Old 01-19-2011, 05:26 PM   #1
Turbosteen
I was born at a young age
Turbosteen's Avatar
Default Rebuilding our Amazon
So, as the title suggests, this is a shared project.
Since we (my brother JW240 and I) have our cars up and running good enough we decided to take a look in the shed if there's something else to start with. Behold, an Amazon (121) from 1970.
The story starts in the summer of 2007. We bought the car on Ebay Germany and picked it up.
Some pictures from when we got it:
B20A engine
Nice seats btw
Extra stuff we got with the car like doors etc.
After some rallying around the house with it we started to realize that it wouldn't be a simple job to restore this car. We decided to ditch the body and keep all the mechanical bits when we found a body that had been restored a few years back but had been involved in a crash.
This was again an Ebay auction where we acquired it and hauled it back home.
We fitted the axles and gave it to a local guy who has good skills to fix it up (engine had rammed the firewall, front beam under radiator needed replacing etc.) With some bodypanels of the old green Amazon we then had a good starting point to work with.
That's where the project grinded to a halt. So we now have a rust free, very good, multi-colored Amazon body. And tons of mechanical bits as well off course.
In the last months I decided we just needed to start somewhere, and since tearing stuff apart doesn't cost money I opted for the engine... and then you discover it's going to cost even more money
On the stand
A few surprises on the way:
- 8 bolt crank (so engine must have been replaced)
- modern type seal was already in
- 1st oversize pistons
- Remarkable new looking valve guides
Now for the bad surprise.. damaged cylinder walls.
This is on all 4 cylinders I think. At least on three of them, and it's pretty deep.
So we now move onto the build plans for this car, I can say this: it won't be finished next year
So far we've opted for the ''how Volvo should have build it'' option. Meaning we are going towards old skool performance.
Engine wise this gives something like:
- Keep the B20
- Carbs
- Porting the head
- Header
- Make use of the 8 bolt crank > 2.2L B20 already acquired a set of new B21 flat tops (92.48mm)
etc.
Chassis/transmission:
- Keep the M40, or maybe opt for a M46/M47
- Keep stock back axle unless we can do a 240 axle conversion (5x108)
- Weld the body in critical places for strengthening
- Lower it, all the normal bits like Bilstein etc.
- 164 vented brakes up front, or something else that is an easy improvement over the current setup
etc.
Body:
- We don't know what color it's gonna be
- Big and wide steelies
So we'll be looking closely to the Pushrod performance thread for tips and tricks and to the picture threads. It's all in the beginning stages now. If you have an awesome idea for this car, don't hesitate to post it!
Philip
Project '82 760 16vT | Amazon | B204GT | Feedback |
Husqvarna Nuda 900
Turbosteen is offline   Reply With Quote
Old 01-19-2011, 05:27 PM   #2
Turbosteen
Turbosteen's Avatar
Mine
Old 01-19-2011, 05:27 PM   #3
Turbosteen
Turbosteen's Avatar
Mine as well
Old 01-19-2011, 06:22 PM   #4
Tom Wiley
glwp
Tom Wiley is offline   Reply With Quote
Old 01-19-2011, 06:35 PM   #5
Fivehundred
Fivehundred's Avatar
I'm not entirely convinced You need 164 front brakes, the car is so light it ought to be enough to have the standard brakes in good order. You've got the dual circuit brakes. Stuff in an 1800E or ES rear axle maybe. It's a straight bolt in in assuming the replacement shell has late rear suspension.
Why M46 for the recipe you're writing an M41 will do the job I'd have thought?
Fivehundred is offline   Reply With Quote
Old 01-19-2011, 07:03 PM   #6
Dirk242
Gonna follow this one. Good luck with the rebuild. It's in good hands. That's one thing for sure.
Dirk242 is offline   Reply With Quote
Old 01-19-2011, 09:49 PM   #7
wingnutty
wingnutty's Avatar
So far so good,I m gonna be watching this one
wingnutty is offline   Reply With Quote
Old 01-20-2011, 05:06 AM   #8
Turbosteen
Turbosteen's Avatar
You're right about the brakes, it is indeed a light car but I was thinking that if we're at it (replacing all the major components in the brake system) we might as well go for the 164 parts. (And at the same time converting the hubs to 5x108).
P1800 axle would be ideal, but I'm not sure if we're able to source that (at reasonable costs), this doesn't need to be a cheap build but keeping costs down is always a +. It is good though that we're getting suggestions already in this build, I'll make a list for the options we need to consider (so looking for parts and their prices is something I have started to do already).
About the gearbox; the main goal is to have a fifth gear. I thought M41's were über rare and $$$? Good option to look out for, since it's easier to fit.
We also don't know how muck work it would be to adap the body to fit another gearbox (M46/M47). Anyone with some links for examples on that one?
Old 01-20-2011, 06:18 AM   #9
Fivehundred
To fit the M46 you need a bellhousing that has been split in half and re welded. Front half M40 rear half M46 or M47. Huke Basart does do them http://www.hukebasart.nl/huke/
If you want I'll keep an eye out for a back axle and gearbox, or buy a whole scrap ES. As a friend of mine once remarked, "I love 1800s, every one contains an overdrive gearbox for a 120".
Old 01-20-2011, 06:54 AM   #10
larry818
larry818's Avatar
I thought all the 1970 122s came with the 1800 disk rear end? I thought they all came with overdrives as well...
larry818 is offline   Reply With Quote
Old 01-20-2011, 07:23 AM   #11
Fivehundred
Nope, the 1970 cars had dual circuit brakes with rear drums. Overdrive always was an option. Supposedly Volvo did build rear disk brake Amazons but I've not personally ever seen one. It is in the late parts manuals and there was a road test of one in Australia.
Generally they were stripped down to price them below a 140, no bonnet stripe, no overriders, no door pockets, matt black handbrake lever (not chromed).
What they did get was the dual circuit brakes (essentially lifted out of an 1800 ES) and a steering lock ignition switch. They also came with alternators.
Old 01-20-2011, 07:31 AM   #12
JW240
All idiot, no savant
this is a 121, B20A, M40. I dont think they sold the basic model in the US?
Here are some pics that i found from 2007:
240 | 1991 | 345K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack (parked for a many months)
dd: 940 | 1992 | B230FB | Polaris | some mods
Old 01-20-2011, 08:13 AM   #13
Turbosteen
Turbosteen's Avatar
That would be very nice!
Is there a specific year to look for when searching a P1800 axle? I found one from 1972
I also found a site similar to the one Huke Basart,
http://www.tinustechniek.nl/0-home.html
Good thinking so far! More choices to be made then I anticipated
Old 01-20-2011, 10:41 AM   #14
dopski
* bookmarked
Nice project, never saw it before, although i saw on the NL-sites you had this kind of project.
dopski is offline   Reply With Quote
Old 01-20-2011, 12:03 PM   #15
Ruben
Ruben's Avatar
So no Folkracebil?
Rustbucket was a lot of fun to drive!
A dirty mind is a joy forever
Drove:
'87 Escort 1.3:'90 mini Jumbo:'87 360GLT:'87 744T:'92 240 Polar:'84 744T:'95 854T5:'90 744GLE 16v:'87 340 1.7:'79 343DL :'84 340L:'91 240DL lpg:'89 360 GL:'94 944TDIC M90:'85 360 GL:'90 745 GL:'89 744 GL:'86 745 TIC:'94 Nissan Sunny 2.0D:'92 Peugeot 205D:'88 360:'85 340GL:'86 360GL:'84 242TIC: '85 244 TI:'89 Dai racer:'95 460: '85 360GLS:'83 340 DL: '97 944IC: '91 AX Cup:'93 Diehatsu:'98 Polo D:'87 360GL
Drive:
Citroen C15D
Ruben is offline   Reply With Quote
Old 01-20-2011, 12:42 PM   #16
Dan820
Dan820's Avatar
Everyone always says M41's are hard to find.
It took me all of 20 mins to find one for my Amazon (granted I drove 120 miles to pick it up)
Nice thing is they're so damn tough and paired (normally) with underpowered motors so they are almost all still around, lol.
Dan820 is offline   Reply With Quote
Old 01-21-2011, 04:56 PM   #17
volvo78244
Ring apprentice
volvo78244's Avatar
I knew this was coming around eventually.
I have the best idea for it, finish it quickly and donate it to my wife since this is the only older Volvo she likes.
Post some current pics. I think I'm gonna like this thread
2019 Peugeot Expert
2005 V70 - 2.4D
1992 740 B230FD
1982 242 B230FK
volvo78244 is offline   Reply With Quote
Old 01-22-2011, 01:37 PM   #18
Turbosteen
Turbosteen's Avatar
Originally Posted by Ruben View Post
So no Folkracebil?
Your 340 will be a good alternative
I found one that's for sale now, rebuilded etc. for €750,- ($1000,-). If that's our only option we're going for the M47 with modified bellhousing
No
Just stripped the engine a bit more. The next surprise is a steel timing gear (B30):
An 'A' cam, looks to be in very good condition. But it won't be used I guess..
The lifters are a bit scratched, some more than others.
Crank etc. Oil pump looks newish too.
Getting a spare head now so we can tinker a bit with porting etc.
Old 01-22-2011, 03:34 PM   #19
J2_
J2_'s Avatar
Looks good Philip & JW !
J2_ is offline   Reply With Quote
Old 01-23-2011, 11:48 AM   #20
Turbosteen
Turbosteen's Avatar
Thanks!
As it stands now:
Where engine hit firewall, now fixed
Random:
Old 06-28-2011, 05:32 AM   #21
dopski
And.. Any progress?
Old 06-28-2011, 11:31 AM   #22
Turbosteen
Turbosteen's Avatar
Originally Posted by dopski View Post
And.. Any progress?
Many, many interesting metal object have started to collect themselves around this car. The amount seems to grow given enough time. Considering the fact that my holiday starts this Saturday, I will be busy making sure the interesting parts will develop themselves in (sometimes performance) additions for the 121.
You want to come and help me clean off 5 million cubic feet off paint, dirt, junk and other not so pleasant substances?
Pics will follow next week
Old 07-07-2011, 04:16 AM   #23
dopski
Ok, sounds nice!
I'm very interested
Normally no problem, but this weekend i'm going to help my brother with the suspension of his 142.
Old 11-09-2011, 07:52 AM   #24
mark244turbo
mark244turbo's Avatar
There's a volvo 240 turbo back axle for sale in Meijel. That's pretty close to you guys. It's modified for fitment in an amazon (new brackets welded on using a welding mall). That would be a good basis for future mods (like a T6-engine ).
What are you going to use as a gearbox? A whiteblock-m90 from 960?
mark244turbo is offline   Reply With Quote
