Old 02-07-2011, 10:17 AM   #1
eeaves42
eeaves42's Avatar
Default Service Light Reset
In my 1990 740 the service light just turned on, not the check engine light. It says on for 2 mins and its off, my local Volvo repair shop said just remove the rubber plug near the speedometer, I did that. Yup nothing happend.
eeaves42 is offline   Reply With Quote
Old 02-07-2011, 10:35 AM   #2
moedmus
there is a push in below that plug in the dash put key on push it in and hold for a few secs it will go out
moedmus is offline   Reply With Quote
Old 02-07-2011, 12:11 PM   #3
Tuesday
Volvus Seven Fortus
Tuesday's Avatar
Also, you need to push it until it clicks in. It will stay on after you press it if you don't click it in all the way.
-Z
Tuesday is offline   Reply With Quote
Old 02-07-2011, 01:08 PM   #4
eeaves42
eeaves42's Avatar
I did remove the plug and press the button until it clicked, do i need the car running or in run?
Old 02-07-2011, 01:14 PM   #5
just be careful not to lose that plug into the cluster. Car doesnt have to be running, but it can be.
Old 02-07-2011, 02:01 PM   #6
eeaves42
eeaves42's Avatar
http://s819.photobucket.com/albums/z...t=5e7c1ea7.mp4
hear the click
Old 02-07-2011, 04:16 PM   #7
something just isnt right then. Try it with the car running I guess? I dont even know what turns the thing on, but that would be next.
Old 02-07-2011, 04:22 PM   #8
eeaves42
eeaves42's Avatar
It can never be easy, I like the idea of a service reminder light so I do not want to just remove the bulb. Quote by Volvo "Every 5,000 miles the ser-vice light will stay on for 2 mins on start up" end quote. I have googled it and some say there is a switch behind the cluster about where the 80 mph is. Yep there is no switch. What turns it on should be a ECU..... man I miss my 83 245 TIC... ecu??? **** that! We have K-Jet
Old 02-07-2011, 04:30 PM   #9
yeah it comes on every 3500 or 5000 miles. I dont know exactly. It might be the cluster that turns it on, but probably the ECU.
Old 02-07-2011, 06:29 PM   #10
ecow
It is a reminder to change your oil. The plug is on the back of the cluster.
ecow is offline   Reply With Quote
Old 02-07-2011, 10:20 PM   #11
psychoelf
The Smoking Volvo
psychoelf's Avatar
My '87 740 has it behind the cluster at the top of the speedo. There is a counting mechanism up there that keeps track of the service miles. If you never reset it, it will eventually jam your odometer. Don't know about the newer clusters in the 90 though.
psychoelf is offline   Reply With Quote
Old 02-07-2011, 10:24 PM   #12
miguel.760ti
miguel.760ti's Avatar
turn the key to position II, push the button a couple times, then start the car
1988 760 Turbo
also
2016 Ford Fiesta ST
1995 Ford F150
miguel.760ti is offline   Reply With Quote
Old 02-08-2011, 02:05 AM   #13
eeaves42
eeaves42's Avatar
I like the sound of that, I will try that first thing in the morning.
1990+ cluster does not have a reset switch behind the cluster.
Old 02-08-2011, 02:10 AM   #14
MasterBlaster
1990 doesn't use an electric button, nor does it care of the engine is on or off (though with the key on it's easier to see when the light goes off). It's gear-driven just like the trip meter, and resets the same way. Pull the rubber plug, get something pointy in there, and push. The first 1/16" or so takes up the slack, the next 1/4" (sometimes so stiff it feels like you'll break the cluster in half) does the resetting.
447,000 km so far...
