Old 08-19-2011, 04:08 PM   #1
BryantTF242
BryantTF242's Avatar
Default 1982 volvo 242 GLT turbo boost?
Hey, so i have an 82 242 turbo, i was wondering if any of you guys knew how much boost these things run stock? i only got the colored black-orange-red boost gauge so it doesn't say how much psi it runs haha.
BryantTF242 is offline   Reply With Quote
Old 08-19-2011, 05:18 PM   #2
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
5-7 lbs
'91 744t...it's fast as phuck
Old 08-19-2011, 05:27 PM   #3
6 stock
10 with the IBS kit.
Old 08-19-2011, 05:30 PM   #4
Wilford Brimley
LOCAL ONLY
I was close!
EDIT: Ken, there is something wrong with your monitor...its made of paper.
Old 08-19-2011, 05:58 PM   #5
Coupe' de Grace
Slowest in the West™
Coupe' de Grace's Avatar
non-i car = 5.5-6lb
intercooled = 7.5-8.5psi
intercooled with Turbo+ = 10.5psi above 3800rpm for 10sec or so duration
ken thanks for posting the published baseline 1/4 mile time also, nice to have the realitycheck in place!!
V A F
(1976 265dl/b27/m46 killed in battle, 1991)
(1976 265dl/b27/bw55 bring out ye dead, 2000)
(1980 262c/b28/m46 trebuchet fatality 2014)
1982 244t/b21ft/aw71 'Vicious Chicken of Bristol'
1989 780/b230ft/aw71 'Brave Sir Robin'
Coupe' de Grace is offline   Reply With Quote
Old 08-19-2011, 07:50 PM   #6
fcpgroton
fcpgroton's Avatar
But keep in mind that in 1982, that was not bad for a DD.
@OP: If I were you, I would make my own FMIC kit and up the boost with a MBC. That would be the best bang for the buck.
FCP Online Support Team
FCP Euro - European Car Parts Specialists
FCP Import - Import Replacement Car Parts
fcpgroton is offline   Reply With Quote
Old 08-20-2011, 01:36 AM   #7
BryantTF242
great thanks for the info! i was lookng to replacing the old turbo and replacing it with something a little better, i found a good price on a GT35 T3 Turbo Charger. heres some specs
Air Inlet: 4"
Compressed Air Outlet: 2.5"
Bearing: Journal Bearing
Turbine Housing Flange: Standard T3
Exhaust Outlet: 4-bolt, 3" OD
HP: 300~500 WHP
Cooling: Oil and Water Cooled
Working Pressure : 6-25 PSI
Compressor: .70 A/R
Turbine: .63 A/R
Compressor Wheel: 61.3 /82 mm
Turbine Wheel: 62 /67.8 mm
if its adjustable i would run it around stock boost psi, i just want something that doesn't have 200,000 miles on it and spins a little more efficiently?
Old 08-20-2011, 01:42 AM   #8
BryantTF242
there is a few others i have been looking into, it would be ok to get new equipment and run it at stock psi right?
Old 08-20-2011, 09:14 AM   #9
Juggernot
Taking myself seriously.
Juggernot's Avatar
There can be a little more to it than just bolting on a new turbo. That said, if your stock turbo isn't burning oil or making noise, and your engine isn't either, you can get a bit more boost out of the stock turbo. You should make sure you have a good "stage 0", or, that worn tune up type parts are replaced. Search this site for stage 0, and also check out peoples different builds. There are answers to all your questions on this site because most have been there, done that.
Or, citing your original post, if you want to know your boost levels while driving, boost gauges are $20 - $30 at the local parts store.
Eric
94 945t
92 F-250 7.3L Intl. Diesel+t
Originally Posted by pball72008 View Post
I am now unsubscribing from my own thread now, because honestly you annoy me.
Originally Posted by turbowagon View Post
This could proble be something so sample that it just is confusing to my head.
and if you're not familiar with outset how do you start?
Juggernot is offline   Reply With Quote
Old 08-20-2011, 02:15 PM   #10
24DinCT
Don Juan De La Nooch
24DinCT's Avatar
Air Inlet: 4"
HP: 300~500 WHP
Compressor: .70 A/R
Turbine: .63 A/R
boost is always adjustable one way or another. t's only a $20 boost controller. However a max of @10.5psi with a stock Garrett turbo for that year car (.42 AR IN/.63 AR EX) is going to flow a lot less air than your new turbo at that SAME 10.5psi (.70 AR IN/.63 AR EX).
Given that they have the same side exhaust...it should spool about the same...but not as fast as a ball bearing 35R.
Yes...and No. For arbitrary purposes...you could be making 150WHP now on the stock turbo setup at 10psi and just by bolting on a new snail...at that same 10 psi...you could be pushing 300WHP. You can probably make the same 150WHP with the new 35 snail at 5 psi compared to the stock 10psi...but you'd be out of the turbo's efficiency range. It IS possible...however...can your almost 30 year old engine, with 200K on the clock, HANDLE 300WHP???? Does your stock fuel system have the capability for 300? Your clutch? M46???
You should be looking at the proper turbo for your application and needs.
Theoretically...you CAN make it happen...there are tricks...
But simply trying to bolt up that big new snail with that huge compressor housing and a 3 inch/4 bolt DP outlet...is going to make it "harder" to put in. You're going to most likely have to make a new DP and match it up to the existing exhaust...get couplers/reducers/adapters for the stock 2 inch IC piping to go into that 4 inch inlet....ETC
See the bold...
If you're not looking for 300-500HP worth of snail...
No sense in buying it. You could definitely get away with going with a smaller basic t3/t4 with an approximate 50 trim should do the trick just fine...and get the same job done without as much modification needed to just make the damn thing fit....nevertheless all the other mods you'd have to do to make that 35 you're looking at actually run well on your 242.
83 244 DL+Ti---Being parted
82 242 TI project---bare bones, shaved, and tucked...never gettin done
Originally Posted by blackbrick82 View Post
It's all about the beer.
Originally Posted by blkaplan View Post
how come everytime i in the kitchen, you in the kitchen, in the god damn refridgerator
Buy my partz...here
Feedback...here
24DinCT is offline   Reply With Quote
Old 08-20-2011, 09:09 PM   #11
BryantTF242
awesome, thanks for all the info, yeah ill have to do some more research, im very familiar with N/A and all that good stuff, but still a little new to turbo cars.
Old 08-21-2011, 02:43 AM   #12
http://www.k-jet.org/files/installat...structions.pdf
