Old 08-21-2004, 01:48 AM   #1
coondog240
Homing Pigeon
Thumbs up T5 done, good news and bad
Finished the T5 swap tonight. I started w/ a '94 WC gearbox, which has a longer input shaft than earlier ones, so I put a new input shaft in it, turns out this year had reverse syncros.
I purchased my clutch components from John Parker he got me clutchnet's dual diaphram Pressure Plate 100% over stock balanced on to one of his 9lb aluminum flywheels/ with a carbon disc, and a Mcleod long TO bearing w/ fork adapters.
Everything installed perfectly, I was a little worried that I might have some clutch issues like the pioneers of this swap had. But the bugs have been worked out and the set up I have now works flawlessly. The clutch does its job correctly and noise free.
I made the mount that Noah posted a pic of in another thread.
And I had a 1pc. drive shaft made 46 3/8" center to center U-joints, 3" diameter.
Everything works beautifully, no complaints feels like the car came from the factory like that, but I am getting the same decel buzz noise that Dave B. has. And I don't really know why, but I can live with it.
I give this swap an A+.
-Jeremy
Oh, and if you can swing it get the aluminum flywheel it is a drastic improvement over stock.
coondog240 is offline   Reply With Quote
Old 08-21-2004, 06:37 AM   #2
mfpmax
Holy crap...reverse syncrhos! I could use that about now.
A 2.3, but not a Volvo...
Hesh wants some sex!
mfpmax is offline   Reply With Quote
Old 08-21-2004, 07:33 AM   #3
grizlyadams
ni!
grizlyadams's Avatar
nice.....just like to point out that the M90 has syncrhos on reverse.....
Griz
I AM THE GRIZ!!! (bit like the brummy stig )
2007 V50 SE - chipped
grizlyadams is offline   Reply With Quote
Old 08-21-2004, 10:31 AM   #4
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Coondog, I believe I got one of the first improved clutches that dropped in and worked. Mine was flawless. Every time we do a swap, the closer we get.
Now, I see your tranny sits at a slightly angle just like mine. I wonder if that could be part of the problem w/ the noise? (which btw, we all have). Seems to me, JP could rotate his milling 2-3* on the adapter to help line that up a bit better. Not really a huge issue, the motor mounts are so soft when you bolt it down that it levels out.
Does that have the .8 or .6OD? Over all pretty happy I'd assume!.. right?
Old 08-21-2004, 11:03 AM   #5
coondog240
Homing Pigeon
yeah I noticed it was on an angle too, I was thinking of elongating the holes for the mount and sliding it over.
This tranny has the .68 5th. And I will be swapping a 4.11 rearend from my Gt into my car soon.
Old 08-21-2004, 11:21 AM   #6
reeferman
broad member
reeferman's Avatar
Default T-5
nice install
t-5 is the way to go.i road in a 92 mustang with a wc t-5 he put in a year ago.sounds just like mine.the sound is not a volvo thing.
tony
[IMG][/IMG]
reeferman is offline   Reply With Quote
Old 08-21-2004, 11:35 AM   #7
mikep
The MP
mikep's Avatar
As long as it isn't a cruise noise I wouldn't sweat it.
I had a bunch of the early T5s apart for blocker rings in the 80s. The newer ones are great.
Originally Posted by DaBossk View Post
dornald blormpf bad because he has spine xd
I think that's a bit of a stretch to put him in the phylum chordata.
Old 08-21-2004, 11:32 PM   #8
coondog240
Homing Pigeon
Originally Posted by reeferman
nice install
tony
So you think that it is a T5 noise that is not related to our volvo's, but any car with a T5?
Old 08-22-2004, 12:02 AM   #9
mfpmax
Yeah, I think that buzz is normal. Before I swapped in my ...mustang... I read about auto to manual conversions and they say its normal. Mine certainly is a noisey bugger but my pilot bearing is the cause mostly.
GM Syncromesh "may" quiet it up, but it wasn't designed for it, but some sware by it.
Old 08-22-2004, 12:23 AM   #10
Chigga 744SE
Taiwan Panda Racing Unit
it eliminates that annoying 2nd gear grind on MKII's.
Chigga 744SE is offline   Reply With Quote
Old 08-22-2004, 11:29 PM   #11
Qc_Drifter
By T5 do you mean the Turbo 5 cylinder ?!?!!?
If yes, in which car is the T5 now ?!
And to reeferman , You swapped a T5 Volvo engine in a Mustang ?!
Any way .. may be i'm totally losted in your stories
http://QcDrifter.monchar.com
-89 240 DL
-97 850 AWD
Qc_Drifter is offline   Reply With Quote
Old 08-22-2004, 11:36 PM   #12
Bready
board deviant
Bready's Avatar
C'mon!
Sheesh
JB
Originally Posted by Pennybridge Pioneer View Post
Just because you didn't experience something growing up doesn't mean other people didn't. Case in point: I can't remember ever being a total moron, but that doesn't mean you aren't one.
Someone said “gavin” three times, and a troll appeared.
Keep your minds out of my pants.
Originally Posted by centason View Post
Bready is right.
Kalazdar - (3/23/83 to 5/12/03)
MUST READ!!! https://cleantechnica.com/2017/04/24...-adds-screwed/
Bready is offline   Reply With Quote
Old 08-22-2004, 11:52 PM   #13
mfpmax
Yup, T5 Volvo engine in a Mustang with a Jaguar inboard disc brake rear end setup.
NO!
Old 08-23-2004, 12:18 AM   #14
Qc_Drifter
Sorry !!! I only asked a question !!
But then what do you mean by T5 ?!
Old 08-23-2004, 12:19 AM   #15
Hard_Rocker
if you don't mind, what was your total cost for the swap, and how long did it take to get it all together once you had all your parts ready? I'm thinking WAY ahead here for a car I don't even own yet but it's good info to have
Hard_Rocker is offline   Reply With Quote
Old 08-23-2004, 12:22 AM   #16
Hard_Rocker
T5 is a Ford 5-speed manual transmission commonly found in Mustangs. It's an extremely strong transmission compared to the Volvo manual transmissions because it was designed to take the torque that a big V8 outputs. From what I've read it's becoming a fairly standard swap for high-power RWD Volvos.
Old 08-23-2004, 12:25 AM   #17
Qc_Drifter
Ok Thank you for the answer
Old 08-23-2004, 02:40 AM   #18
mfpmax
Oh I thought you was joking.
Old 08-23-2004, 02:44 AM   #19
mAydAy
Fabricatin'
mAydAy's Avatar
makes me wnant to do it....
mAydAy is offline   Reply With Quote
Old 08-23-2004, 02:45 AM   #20
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
I thought it was the new bi-directional, universal muffler bearing. ;) Sorry couldn't help it. Either way, a search will turn up lots.
-Kenny
Old 08-23-2004, 04:46 PM   #21
coondog240
Homing Pigeon
ALOT!
check PM.
Old 08-23-2004, 07:14 PM   #22
volvo9
volvo9's Avatar
Sweet! My car is high powered! j/k.
How much did your 1 piece driveshaft cost? I will probrably be switching to a 1 piece if I can't get this f*kin 2 piece to work correctly.
Did you have to modify that "little crossmember thing" which the driveshaft crosses through near the rear?
volvo9 is offline   Reply With Quote
Old 08-23-2004, 07:32 PM   #23
2ptslow
2ptslow's Avatar
looks good, nice oil trail under the car tho time for some degreaser
Dress Italian, Kiss French, Drive German
2ptslow is offline   Reply With Quote
Old 08-23-2004, 10:55 PM   #24
Turborg
Turborg's Avatar
Default Cost for T-5 conversion
I just posted what my conversion cost. It included a rebuilt B23FT but the trans conversion cost is broken down.http://forums.turbobricks.com/showthread.php?t=23646
Turborg is offline   Reply With Quote
Old 08-23-2004, 10:59 PM   #25
Hank Scorpio
Thats active rust prevention.
