- Dec 3, 2010
- Iowa City
I have a 57 trim turbo on an LH 2.4 940 turbo.
I am running stock fuel pumps and injectors, stock base timing, straight exhaust.
New fuel filter
NGK BPR8ES plugs gapped at .022"
Known good 3 bar FPR
At any boost, when I tip into boost, the car goes lean, and gets to about 15:1 or leaner, then dithers back and forth a couple times to 12, 14, 13, then finally to the 11-12's where I want it to be in boost. After the initial lean spike is gone, and it is fattened up, it stays fat until I release the throttle, even after a couple of gear changes.
Predictably, the car pings badly, and I can feel a very large decrease in power.
My old LH 2.4 car did none of this, even with the lift pump on its way out.
I even tried my set of brown tops, and it does the same thing just as bad.
Any insight?
New fuel filter
Any insight?
