evening all
can anybody point me in the direction of any threads detailing the ins and outs of upright mounting a b230 16v in a 240. ive had a search around and the only one i could find is 2fast242gt's thread, im wondering if theres any others about so i can get as much info as poss before tackling it cheers Tom |
Rad Panda
you'll shoot your eye out
'79 242 GT - Project '91 SR5 Pickup - Work Beater '84 BMW 533i - Summer Daily |
Pastafari !
I don't know if there are any more threads on it?
I'd like to do it too, although it's not happening anytime soon. It strikes me that right hand drive would prove advantageous with an upright 16v in a 240, and it looks most excellent! |
#4 |
cheeseland highschool kid
What did you want to know its expensive and alot of work pm me with any questions
1980 241gt *6.0 lq4 swaped* |
#5 |
#6 |
still rides with MrDoug
![]() Join Date: Feb 2007
i mean why? it's not like you are trying to put this in a 122 or something
-Matt 1989 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes. 1983 Ford F150- 302ci, C6/4x4, 7" lift, 35s. 1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, Bulletspeed lower, HR-Titan 20p. the rest: 1996 850t 179k, 1998 S90 175k, 2004 V70 2.4 175k, 2005 XC90 2.5t AWD 122k. |
#7 |
AEM infiniwhat?
![]() Join Date: Aug 2009
Cuz vert 16vt's are sex.
942j 623whp 944 568whp RIP 941g 16vhttp://forums.turbobricks.com/showthread.php?t=199503 SHEETMETAL INTAKEhttp://forums.turbobricks.com/showth...etmetal+intake feedbackhttp://forums.turbobricks.com/showth...ght=nathaninwa http://brickspeed.net/forum/forumdis...?fid=42&page=1 |
#8 |
Pastafari !
As it's right hand drive, it gives more room for exhaust/turbo so they don't conflict with the brake master cylinder/steering column, gives an opportunity to fix the crappy 240 engine mounts, and looks great, what's not to like?
#9 | |
Backwards Turbo
![]() Join Date: Feb 2005
From osmosis I have gathered that you need a B20 oil pan, and that you need to cut and weld the pickup on a B230 oil pump for the correct angle, and then make engine mounts. And for transmission you will either need to do a swap with an adapter plate for upright, or use an M4x with the uber rare M45 bellhousing from a 1974 140, or something. |
#10 |
Yeah it adds up in small bits don't forget your new intake manifold and maybe exhaust if its a 240
#11 |
AEM infiniwhat?
When verting with a gm V8 T5, the transmision actually gets located in the stock position that gm intended.
#12 |
This looks like the route I will be taking sooner or later.
RHD 16v in 240 means auto as the head conflicts with the clutch master cylinder. Tilton pedal box will solve it...at $800! Mounting the engine upright will probably be cheaper than that, and will give room for turbo too. RHD 240 has very little room for turbo with steering shaft in the way, even less room for a bigger than stock turbo... As I will be going to most likely a T5 gearbox anyhow, and the adapter stuff is non existant in Aus the bellhousing issue will be there for me upright or slanted so it's not an issue... |
#13 | |
one and the 16v head sits stupid close to the clutch master, i have the clutch pedal from a 940 16v with the internal master that would solve that problem but as nathan said upright 16v are sex, so im going for that option instead ![]() tom |
#14 |
OK, I'm not saying don't do it. If you have the time and money go for it.
I have experienced up-righting a b230ft 8v It was a ton of work. Some of the things i see you needing to do for sure to make it happen. Motor mounts: I used 140 b20b motor mount feet with early 240 motor mounts. b20 oil pan: you will need this so i will clear the X member. B230 oil pump: Cut and fabb up the pumps pipe to fit in the b20 pan Down pipe: Cut and relocate pipe to new position Possible other issues; When stuff gets moved around it causes a knock down effect. Expect certain wires to be too long or too short. The air intake may need to be modded to fit. Throttle linkage/ cable too short now etc. Transmission suggestions. A m40 or m41 will fit on the back of a b230 however if you plan on making more than 300hp I would not use it. see my sig link for ideas about mounting upright. |
#15 | |
Thx in advance!!
BritishBrick is currently hoarding parts for a vert 16v monster like half of the rest of you.. ![]() Fo Sale Thread : http://forums.turbobricks.com/showthread.php?t=276795 Wanted Thread : http://forums.turbobricks.com/showthread.php?t=254940 Feedback Thread : http://forums.turbobricks.com/showthread.php?t=242385 |
#16 |
I'm looking at doing a powerglide upright 16v , i got 2 16v engines, but geting a powerglide in the uk is
...Sorry about the spelling and grammer but i really cant be arsed. |
#17 |
Backwards Turbo
Besides the advantage of looking totally awesome and giving you a LOT more room on the exhaust side for a nice header and huge turbo, mounting the engine upright and using the B20 pan lets you lower the engine almost 2" at the crankshaft centerline IIRC. This is great for lowering the center of gravity of the car, as well as makes it easier to fit a large transmission (such as a T56) in the tunnel.
#18 | |
M90s are lame anyway
#19 | |
#20 | |
ドクターマリオ
The room from vert mounting would give you a lot of room for a nice clean bottom mount header too. You could even do a sweet backwards turbo setup |
#21 |
†500DollarSparkMap
![]() Join Date: Jan 2009
it would enable you to not have a turbo sticking out of the hood if you so desired
Matthew 10:28 And fear not them which kill the body, but are not able to kill the soul: but rather fear him which is able to destroy both soul and body in hell. ![]() |
#22 | |
doing something stupid
this is the only real reason for me at this point :P
88 244 - m47 - on the bumpstops - 366k on the clock 83 245t - m46 - the green monster - 130k - 260whp/280tq with a lot on the table 94 z28 - t56 - pull me over red - 100k Quote:
#23 |
That's your own fault. That turbo is too big.
#24 |
AEM infiniwhat?
When I get my 240 front clip.....ill look into desinging a drop in, weld vert setup. Seems theres a lot of interest lately in this.
#25 | |||
There's a gif for that.
| Thread Tools | |
| Display Modes | |
