t-5 injectors, Homebrew 3.5 inch downpipe with a shortened wastegate arm so it opens extremely fast. it has a relocated filter, am using the 93+ water cooled oil cooler, and going to also run a air cooler too. ![]() ![]() ![]() Now with 91+ power steering ![]() ![]() Interior work is becoming a huge focus as when this car is finished it will be my daily driver. Old ![]() New ![]() as it sits now, its running i am still working out bugs. got the pegs on my 944, now im looking for some tethys. Going to post pics of the actual swap in a little bit. ![]() Here they are! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() the big guy in the pictures mainly operated the hoist. it was a real struggle to work with someone who has never touched a car before.
1988 Volvo 244, B21ft, unitek stage 4 531 head and cam, ms2v3.0, "gt35" Aw71 http://forums.turbobricks.com/showthread.php?t=223946 Last edited by cosbySweater; 04-02-2013 at 01:11 PM.. |
Emerged as Ugly Butterfly
I thought you already had a build thread for this car!
? http://forums.turbobricks.com/showthread.php?t=212560
'97 GMC K2500 Suburban 6.5TD - FailBus
'84 245GLT - FailWagon '92 245DL - The iFixit.com Lemons Car '95 850T5R - ButterCup Cheap 2/7/9 Camber Plates! Now w/Weld-In Steel! BrickSpeed - For Making your car fast. Not low. |
Yea I'm gonna close that one cause its in the showroom. This car is a ongoing project.
#4 |
Well looks like the car is getting a t5 a lot sooner then I thought. Just blew up the aw71L. :(
#5 |
well heres some stuff i did while waiting for the transmission, getting another aw71 as a temp.
![]() added pins #10/11 for the efan (no more crappy saab sensor) ![]() hanging low magnaflow need to cut the tip off ![]() 3 1/2 inch to 3 downpipe ![]() relocated battery and coil for future super secret mods ![]() going to cut out and power wash this part ![]() dodge intrepid remote terminal. i like it! ![]() |
#6 |
Shaved some unecessary weight, and put on the Bilstien HD's off of a blazer, WOW what a difference when the car is jacked up the springs dont fall out of the perches!
#7 |
Newest mods:
3 inch intake 012 amm TLAO Ezk/Ecu chips 20psi 55lb delphis ebay intercooler new 32mm/25mm spacers and more to come!!!! |
#8 |
Update!!!
So here is how the car sits now. POWERTRAIN: 1993 b230ft LH 2.4 SWAP 20PSI MSD 6al Ipd cam 3 inch intake 012 maf 50lb msd injectors (by delphi) Full 2.5 in inter cooler piping Big tank ebay ic Rx7 oil cooler .50/.63 chinabay turbo Forge recirc valve bpr7es Tlao chips 939 box and gold ecu 3.5 to 3 inch downpipe Oil filter relocation kit Single v belt setup Jank waterbottle catchcan STEERING/SUSPENSION mono wheel Ipd 28/25 bars My own panhard rod and torque rods Firewall braces Gt plates diesel springs front wagon springs rear Full bilstien hds Electric power steering Authentic polaris wheels brembo rotors Still have the aw71 and am working.on getting a flywheel lightened/resurfaced ![]() ![]() ![]() ![]() |
#9 |
looking very good bro
Brandon B. DD-1993 240+T ms2v3, 96#s, e85, T5, plus a few other things ![]() Currently at 315whp/294tq and ran out of pump at 6500 Build Threadhttp://forums.turbobricks.com/showthread.php?t=264885 Feedback Threadhttp://forums.turbobricks.com/showthread.php?t=249057 |
#10 |
Its coming together really well. I am very happy with it. I am going to be ordering injectors for it soon for my e85 swap
#11 |
Baseline dyno results at the end of the day
#12 |
![]() E85 bitches! |
#13 |
stupid question, but we dont have much E85 here, What is the perk to E85?
89 244 lowered on black painted steelies, all black cloth interior, Dave's white gauge faces, Full turbo gauge cluster, M46, 1992 940 B230FT swap, Electric fan conversion Pioneer CD/MP3 stereo |
#14 |
More power if tuned for it, cooler running and cheaper. Plus it smells like corn!
#15 |
Moard Bember
100-112 octane rating equivalent, cheaper.
850 GLT RIP Lead Sled 98R AWD When I'm working on a problem, I never think about beauty. I think only how to solve the problem. But when I have finished, if the solution is not beautiful, I know it is wrong. - R. Buckminster Fuller |
#16 |
The car runs great on e85. All that has been done is. TLAO ECU/EZK chips. 75lb injectors and yea.... lol it smells awesome! I will post 5gas and dyno results in the coming week
#17 |
#18 |
![]() Emissions delete |
#19 |
![]() This pull was. Spike at 15psi dropped to about 13ish with a plugged up stock cat converter. And a leaking divertervalve and aw71. Pretty darn good if you can't read it it's 209whp and 235torque |
#20 |
Noice work
'things which matter most must never be at the mercy of things that matter least' - goethe
Tiga's Garage : White 1988 245 (autoshizen) "The Volvonator" : White 1988 M47 245 "The Goon" : White 1972 M45 142 "Princess" : White 1985 245 M46 "Cowabunga" Mobile |
#21 |
†500DollarSparkMap
![]() Join Date: Jan 2009
fix all that, then get back on it again.
Matthew 10:28 And fear not them which kill the body, but are not able to kill the soul: but rather fear him which is able to destroy both soul and body in hell. ![]() |
#22 |
Well here's a list of parts coming in the mail for it.
Header 38mm tial Just got my ssqv today. And I am getting a intake manifold made as we speak for it Also I have a full 3 inch exhaust that goes all the way out the back strait piped that is gonna sound meannnn. |
#23 |
Cat removed and 20psi!
#24 |
Chinese guy/Swedish rides
Looking great! Those are the wheels that you're selling, eh? Too bad I don't have the cash for them now.
'90 Volvo 744T: It's beige. | '77 244DL: Was red. Now sold. | '82 242GLT: It's silver. My Feedback mtd240: I suspect "the wives" have a super-secret forum to discuss whether or not they will let us buy Volvo parts. DavidSamuels: Not a website, a panel discussion/reality show. Real Housewives of Gothenburg. |
#25 |
Yep that's them.
Forgot to update. Best dyno results I got was 269whp and 289 torque! That was before this happened ![]() ![]() Still have to throw the custom intake manifold on. I am shooting for 300whp before 2012 and I'm getting.g very very close |
| Thread Tools | |
| Display Modes | |
