Old 07-18-2011, 04:11 AM   #1
Koston740
Koston740's Avatar
Default catch can contents
emptied my catch can a few hours ago ... what I found inside was a thin oily black substance that smelled of fuel. I am running an experimental vent tube from the block from under the intake manifold to vent off some excessive blowby. This is about three weeks worth. plus a 7 or 8 hour trip last week.
I dont really know if this is normal bad or good for this kind of catch can setup.
90 745 w/ b230ft- Holset He351cw, TLAO chips, eBay ic, Delphi 65's, bmw oil squirters, spec stage 2+ clutch, t5 WC E85
Feedback thread:
http://forums.turbobricks.com/showthread.php?t=236339
Koston740 is offline   Reply With Quote
Old 07-18-2011, 04:13 AM   #2
Koston740
Koston740's Avatar
Not much oil, it seemed pretty thin ...
Big thanks to everyone! I appreciate any answers/comments.
Old 07-18-2011, 04:20 AM   #3
Mylesofsmyles
i dunno if that's a lot or a little...looks like a lot to me.
Does your catch vent to atmosphere or recirculate?
Old 07-18-2011, 04:37 AM   #4
Koston740
Koston740's Avatar
recirculate, so i have negative pressure, keep in mind that there is no baffel system or anything to prevent oil from flying from the hole on the block of place under the intake,
I dont see why its so black, just did an oil change not tooo long ago.
Like I said its watery and smells like fuel, if that means anything.
Old 07-18-2011, 04:38 AM   #5
Koston740
Koston740's Avatar
Old 07-18-2011, 06:32 AM   #6
M.H. Yount
M.H. Yount's Avatar
If cylinder seal is relatively good (not much blow-by) and your system for trapping oil BEFORE the can is good, then your catch can is going to capture primarily condensate that gets boiled off. It appears as a thin black fluid that smells of hydrocarbons. You won't capture as much in the summer as you will in the winter. Sounds like yours is working just fine to me.
Old 07-18-2011, 06:32 AM   #7
M.H. Yount
M.H. Yount's Avatar
double post
Old 07-18-2011, 08:28 AM   #8
lookforjoe
lookforjoe's Avatar
That's still a fair amount of oil content. Oil & water don't mix, so you would see water with oil layer on top if it were just condensate
As pointed out, this particular content is seen primarily in colder weather.
As long as you're checking it frequently enough, there's no reason it should be an issue, although a baffled setup is obviously preferable in terms of keeping more of the oil in the motor.
My XR July2013 - 446AWHP @ 8K rpm Feedback Thread
Old 07-18-2011, 08:28 AM   #9
lookforjoe
lookforjoe's Avatar
Old 07-18-2011, 04:15 PM   #10
M.H. Yount
M.H. Yount's Avatar
What is with the TB system and all the double posts? I know I'm only hitting the button once....
If you gently pour some oil and water together - yes, you get a delineation of water on the bottom and oil on top. But the way condensate and hydrocarbons of various sorts get 'mixed' in the crankcase (pretty violent environment) it's like putting everything in a 300HP blender. So what starts as condensed water in the crankcase ends up looking like a thin dark fluid that smells like hydrocarbons.
Old 07-18-2011, 06:10 PM   #11
adrianpike
adrianpike's Avatar
Yeah, that's a lot more oil than I see in mine too.
I'm looking to buy, PM me if you've got any of it: LS bits, 93 850 bumper, ford 8.8", T5 WC, T56, Mustang IRS
Adrian is omniscient, you will never escape his wrath. - 500dollar744ti
doug was here
adrianpike is offline   Reply With Quote
Old 07-18-2011, 06:15 PM   #12
cookiemonster
cookiemonster's Avatar
OT question, ive been running a catch can for about a month now and there isn't even a layer of oil on the bottom, just a hazing of oil on the inside. Is something wrong with that? Btw it vents to the atmosphere!
2001 f250 powerstroke, 535hp 715tq
1983 c30 dually, 350/350 6/8 drop
91 240, m47, ipd springs, sweet cone filter!
cookiemonster is offline   Reply With Quote
Old 07-18-2011, 10:25 PM   #13
lookforjoe
lookforjoe's Avatar
They separate again in the catch can. I guess I should have said oil & water don't stay mixed. That's what my photo is of. His is more oil, less water.
Old 07-18-2011, 10:29 PM   #14
lookforjoe
lookforjoe's Avatar
Where does your vent tube terminate? Where are you venting? Is there oil spray evident after it terminates? No reason to see any oil accumulation if the system is doing it's job. You won't see condensate until the weather changes.
Old 07-18-2011, 10:52 PM   #15
Koston740
Koston740's Avatar
jake, keep in mind my system is venting directly from the block. that's why it fills generally quick.
Old 10-24-2011, 12:26 AM   #16
Sean
Junkyard dawg
Sean's Avatar
It sounds like your system would collect a lot of oil/fuel due to it's installation on the bottom of the plenum. (assuming this is what you mean)
3 weeks.... if you're driving 3-5k in 3 weeks that is fine, if you're driving 200 miles in 3 weeks that's bad...
Sean is offline   Reply With Quote
Old 10-24-2011, 12:37 AM   #17
towerymt
the real Towery
towerymt's Avatar
looks to be sucking oil out of the engine. probably need a better oil separator prior to the catch can
Old 10-24-2011, 01:43 AM   #18
Koston740
Koston740's Avatar
I may just remove the extra vent tube all together. after installing it oil still seeps out of the oil cap and cam seal. But i'm sure it does provide some extra ventilation so its not really that much of an inconvenience.
Towermt I thought about using one of those water oil separation used on air compressors. But the oil seems to be staying in the can and not really causing any issues or anything. What are you using?
Old 10-24-2011, 01:46 AM   #19
Koston740
Koston740's Avatar
try running a tube from the can back to intake after the AMM, You still need positive crankcase ventilation with a catch can, it might catch more oil then.
Old 10-24-2011, 09:32 AM   #20
Canuckvolvo
Drunk as ****
Canuckvolvo's Avatar
How's your oil pressure? Could be your oil is getting contaminated by fuel (either running rich, or bad rings or valve guides). When my B21FT was in its final days the oil would go black and smell like fuel, and hot pressure would go from 4bar to ~2 after only a few days.
Currently Volvo-less
Canuckvolvo is offline   Reply With Quote
Old 10-24-2011, 10:13 AM   #21
towerymt
the real Towery
towerymt's Avatar
Probably some blowby giving the fuel smell.
I run a hose off the breather box into a catch can. Can is vented to atmosphere, no hose to the pre-turbo hose. I get plenty of oil in the can because of blowby. If I pulled vacuum on the can, I'd have even more oil in there.
Old 10-24-2011, 05:01 PM   #22
g0ldie
Post some pics. I want to know exactly what you have done to vent it.
I also have though of other ways to vent the crankcase instead of the fire trap mess.
g0ldie is offline   Reply With Quote
Old 10-24-2011, 05:06 PM   #23
towerymt
the real Towery
towerymt's Avatar
bought a catch can with a filter on the top...done
http://www.pbase.com/towerymt/image/111755776.jpg
one hose connects to the breather box on the block, another connects to the b18 oil cap. can is baffled.
Old 10-24-2011, 08:08 PM   #24
kahluaTDI
kahluaTDI's Avatar
I've got one of those A/C catches jbwelded shut. It works well and is only 20 bucks. So long as you put something in it to allow the vapor to settle out, anything you run will be fine.
.Signature.
kahluaTDI is offline   Reply With Quote
Old 10-25-2011, 01:23 AM   #25
g0ldie
Does this eliminate the need for the flame trap.
I cleaned my throttle body/intake manifold last weekend and it was full of oil vapor sludge from the crankcase.
I basically want to remove everything from the engine that I don't really need. I'm not worried about emissions.
