Old 03-06-2012, 09:51 AM   #51
MadDog_945
MadDog_945's Avatar
Originally Posted by F20A2-T View Post
It has Alu pipes with just one layer of cf.
It's just for looks, nothing fancy.
We still have to pressure test it, so we'll see how it holds up.
The car is in the shop now and is awaiting the trail fit for the compounds. If it only knew what is coming..
And we ordered a bunch of parts (wastegate, BOV etc)from Sweden and the US, Hopefully they'll be here this week.
Cool stuff
And how did you do the merge between the intakebody and the runners?
Old 03-07-2012, 01:32 AM   #52
T-RAN
T-RAN's Avatar
Does gas/paint thinner not have any ill affects on the carbon fiber? Any specs on the rest of the car? Rad Build! BTW, this thread is showroom worthy if not project/resto worthy. May want to have a mod move it for ya?
T-RAN is offline   Reply With Quote
Old 03-08-2012, 04:50 AM   #53
F20A2-T
MAN THAT IS THE ONE!! How much would you need for one of those if it holds up to the pressure test? That is going to make BIG POWER! looks like surge tank intakes used on 1000hp supras. what are you using for the twins?
Let's hope it makes big power!!
For the compound twins we're going with a .60/.63 T3 for the HP and a GT35R for the LP.
Cool stuff
The CF is sandwiched between two aluminium plates which fit over the runners.
Only the inner plate is welded to the runners.
As far as i know the gas doesn't have an effect on the CF. But I would have to ask Stefan to be sure. I think we otherwise would end up with a very floppy intake
The Car (1982 240 Turbo) is completly stock at the moment. When the engine is finished, we'll turn our attention to the car. It'll get the full treatment for sure.
Thanks everyone for the positive reactions!! It sure makes us want to continue this build.
It will be slow going for the most of time. But we'll get there in the end.
F20A2-T is offline   Reply With Quote
Old 03-08-2012, 12:12 PM   #54
MadDog_945
MadDog_945's Avatar
why are u using a b21? because you just have it, have to (reglement of something), or want to?
Old 03-08-2012, 01:44 PM   #55
F20A2-T
It is easier to keep the original engine. Otherwise it would have to be re-registered.
A lot of guys don't do this, but you'd run the risk of having no insurance when you get in to an accident.
We just want to be on the safe side.
There is a B200K in the car now just for mock-up purposes.
Old 03-08-2012, 04:43 PM   #56
MadDog_945
MadDog_945's Avatar
Yeah... great... thx... now i have a bad conscience about my project again... :/
Old 03-08-2012, 04:49 PM   #57
Turbosteen
I'm back
Turbosteen's Avatar
Since I did change my engine I can tell you that you can go to the rdw and apply for uhmm.
In t Nederlands; voor ongeveer €50,- heb ik een omkeuring laten doen. Ik moest aantonen dat het nieuwe blok niet gestolen was en dat het goed ingebouwd was (maar was toch origneel volvo dus geen probleem). Ze hebben de auto ook opnieuw gewogen en de rembalans getest (niets gezegd over grotere remmen). Nu staat alles op kenteken en is het dus ook in orde met de verzekering. Dit kan in feite met alle auto's en alle motoren mits het chassis ouder is dan iets van 1998.
But the B21 is a nice and strong engine, so I like your choice. Great build so far!! Holland ftw
Philip
Project '82 | Amazon | B204GT | Feedback
Turbosteen is offline   Reply With Quote
Old 03-13-2012, 04:16 AM   #58
F20A2-T
Injector fitting....
Next up...
Making a fuelrail. And a whole lot of other things
@ Turbosteen
Yes we could have it re-approved. But we'd like to stay with original engine.
Although we might have it re-approved for the "small" horsepower gain.
Old 03-13-2012, 04:38 AM   #59
MadDog_945
MadDog_945's Avatar
Mh.. arent they sitting too deep in that pocket ? i would be concerned about drips who could occur around the edges due to fuel is sprayed against the wall?
/edit
did you just pinned up the pasticbags from your orders ? :D or do you have an endorsement with KLR ? IC many parts from him ;)
Old 03-14-2012, 05:00 AM   #60
F20A2-T
/edit
We'll do a spray pattern test first. Just to see how things work. We can open up the holes in the head if it wouldn't work.
KL-racing has sent us many parts already.... In the picture you see a box with their tape on it. Just a coincidence it was there when we took the picture.
Old 03-15-2012, 05:14 AM   #61
ovlover
ovlover's Avatar
Hmmm nice work. Loving the thread. Keep up the good work!
I want to join the "I don't give a rat's arse about 300hp" club
My sheilas
http://forums.turbobricks.com/showth...ht=pics+beasts
Instrument Cluster issues?
http://forums.turbobricks.com/showth...t+cluster+bugs
ovlover is offline   Reply With Quote
Old 03-15-2012, 06:45 AM   #62
pwaes
pwaes's Avatar
poeh, dat gvd mooi werk wat daar wordt geleverd En waar precies in NL? Ik ga dit zeker volgen namelijk !!
pwaes is offline   Reply With Quote
Old 03-16-2012, 07:32 AM   #63
F20A2-T
We doen ons best
We zitten in Noord-Limburg... In de buurt van Venlo.
Anywho....
Some updates from the ignition department
Our Holva (Honda/Volvo) ignition.
And our two little wastegate friends
60mm left, 50mm right.
Old 03-16-2012, 09:49 AM   #64
bigreddog
Exclamation
BLING BLING
bigreddog is online now   Reply With Quote
Old 04-01-2012, 02:55 PM   #65
Stefan
Ok a little update from me... Pjotr has been posting on my behalf, thanks for that..
Last Saturday I finally got time to drill out the K-jet injector holes. It was kind of tricky opening those up as I wanted the new injectors to sit as deep as possible. The RC injectors also turned out to have a larger diameter compared to stock Honda injectors.
As you can see I also opened up the hole inside the intake port, this way I’m pretty sure the spray pattern isn’t compromised. (a spray test will have to confirm this)
Im still amazed to what glass bead does to aluminium, the thing looks brand new!
Anyway, I still need to clean the valves u little bit, the coating on the intake valves has been slightly damaged and I don’t want any hot spots bcs of this .
If all goes according to plan we will be able to bolt the head on next Wednesday.
Then ill also do a pressure test to make sure the intake manifold holds… (fingers crossed!!)
I still need to order an additional set of turbo flanges so we can start the whole piping campaign.
B21ETT project; compounding GT35+super 60
http://forums.turbobricks.com/showthread.php?t=234957
Stefan is offline   Reply With Quote
Old 04-01-2012, 04:46 PM   #66
F20A2-T
Damn... You beat me to it :P
Old 04-11-2012, 03:39 AM   #67
MadDog_945
MadDog_945's Avatar
glasbead is the **** !!
Old 04-11-2012, 09:30 AM   #68
740volvo
That looks just like my dizzy setup.
740volvo is offline   Reply With Quote
Old 04-16-2012, 09:04 AM   #69
F20A2-T
Well, the engine is completly built...
Next-up: Making the compounds....
And a whole lot of other stuff.....
I'll upload some pictures from the completed engine in a few days and hopefully some from our mock-up stages for the turbos
Old 04-16-2012, 10:17 AM   #70
DNAsEqUeNcE
†500DollarSparkMap
DNAsEqUeNcE's Avatar
Maybe take down the valve guides to the head?
Matthew 10:28
And fear not them which kill the body, but are not able to kill the soul: but rather fear him which is able to destroy both soul and body in hell.
Originally Posted by Karl Buchka View Post
Any ECU, when improperly wired, tuned, or installed will be unstable and unreliable.
Long live the pen15hood.
Old 04-16-2012, 12:52 PM   #71
lookforjoe
lookforjoe's Avatar
Awesome Build!
What do you use to make sure there is no residual glass beading in any oil/water passages? They will wreck the new engine very quickly if they are in there attached to the walls.
I'm curious about the injectors set directly in the head - isn't the heat soak going to be an issue? The K-Jet at least had phenolic spacers.
My XR
Old 04-16-2012, 10:59 PM   #72
Volvo244GLE
Volvo244GLE's Avatar
ive been running efi injectors directly into a k-jet head for 75 000km or so without issue. didnt modify the injector holes at all, mind you i didnt check the spray pattern either. i know people have put efi injectors into modified k-jet injector holders before, making them sit even higher, without issue.
244GLE Project - The fun daily driver. Rebuilt B23, ported 405, 37.5 exh. valves, BMW oil squirter's, MS2e, VX3 cam, King Springs, Bilstein HD's, upper+lower chassis braces, 26mm Falcon front sway bar, 21+19=24mm rear sway bar, SAAS bucket seats, hi flow rear muffler, almost every factory option.
164 Project - The impulse buy
242GT Project - who likes rust?
Volvo244GLE is offline   Reply With Quote
Old 04-17-2012, 02:50 AM   #73
MadDog_945
MadDog_945's Avatar
They get cooled by the fuel.. so.. should work?
Old 05-06-2012, 03:23 PM   #74
F20A2-T
Sooo... We had some time to spend...
Mock-up of the turbo's and the 3" downpipe.
And i ran the ignition wires..
On the mock-up engine / parts-car
And on the engine.
Now let's get TIGgy with it...
Old 05-06-2012, 04:14 PM   #75
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
****ing awesome, excellent work! keep it up..
-Matt
1989 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1983 Ford F150- 302ci, C6/4x4, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, Bulletspeed lower, HR-Titan 20p.
the rest: 1996 850t 179k, 1998 S90 175k, 2004 V70 2.4 175k, 2005 XC90 2.5t AWD 122k.
500dollar744ti is offline   Reply With Quote
