Old 06-20-2011, 12:23 PM   #1
JW240
All idiot, no savant
JW240's Avatar
Default 240 electronic speedometer calibration (1986+)
Want to calibrate the speedometer of your 240? Here is how!
The speedometer is controlled by a ITT UAF2115 chip. This chip is used in many cars of the same era, including the 7/900 series.
There is a calibration resistor in the cluster that will alter the speed shown by the meter. The trip/mileage counter calibration is not affected by this resistor.
Parts needed: A normal 1/4 Watt resistor in the 56+ Ohm range, I used 61 Ohm on my 240 to calibrate it. Thin wire. Screw terminal. Solder+desolder wick.
Here ya go:
After you have removed the cluster from the dashboard and removed the speedometer unit itself you'll be greeted by this sight. Shown here is the PCB with the chip and calibration resistor and many other components. The green arrow indicates the calibration resistor.
Desolder here.
The resistor that was in this place was the calibration resistor. I used some thin wire and drilled a hole in the back of the case to mount the resistor outside of the case for easy calibration. When you drill the hole make sure that no shavings are left inside of the cluster that will cause problems later on.
The resistor is connected to pin 4 and pin 13 (ground) of the chip.
Here the resistor mounted on a screw terminal thingie. Pro tip: if you need to fix speedometer gear, its helpful if the wire for the calibration resistor can pass through the hole, its helpful of the resistors are connected via such a clamp vs crimped/soldered.
The stock resistor is about 56 Ohm. If you increase the resistance value the speedo shows less km/h or mph. On my car i replaced the resistor for 2 in parallel that are ~61 Ohm combined iirc and the results are very good. 50 km/h on the speedo is 48-49 km/h GPS and 120 km/h is 119,5 km/h GPS.
Some data found on the back of the VDO unit. K=6091 Imp/km - 437.204/002/041
Thanks to the Brickboard speedometer calibration article (for 740) and TB member blabla (BTI Volvo modifications) for reminding me of this possibility.
Extra:
ITT UAF2115 Speedometer and mileage indicator chip datasheet
You can change more stuff about how the speedometer reads and the mileage counter works, for example changing the amount of pulses needed etc (page 2, grounding/floating/connecting pin 11 etc). Can be handy for people swapping in ABS rear axles or triggering the speedometer with front axle abs tone ring etc and when swapping between 12/48/96 tooth tone ring stuff. Though I have not tried this yet.
Extra 2:
More good stuff here: http://cleanflametrap.com/speedo.html
Extra 3: Running a Truetrack with homemade trigger wheel now and the later style aluminiu diff cover, works great. Not sure how it works in stock form since I had to adjust sensor clearance anyway (Using a rubber ring or thick gasket sheet is fine).
Hope this helps
Edit 2: finally fixed the broken links. Things have been crazy here.
Last edited by JW240; 11-03-2018 at 07:34 AM.. Reason: series/parallel mixup fixed - pics fixxxered
Old 06-20-2011, 07:57 PM   #2
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
ugh, would have been nice to know before having to cut teeth and mess everything up.
much appreciated for the write up, Jan.
Old 06-21-2011, 04:47 AM   #3
Originally Posted by JW240 View Post
Can be handy for people swapping in ABS rear axles or triggering the speedo with front axle abs tone ring etc and when swapping between 12/48/96 tooth tone ring stuff.
What!? I need to read more about this!
Old 06-21-2011, 05:36 PM   #4
wow, awesome article. Will be useful at some point when i am driving a 240 again
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 06-21-2011, 06:09 PM   #5
towerymt
the real Towery
towerymt's Avatar
shouldn't be watching the speedo while autocrossing, plus my speedo works fine.
Old 06-21-2011, 10:41 PM   #6
crandandall
Turbobricks Low Life
crandandall's Avatar
You could probably use an adjustable resistor so that you could adjust the calibration on the fly. Just put some sort of 2 pin connector on one of the blank switch panels.
crandandall is offline   Reply With Quote
Old 06-22-2011, 06:52 AM   #7
Dirk242
Me too. Can you tell me more about it. Got a pair laying here.
‘81 245
Dirk242 is offline   Reply With Quote
Old 06-22-2011, 08:19 AM   #8
JW240
JW240's Avatar
Open a cluster, look at how pin 2 is connected (ground, connected to +12v or floating) and see from there. I have no idea how it is from the factory. By altering how pin 2 is connected you can alter the speed and mileage displayed/counted by a factor 4, can be enough to go from 12 to 48 tooth for example (depending on which multiplier is selected from the factory).
The front ABS tone rings probably give the same signal level as the rear axle sensor.
In theory it should work. Someone needs to test it.
Old 06-22-2011, 08:52 AM   #9
Wagner
Tbricks MIG Welding Champion
Wagner's Avatar
Hey, good info here.
You say that this has no effect on the trip or mileage meter?
That would be good news, because i've been thinking about how to use the 220 km/h speedometer face together with a 200 km/h electronic speedometer. The turbomodels had a cable driven speedo that reached to 220 km/h as standard, but i need to use an electronic speedo from a late model 240 (no speed output gear on the transmission that's being used) in my factory turbo, so in theory i might be able to use that face and the adjust the resistor value to get a correct reading.
BTW, you state that you used 2 resistors in series, but in the picture they are in parallel, are they not? Not that it matters in my case, but anyway.
Thanks for sharing. This is great.
Cops pulled me over. Papers, they said. Scissors, i replied. Still i did not win. Go figure.
Wagner is offline   Reply With Quote
Old 06-22-2011, 05:34 PM   #10
JW240
JW240's Avatar
well, if you want to use the 220 km/h speedometer face, then you probably don't need to calibrate the speedo much . 160 km/h on the speedo was 144 km/h gps on my car.
I'd like the 220 km/h speedo face as well but they are hard to come by (only seen it once) and the finish is different from the 89/90? and up matte finish.
In the datasheet of the chip they state that the calibration resistor between 4 and 13 only has effect on the galvanometer, not the stepper motor for the mileage meter. I never tested it but the trip meter seems to be the same as before I think.
I always like it when there is a simple solution with simple/stock parts for these little issues. No need for complicated stuff.
yeah good call on the series/parallel mixup, must have been late when i typed it
Old 06-23-2011, 06:03 PM   #11
volvorod85
volvorod85's Avatar
Good info, any one adapt an electronic speedo to an early (pre 81) cable driven instrument cluster? Ive got a 79 dash in my 86 240 truck with an M46 from a 700, no speedo gear, but ive still got the speedo sensor wiring in the car. I can get an OD with a cable output, but i dont wanna, lol
Mark
1995 E320 wagon AMG 3.6 swap <-- Daily driver
2009 Honda Fit <-- Wifeys ride
1959 Austin Healey Sprite <--something completely different (my project)
1974 Fiat X1/9 <--Mom's little toy (next project)
1982 Olds Custom Cruiser LQ4 <--Dad's beast (current project)
"Driving the old 2 valve 740 is a bit like driving an IKEA wall unit, so leisurely is its acceleration, so angular its lines."
My former brick saved my life 6/25/03....Volvo for Life
volvorod85 is offline   Reply With Quote
Old 06-11-2012, 06:15 PM   #12
M.H. Yount
M.H. Yount's Avatar
Old thread -- perhaps we can revive. Is there a late model 120 mph electric speedo that I can transplant into my '82 cluster to replace the cable driven unit?
JW240 - a few things; go slow with me and talk like I'm a second grader. The unit in the first 2 pictures above looks entirely different from the unit you actually worked on. What am I missing there? Which one is an electronic speedo for a 240? Also, in your written comments you say you hooked up 2 resistors in series; but from the picture (with the 'screw terminal thingie') 2 resistors appear to be hooked up in parallel. Do my eyes deceive me? Last - is there another resistor that can be used to adjust the odometer accuracy? Is there a way to alter the odometer reading? I need to ADD miles to mine; when the 85 mph speedo it came with was swapped with a 120 mph unit -- the new speedo had about 48,000 fewer miles than the original. Us Volvo owners are proud of our high miles....
The good news about this is if it will work, I can hook the whole thing up temporarily in the car while I'm driving, calibrating, checking against GPS, etc. And once I get it right - then I can transplant into the cluster.
Old 06-11-2012, 11:01 PM   #13
turbojose
love the info... great work.
turbojose is offline   Reply With Quote
Old 06-12-2012, 06:12 PM   #14
JW240
JW240's Avatar
Thanks!
You are right about the series/parallel mixup, fixed that.
Not sure if i understand you correctly but the unit in the first 2 pics is the speedo unit itself, pulled from the cluster. You can slightly see the face plate too. The 3rd and 4th pic are taken with the cluster assembled again of course.
I do not know of a way to affect odometer reading with this chip, but it has been a long time since i have read the datasheet. Maybe.
Setting the odo higher with the speedo unit removed from the cluster can be done quite easily, the dials-numbers can be rotated if you are careful. At least, thats what i´ve done to some speedo´s that i took apart.
One thing i realized after looking at the pics is that a small piece of shrink wrap to cover the resistor(s) isnt a bad idea, the exposed wire could make a short if the screw terminal thingie accidentally comes loose from the cluster.
Old 06-12-2012, 07:30 PM   #15
M.H. Yount
M.H. Yount's Avatar
Thanks JW -- we'll see where I end up!
Old 06-09-2017, 03:13 PM   #16
Laffy
Planning to do this, do you happen to still have the pictures? Atleast the one that points out the right resistor do change.
Laffy is offline   Reply With Quote
Old 06-10-2017, 07:53 AM   #17
JW240
JW240's Avatar
I still have them, need to re-host.
But wont have acces to the pics this week. Maybe Art's site can help you with the chip pinout, you can trace it. In a few weeks i can have the pics up again.
Old 06-14-2017, 07:23 AM   #18
Laffy
Would be perfect if you could rehost those pictures. Would really make my life easier!
Old 07-03-2017, 02:46 PM   #19
Laffy
Would it be possible to upload the pics this week?
Old 12-23-2017, 01:19 AM   #20
jjona5
My car currently shows 40mph when I'm going 48. I would love to have this live!
jjona5 is offline   Reply With Quote
Old 12-23-2017, 02:25 PM   #21
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
I did this on a previous 240, as I recall it’s as simple as finding the 50 ohm resistor, and replacing it with a 100 ohm micro potentiometer set to 50 ohms, then adjusting it so the speedo matched my GOS app.
I glued the pot behind the plug for the clock adjust stalk hole, and can adjust mine without removing the cluster.
I used something like this, multi turn trim pot.
https://www.frys.com/product/5976914...H:MAIN_RSLT_PG
1980 242 Turbo
2004 V70R
Old 12-27-2017, 10:01 AM   #22
MikeSr.
What, me worry?
MikeSr.'s Avatar
Michael- did you ever get the late model speedo in the old cluster? I am facing this with my ‘81 240.
The other choice would be to swap the whole cluster from a late model. Has anyone done this?
I coulda had a V8!
MikeSr. is online now   Reply With Quote
Old 12-28-2017, 09:07 PM   #23
Forg
Forg's Avatar
I’ve got an ‘87 cluster in my 242GT with ‘81 dash. Got sick of the cable speedo actuation after 3 different cables all failed to be the right length (Supra 5spd conversion). It works using a Toyota mechanical-to-pulse adapter which came off something Japanese & obscure, and an aftermarket adjustable pulse-counting-and-conversion kit (speedo “tuned” off ‘phone & SatNav GPS ).
With the ‘81 cluster it works fine, with the ‘87 cluster there’s some cross-wiring which I haven’t been arsed hunting-down. The “Acc” setting for the (new) switch (replaced the switch with brand-new one before it occurred to me the problem could be incompatibility between clusters) has the effect of the “On” setting, so I basically don’t have an Accessories setting.
Apart from that, the majority of it just plugged in, including at least the two big whacky-shaped plugs. Speedo plug is obviously custom though, that won’t be plug-and-play. The car drives fine, and everything works as expected for the “On” ignition-switch setting.
When I'm cruisin' in overdrive ...
Don't have to listen to no run-of-the-mill talk jive.
Shatner: The Colonel is breakdancing ... gimme a break!!
Rollins: Credit terms raised!
Shatner: I can't get behind any of that!
Shatner: I can't get behind so-called singers that can't carry a tune, get paid for talking, how easy is that? Well, maybe I could get behind that ...
Rollins: Well, I can't!!
Forg is offline   Reply With Quote
Old 01-23-2018, 04:36 PM   #24
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
Anyway to get the pictures to work? About to embark on this task on the Wife's cluster.
-Stephen
#mclovethesenuts
-My car: White 1991 244, 330k miles. B230F LH2.4, AW70, R134a retro
-Wife's car: White 1990 244DL, T cam, 200k miles.B230F LH2.4, AW70 w/aux cooler, Virgos, tow hitch
-PSM 2002 Subaru WRX wagon: EJ205, 5MT, 120k miles, Perrin TBE
-1997 Subaru Legacy Brighton: EJ22, 5MT, 236k miles
Old 01-25-2018, 12:43 PM   #25
seads505
seads505's Avatar
Would be very interested in seeing these pics. Thanks so much for doing this write-up!
seads505 is offline   Reply With Quote
