Old 05-06-2011, 03:43 PM   #1
camelwideswagon
camelwideswagon's Avatar
Default shorter timing belt specs.
got a head that has had some shaved off. I need to find a FORD PINTO (engine type) timing belt. what are the specs on the belts people are using?
would this belt work?
http://www.oreillyauto.com/site/c/de...0074&ppt=C0007
I have searched but no one has a direct link to a shorter timing belt they are using. any info would be much appreciated!
edit' F! volvo b230f uses a 3/4" x 46 1/8" (123 Teeth) belt.
i cant find a 122 teeth belt! please much help with a link would be appreciated.
jerk.
camelwideswagon is offline   Reply With Quote
Old 05-06-2011, 03:53 PM   #2
towerymt
the real Towery
towerymt's Avatar
How much was taken off? At around 2mm+, you may need a shorter belt, but less than that should be fine with a stock length belt.
You could also contact Lawrence Knox (aka 'Fidel') and ask if he has one available.
Old 05-06-2011, 04:03 PM   #3
Poik
Backwards Turbo
Poik's Avatar
https://www.rockauto.com/dbphp/mfr,G...16,Timing+Belt <--- invaluable link to bookmark
Scroll down, looks like the 3rd one down will work. Gates T013, T089, or T158.
Eric Olsson's 242 Turbo | 245 DL | 744 Turbo
Poik is offline   Reply With Quote
Old 04-11-2019, 01:36 PM   #4
klr142
Turbo, what?
klr142's Avatar
Bump. People were curious.
TB089 is the short round tooth belt(and MD140228 is another part number for it).
T013 is the square tooth belt short.
