Old 12-21-2010, 03:33 AM   #1
gross polluter
They see me trollin'
gross polluter's Avatar
Default The official DSM CAS information and install guide
Old 12-21-2010, 03:33 AM   #2
gross polluter
Old 12-21-2010, 03:34 AM   #3
gross polluter
Old 12-21-2010, 03:35 AM   #4
gross polluter
Old 12-21-2010, 05:33 PM   #5
gross polluter
Old 12-21-2010, 05:48 PM   #6
doucheNozzle
doucheNozzle's Avatar
This is good so far. Thanks for the write up.
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
doucheNozzle is online now   Reply With Quote
Old 12-21-2010, 09:44 PM   #7
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
I second this motion.
Old 12-22-2010, 03:04 AM   #8
WindowsBreakerG4
ALDORF THE DESTROYER OF WHITE SHIRTS
WindowsBreakerG4's Avatar
Thirded and 1 question, what size bolts are they held in with so i only have to bring 1 wrench to the yard lol
Thanks for listing the cars. That'll make my life tons easier
ovlover: Its an auto. Problem found, Manual swap. Problem solved
Originally Posted by cosbySweater View Post
She was pretty damn hot. And she folded my clothes and made me breakfast in bed
Towery wants to get me drunk but doug already is. Don't trust a drunk Towery he will slip you the old stiff one eye
I AM ALDORF THE DESTROYER
1985 744ti M46 -3rd, 15g, 3" exhaust, Ported Head, 333,333 miles
91 945 Turbo 3 pedal auto, DD
83 242 Turbo Flathood
15 Golf TDI 6 Speed
Doug <3 me. Not scottyd. doug was here again
WindowsBreakerG4 is offline   Reply With Quote
Old 12-22-2010, 03:20 AM   #9
gross polluter
A 12mm wrench will remove the CAS bolts.
Old 12-24-2010, 10:59 AM   #10
varg
kludgemeister
varg's Avatar
I just grabbed one off a 6cyl DSM at the junkyard (all the 4 cylinder cars were stripped), the sensor has the same numbers on it as the one pictured. Just wanted to put it out there.
'85 244DL B21FT swap (gone ), ->Project thread
'91 E30 318is, M20 swapped, turbocharged. project in progress.
Kawasaki ZRX1200R
varg is offline   Reply With Quote
Old 12-24-2010, 01:46 PM   #11
gross polluter
No such thing as a 6 cylinder DSM. A 6 cylinder Mitsubishi CAS look like this:
None of the 6cyl Mitsubishi's used a CAS identical to the four cylinder cars. Mounting is much different as well. These sensors are not a direct replacement for what's documented in this thread.
Old 12-24-2010, 03:22 PM   #12
varg
kludgemeister
varg's Avatar
It sure looked like a DSM but I'm no rice expert. I can't see the one you posted but it looks nearly identical to the one in the first post and has "T1T49371 R" and "OY24" on it.
(edit)
Old 12-25-2010, 05:59 AM   #13
sdturbo
sdturbo's Avatar
Just from that picture I can see that the mounting is different and that the body dia is bigger and longer. Better pay more attention to your "rice". DSMs are built in Normal, IL BTW.
Josh
92 245 (TDI diesel powered.)
84 242 (16vT beater/track slut)397whp/11.6@118mph Sold
97 Land Rover Discovery (Mercedes om606 swap)
65 Mini Cooper (B18 powered)
www.yoshifab.com Volvo performance parts.
(760)468-7002
sdturbo is offline   Reply With Quote
Old 12-25-2010, 10:57 AM   #14
varg
kludgemeister
varg's Avatar
Oh well, I guess I'll sell it on ebay and try to find a 4cyl that hasn't been stripped. The CAS I have came off a 3000GT, which I thought was a DSM but apparently it isn't. I knew DSMs were American built, BTW. I call them rice because most of them are riced around here, including the ones I see in the junkyard. Very rarely do I see a DSM that is actually fast.
Old 01-14-2011, 10:39 PM   #15
Rustee
Rustee's Avatar
Any updates on this Nick?
90 240 B230 16v+T
Rustee is offline   Reply With Quote
Old 01-15-2011, 01:24 AM   #16
gross polluter
The final part, ecu configuration, will be done very soon. It's a difficult section to write since there's a plethora of different MS setups out there. I'm trying to keep the documentation as specific as possible to try and cover everything without writing a novel.
I'll have it up by the end of the weekend.
Old 01-15-2011, 11:30 AM   #17
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
actually the sensor part of it is, the shell and the mechanical means to make it work, however, are not.
that's really just a longwinded way to say "hang on to it" since the senor part of it will interchange.
yep. I thought I posted about that elsewhere? I grabbed a v6 cas so I'd have a spare pickup setup.
Megasquirt Tuning!
Old 01-15-2011, 12:52 PM   #18
gross polluter
I know that. For all intents and purposes of this manual, and to try and reach an audience with a broad range of mechanical aptitudes, I'd like to keep it focused on what works with Josh's adapter.
Old 01-26-2011, 08:31 PM   #19
DNAsEqUeNcE
†John3:16
While poking around at the shop today, I noticed that the earlier miatas with no head mounted ignition coil pack indeed have a DSM cas.
The unit was out sitting on the bench, and it had a mitsubishi insignia on it. I was not allowed to open the unit to my dismay and inspect to see if it was indeed optical or magnetic.
Old 01-26-2011, 09:02 PM   #20
sdturbo
sdturbo's Avatar
Again, the internals are going to be the same. Same disk, same sensor different housing and different mounts.
Old 01-26-2011, 09:16 PM   #21
DNAsEqUeNcE
†John3:16
derp :(
Old 01-26-2011, 09:34 PM   #22
gross polluter
What's next, people coming on and telling us that SR20's have DSM CAS' too? Just because it has a Mitsubishi logo does not mean it is for sure a DSM CAS.
Old 01-28-2011, 07:07 PM   #23
wennstroma
Before installing the hires trigger disc you will need to verify orientation. Lay the disc flat on a table with the key of the disc facing up. The cam sensor window should be to the left of the key as shown in the picture below:
I haven't looked into how the second trigger works yet, so this may be a dumb question, but the position of the inner window on the wheel I got is slightly different than the one pictured above. Will this affect the settings?
Mine has "MANDO" written on all the parts instead of the Mitsubishi logo.
wennstroma is offline   Reply With Quote
Old 01-28-2011, 07:52 PM   #24
gross polluter
No. MS simply looks at where the cam tooth is and considers the next crank tooth "tooth 1." The position of the crank teeth have not changed therefore timing will not be affected.
Old 02-03-2011, 02:14 PM   #25
Rustee
Rustee's Avatar
Got my CAS, adapter and hi res disc, just need to finish setting up MS. Eagerly awaiting the final part to this, so i'll just keep buggin ya
