Old 08-10-2004, 06:14 AM   #1
mattias
Default How about this? 940 turbo tuning!
I have a 945 -1996 LPT
Planning to do this:
531 ported
K-cam, adj camgear
15G turbo from 850
3" exhaust from turbo
465ccm green tops
72mm AMM
3" piping from AMM to turbo. Cone filter.
And of course matching chip to it.
mattias is offline   Reply With Quote
Old 08-10-2004, 06:22 AM   #2
grizlyadams
ni!
grizlyadams's Avatar
Sounds good to me, what about a V16 turbo cam instead of that k?
What chip are you thinking about, i take it there are companiesover your way that will do a custom map for the 940 etc...got any more details?
Griz
I AM THE GRIZ!!! (bit like the brummy stig )
2007 V50 SE - chipped
grizlyadams is offline   Reply With Quote
Old 08-10-2004, 06:26 AM   #3
MikeHardy
The Sirius/Nova Police
MikeHardy's Avatar
yeah i'm pretty sure if you loaded your ride up with such. and take it to a chip tuning place they could do the same on the rolling road here griz
Mike
Lost my 2004 V40 GDI sport lux in local flooding last november, currently driving a Mercedes E430 avantgarde with prins LPG system (Sorry guys it is fun though)
MikeHardy is offline   Reply With Quote
Old 08-10-2004, 06:27 AM   #4
mattias
You think the K-cam is bad? even if one can "fine tune" it with the camgear?
I think i have found a guy that does custom maps for both ignition and fuel. 6-700$
Old 08-10-2004, 06:29 AM   #5
grizlyadams
ni!
oooooo, nice!
Mike, problem is, rica used to do custom maps for the 940's, but i dont know if they still do as they removed it from there site, they are only up the road from me, and if they still did custom maps for the 940's, man that would be cool. Besides, im planningsomething more extream than what hes listed....
One questions, what injectors are you using then? from what?
Griz
Old 08-10-2004, 06:30 AM   #6
MikeHardy
MikeHardy's Avatar
if you want to use K cam by all means do. has it been cut for head mount or are you going block mounted dizzy
Old 08-10-2004, 06:36 AM   #7
mattias
Injectors are the green ones from V70R I think, 465ccm at 3,8bar.
K-cam is for the head mounted thingy. Was in the 531 head i bought off the junkyard for 200$.
Old 08-10-2004, 06:39 AM   #8
MikeHardy
MikeHardy's Avatar
really thats very strange, the K cam was last used in the B23E with block dizzy in 84 so never got cut for head mounted dizzy. if you've found one cut someone may of had it done in the past and you've got something very rare
Old 08-10-2004, 06:46 AM   #9
TheJoyOfSix
Grumpy old git
TheJoyOfSix's Avatar
I agree with raven, K cam in a 531 head is unusual to say the least!
1999 Volvo S80 2.9 SE lux, 1988 Merc 500 SEC
TheJoyOfSix is offline   Reply With Quote
Old 08-10-2004, 06:51 AM   #10
grizlyadams
ni!
ah right, at 3.8bar.......the 940 FRP is 3 bar mate, are you going to use a 4 bar? otherwise they arnt going to flow 465cc with only 3bar of fuel pressure.
Griz
Old 08-10-2004, 06:52 AM   #11
mattias
Looks like it is one anyway, or?
Old 08-10-2004, 06:53 AM   #12
mattias
Griz
Im going to use a rebuilding kit on the one in there now. Then I can use the pressure I want to.
Old 08-10-2004, 06:54 AM   #13
MikeHardy
MikeHardy's Avatar
looks like you do have something rear then. do get that someone would of have to take it to a machine shop and have that groove cut into it at the exact angle.
Old 08-10-2004, 07:03 AM   #14
mattias
according to the note attached to the head it was from a 1987 740 turbo. But I guess some previous owner must have changed the cam.
Old 08-10-2004, 07:58 AM   #15
MikeHardy
MikeHardy's Avatar
so probably from a B230ET then hence the 531. so should of had a A cam in there stock, but nice that they upgraded to a K cam and had it cut. most people would swap to a block dizzy to do that
Old 08-10-2004, 12:13 PM   #16
Hoggster
Sacred Chao
Hoggster's Avatar
Tell me more about this FPR rebuilding kit.
And I don't think those guys meant that the K was a bad cam, I think they meant that there are still better cams out there, but hell you've got a K cam so why not use it. especially with an adjustable gear.
'86 744 GLE - Normal
'85 744 B234F - LeMons #16
'82 242 B21MPG - Chop top
'87 244 DL - Budget +T build
Hoggster is offline   Reply With Quote
Old 08-10-2004, 12:19 PM   #17
mattias
here is a link to the FPR rebuild kit!
http://www.amworks.com/eng/irtokannet.htm
