Old 12-31-2010, 02:20 PM   #1
Dakar09
The Blue Baastard
Dakar09's Avatar
Default Blue Bastahrd - Targa Newfoundland Entry
Hey guys,
I've been bouncing around the forums for the last few months, accumulating know-how and parts for this project. I'm ready to start the work now, so I figured it was a good time to start a thread.
We raced an e39 M5 in the 2010 Targa Newfoundland this past Sept., but we only entered the Grand Touring class with that car. I didn't want to put a roll cage in that car, so we "took it easy", per say. This is a link to the actual event:
http://www.targanewfoundland.com/
Now I'm ready to haul arse in next year's event. The entire trip home (1 1/2 days), I was putting this project together on paper and in my head. I originally wanted to build a 122, but put the lid on that pretty quick. So, I came up with this idea:
This is the Blue Bast**d. A 1983 245 Turbo. picked up from a fella in NJ in Sept. for $500, paid $200 to have it shipped to me in MA.
Stock K-jet with floor board rust - will have the cage fabricators patch this up in January 2011.
No reverse lights but working OD - rewired the light and OD circuits - but the wires keep coming off of the reverse switch. But, I know a guy that will pass it for me , and will do a permanent fix when the T5 goes in.
Biggest issue was leaky vac lines - all taken care of.
It runs great now after bringing it near Stage 0. Haven't done the PVC system yet, as I didn't want to remove the intake manifold.
It's already gutted, aside from the two front seats, as I still need to get it inspected. Then I'm putting in 2 Corbeau seats and taking it to the fabricators for the cage and floor repair. I want to make sure I can build on this car before putting all the work into it.
Tony
1958 Volvo PV444
1983 245 Turbo - The Project - Targa Newfoundland entry - Sold
http://forums.turbobricks.com/showthread.php?t=225396
2002 BMW M5 - Sold
2011 F150 FX4 Screw with Ecoboost V6
Past bricks - '95 855 manual, '98 V70 T5 Manual, '04 V70R 6-speed, '10 XC60 T6
Dakar09 is offline   Reply With Quote
Old 12-31-2010, 02:42 PM   #2
Dakar09
The Blue Baastard
Dakar09's Avatar
The plan is as follows:
530 head w/oversized valves - have
IPD turbo cam - (need to get)
MS (fuel only) - (need to get)
B23 intake - (have) with a Chrysler FPR feeding Bosch 0 280 150 400 46# injectors (need)
15g - have
T5 swap - (have freshly rebuilt WC T5 for 86-92 5.0 Stang)
NPR I/C - (need to get)
740t in-tank pump feeding 240t main pump with a new sending unit (have all)
BBS mesh - 16x7 (have)
full upgrade of all suspension componenets + HD Bilsteins and IPD or B&G springs (have some stuff, need most)
brakes - probably run stock caliper with better rotors and ceramic pads, stainless steel lines
Here are some goodies:
Old 12-31-2010, 03:16 PM   #3
crazy240
crazy240's Avatar
Best colour in my opinion. Good luck.
crazy240 is offline   Reply With Quote
Old 12-31-2010, 04:08 PM   #4
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Great find! +1 on best color.
Old 12-31-2010, 04:50 PM   #5
doucheNozzle
doucheNozzle's Avatar
What are you going to do for ignition?
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'11 XC90 V8 - Torque Monster
Old 12-31-2010, 05:57 PM   #6
Dakar09
The Blue Baastard
Dakar09's Avatar
Thanks dudes.
From what I understand, you can use the stock ignition (with improvements like an MSD coil) on this with the MS for fuel. I may go this route to get it running right, then switch over to MS for ignition as well. I have a time limit to get this thing ready and want to avoid changing both fuel and ignition in the engine at the same time.
Old 12-31-2010, 06:03 PM   #7
DNAsEqUeNcE
†John3:16
Dont forget the MSD box as well.
Old 12-31-2010, 07:24 PM   #8
doucheNozzle
The ignition is easy to do. Just get a LH 2.2 distributor and slap it in. That's were you can make some power over kjet. The fueling won't be that much of an improvement.
Old 12-31-2010, 11:18 PM   #9
Dakar09
The Blue Baastard
Dakar09's Avatar
I meant to add the MSD box...I run through the various parts of this project in my mind all the time and leave parts out
From what I've read, fueling with MS will make a huge improvement over K-Ket. With the MS ignition, I would need to run new wires to the distributor, no?
Old 12-31-2010, 11:19 PM   #10
doucheNozzle
How long does that take?
Old 01-01-2011, 01:19 AM   #11
Dakar09
The Blue Baastard
Dakar09's Avatar
It's more a matter of getting the wiring correct while trying to sort the fuel out as well. Too much all at once, and it's tough to diagnose any problems that arise. Mechanical stuff I can do all day, I'm not a huge fan of wiring by any stretch of the imagination.
On a side note...on the pic of the intake manifold, what is that thing in the hose coming off the center of the manifold (sort of resting on the fuel rail)?
Old 01-01-2011, 03:23 PM   #12
pwschuh
Rolling...
Looks like vacuum source with check valve. Power brakes or vent system?
"No man would listen to you talk if he didn't know it was his turn next." E. W. Howe
Old 01-01-2011, 03:55 PM   #13
doucheNozzle
It's for your HVAC
Old 01-01-2011, 04:40 PM   #14
Karl Buchka
Targa Newfoundland has been on my to-do list for a long time. Would love to take the 242 up there some day.
Good luck with the project. Can't wait to see this take shape.
If you need any help with an MS install or wiring, send kildea a private message. He's nearby in Wellesley and has done quite a few installs for people.
Old 01-01-2011, 11:10 PM   #15
Dakar09
The Blue Baastard
Dakar09's Avatar
Great to know, Karl. Thanks for the heads-up on kildea. It's a life changing event, the Targa. We went through serious withdrawals after this years event, even though we found the Grand Touring class to be fairly boring in the M5. I CANNOT wait to go back. I have a video on Youtube (search for "M5 brigus"), onboard during the last stage. Apparently a semi-famous driver had won it a few times in a 142 several years ago, he and his daughter IIRC.
And thanks for the vacuum source info...do they go bad at all, or can I just leave that one in place?
Old 01-01-2011, 11:13 PM   #16
doucheNozzle
How are you getting the car over there?
Old 01-01-2011, 11:44 PM   #17
WindowsBreakerG4
ALDORF THE DESTROYER OF WHITE SHIRTS
WindowsBreakerG4's Avatar
Love the color! Looks like you'll have quite the car! Should the color code 200 group ;) http://forums.turbobricks.com/group.php?groupid=79
ovlover: Its an auto. Problem found, Manual swap. Problem solved
Originally Posted by cosbySweater View Post
She was pretty damn hot. And she folded my clothes and made me breakfast in bed
Towery wants to get me drunk but doug already is. Don't trust a drunk Towery he will slip you the old stiff one eye
I AM ALDORF THE DESTROYER
1985 744ti M46 -3rd, 15g, 3" exhaust, Ported Head, 333,333 miles
91 945 Turbo 3 pedal auto, DD
83 242 Turbo Flathood
15 Golf TDI 6 Speed
Doug <3 me. Not scottyd. doug was here again
WindowsBreakerG4 is offline   Reply With Quote
Old 01-02-2011, 12:47 AM   #18
John2x240
John2x240's Avatar
I think the lad with the 142 would be Doug Mepham (?). He ran (and won?) in the Targa Tasmania too and I think he was involved in organizing the first Targa Newfoundlands.
'88 Volvo 240 auto (now a parts car), '89 Volvo 240 5 spd. (now a daily driver), '92 245 5 spd. (new my car), '80 Holiday Rambler/Ford E350 (tow vehicle and track crash pad), '95 GMC K2500 (local hauler/back-up tow vehicle), '83 Mazda RX7 (race car when I have the funds), '99 Miska 20' car hauler.
The man's prayer: "I'm a man, but I can change, ... if I have to, ... I guess."
John2x240 is offline   Reply With Quote
Old 01-02-2011, 03:15 AM   #19
Dakar09
The Blue Baastard
Dakar09's Avatar
That's him, John. He was co-driver in a Targa car this year, but I can't recall what team it was. Didn't have much of a chance to speak with him.
As for getting it there, it will be shipped. I drove last year, 2.5 days to get there (via ferry w/delay) and 1.5 days coming back. Not again.
Old 01-02-2011, 03:16 AM   #20
doucheNozzle
Awesome. I'm way jealous.
Old 01-02-2011, 03:59 AM   #21
classiccarsrule85
subscribed this is something that ive always wanted to do i really enjoy auto cross and going to start rally x shortly but id like to get into something like targa newfoundland
anyhow good luck with your build i do have to say im jelous this looks like it will be a good fun car.
Pending pick-up-'88 740 GLE
classiccarsrule85 is offline   Reply With Quote
Old 01-02-2011, 04:01 PM   #22
John2x240
John2x240's Avatar
Did you meet any members of my club (the Motorsport Club of Ottawa) there last year, in particular Martin Walter and Ferd Troutmandorff in the Nissan 240 SX? They're a good example of what can be achieved on a very sparse budget. Also, did you get to meet the two wounded Afghan vets (also MCO members) in the Soldier On team? 1st in class in their first attempt, and neither of 'em with both legs ... a great example of perseverance.
Anyway, good luck with your efforts and now I have another team to cheer for at the next Targa Newfie.
Old 01-02-2011, 04:12 PM   #23
Dakar09
The Blue Baastard
Dakar09's Avatar
I did meet the 240SX team, very nice guys. They were huge fans of the M5 actually. I met the Soldier On guys as well. They were a bit overwhelmed by all the publicity and didn't gel with the rest of the competitors until much later in the week, but they were hounded by press most of the time. What's amazing is the car was barely prepped, aside from the roll cage and the driver's aids for their handicap. They kept roasting their stock brakes. We also ran with the Trailer Park Boys, Trembley and Wells. They were awesome. Shared some drinks and actually had them laughing, which was pretty cool.
All in all, it was simply amazing.
Old 01-03-2011, 01:55 AM   #24
blkbox
Sounds very interesting project!
Keep up posted with updates and results
Wagon FTW haha
blkbox is offline   Reply With Quote
Old 01-03-2011, 11:17 PM   #25
wingnutty
wingnutty's Avatar
yea but paint it blue and yeller
wingnutty is offline   Reply With Quote
