Old 08-21-2011, 09:15 PM   #1
beepee
how hard can it be?
beepee's Avatar
Thumbs up beepee's 1990 740 'SE', Leakzilla, AKA The Emulsifier
11/30/2014 - Finished prototyping my wasted spark tachometer driver circuit.
10/14/2014 - If you ain't leakin, you ain't nothin.
EDIT: fixed. taking car to work tomorrow so it will surely fail.
10/10/2014 - It only took a year.
11/24/2013 - Proudly still doing things the wrong way.
UPDATE 9/24/2012 frankenmotor lives
Bearings? What bearings?
Matt working in the clean assembly area re-ringing pistons...
Oh god, there's actually work involved?
It looks so much better out of the car...
T5 in place, GOT WOOD (it was the solution to keep it from pissing fluid when we put it in)
Speaking of... putting it in. Heh.
And, a little bit later...
And then it ran! No video because my phone was being retarded. But it sounds MUCH better.
Also, for those of you who haven't had the pleasure... the underside of The Emulsifier:
UPDATE 9/20/2012 melt pistons erry day!
[/QUOTE]
nerd despair
hone fail
Older (in reverse chronological order):
megasquirt!!
LH2.4 at infiniboost:
goofing off on my way home
turbo oil feed test
goofing off
car runs
Backstory:
In early 2011 I was rocking a 15g, an IPD cam, a heavily-tweaked LH2.4, and some other bits and pieces. When it was time to finally lay down some numbers, this happened:
Which meant this had to happen:
Of course, I didn't do it alone. MrBill here, hard at work, phoning his girlfriend, while Towery investigates...
..and decides to check fitment:
Went to good ol' Crazy Rays and yanked this outta a 940, (squirter ), shown here post-pressure wash
Pulled the head off and got jiggy with the block...
...while the head got jiggy with some heavy machinery.
Got a little OCD with the wirewheel...
Meanwhile, parts were arriving... 55lbs, w 4/bar FPR
Holset HY35 with a HE351 hotside:
Bad-ass header from TLOA...
Eventually, things started coming together:
I soon realized I had created a plumbing/fitment nightmare:
So I took it all apart again and spent a bunch of money on spray enamel, not solving anything but making me feel better:c
Finally, I got cheeky one weekend and decided to, well... put it in.
I had help, but once it was on the mounts they were at a loss as to what happened next...
Eventually the trans went in along with a million wires, nuts and bolts, hoses, clamps, zip-ties, bailing wire, twine and miles of duct tape.
And it ran! (see videos above)
That's it for now. Watch this space...
beepee is offline   Reply With Quote
Old 08-21-2011, 09:38 PM   #2
thelostartof
unbalanced chemical
thelostartof's Avatar
So wait, the manifold clears the a/c?
Sure hope to heck it works out for you.
Old 08-21-2011, 09:39 PM   #3
TJcars2
TJcars2's Avatar
Where's the like button??
Function ≥ Form
JRT Performance Like it please!
Legend Build The Useless Four Door
My Youtube Account
TJcars2 is offline   Reply With Quote
Old 08-21-2011, 09:50 PM   #4
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
excellent, now make it work! Is the comp. outlet going to go downwards as such?
Old 08-21-2011, 10:10 PM   #5
boosted_nonv
Ball bearing FTW
91 740 Turbo project begins now
GeckoSquad Member
boosted_nonv is offline   Reply With Quote
Old 08-21-2011, 10:18 PM   #6
llama
llama's Avatar
hell yeah, been waiting for that ever since our trans bolt adventure.
Doing mysterious things with mysterious people
Originally Posted by m46destroyer View Post
Fuel distributor, may God have mercy on your soul.
llama is offline   Reply With Quote
Old 08-21-2011, 10:30 PM   #7
maxman142001
I like turtles
maxman142001's Avatar
awesome
as nothing is impossible with God, even turbo's fixing themselves
-2011 VW GTi
maxman142001 is offline   Reply With Quote
Old 08-21-2011, 11:09 PM   #8
beepee
how hard can it be?
beepee's Avatar
it sort of clears. one of the lines is sitting pretty firmly against the angle pipe leaving the hotside, but it will clear with some strategic bending. what did you do to keep your plug wires from melting? custom wires with heat socks? pretty sure im gonna go that route.
just sorted out my oil and water leaks. had to redo the fittings on the external oil cooler thermostat. trans cooler lines still leaking but that's an easy fix.
waiting for some piping to come in so it can actually be turbo. the compressor outlet, aside from being in an awful place, uses a v-band.
but there is such a clusterf*** of stuff around the turbo it is gonna take some serious engineering (read: zip ties, jb weld, and pvc pipe) to get the compressor outlet talking to the I/C inlet.
but, it's a WIP.
Old 08-21-2011, 11:12 PM   #9
thelostartof
unbalanced chemical
I just used high temp boots/socks over the plug wires, no issues for the year I had it like that.
The outlet worked just fine if you used the Late model hy35cw.
Being that I did not have a/c in my car nice to see that it almost clears.
Old 08-21-2011, 11:45 PM   #10
towerymt
the real Towery
towerymt's Avatar
protip: don't cut the engine off at 5k.
my ball bearing turbo spins longer than that when shut off at idle
sounds/looks good, broseph. can't believe the two cars that are going to SE from this area...
1987 244 | Project Thread | The 87 | Now with 74 mods and counting
1992 244 | The 92
244s are drop dead ugly and suck.
Old 08-22-2011, 12:13 AM   #11
Bitchin'.
Old 08-22-2011, 09:51 AM   #12
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
what's with the shriek coming from the turbo? sure the oil feed is feeding? you run it into a cup before hooking it up to the turbo to flush any trash out?
Megasquirt Tuning!
Old 08-22-2011, 12:45 PM   #13
MrBill
fige=500Dollar Mistake
MrBill's Avatar
Originally Posted by boosted_nonv View Post
Ball bearing FTW
Yeah I think it's journal bearing
we bad.
Uh oh. I mentioned it friday but we forgot.
Edit: He still has the little piece in the compressor intake that's held in with a snap ring. Maybe it makes the noise?
I took mine out
Someone say crazy rays?
Old 08-22-2011, 12:48 PM   #14
beepee
how hard can it be?
beepee's Avatar
pretty sure it's feeding. Originally I intended to do the whole "prime it into a cup" thing but I didn't think about it at the time.... and I guess MrBill secretly wants my car to explode
it sure as hell feeds the other 9 miles of oil cooler/remote filter nonsense I have going on. The feed line got hot... and it spins (by hand) much more freely than it did before the oil system was primed (by cranking and cranking and cranking and cranking and....)
oil pressure light behaves normally, but i know that doesn't mean a lot. the oil lines are all new braided stuff now that you've got me paranoid, i'll check tonight.
Of course, the turbo IS freewheeling right now (nothing attached to the compressor) so that may be why it's LOUD. I know you can overspeed it like that which is why I've not beat on the car or anything yet.
Old 08-22-2011, 02:18 PM   #15
towerymt
the real Towery
towerymt's Avatar
sounded a little like the t3 keysar gave me. i put it on my car, drove it around the block, and it started POURING smoke out the exhaust. it sounded like a supercharger whine for .1mi.
I'm sure it's fine, though.
Old 08-22-2011, 02:25 PM   #16
linuxman51
linuxman51's Avatar
meh, it's just a holset and you're rolling in dough anyway with the new job. bet you'll run it into a cup next time though if it's shot ;)
Old 08-22-2011, 02:35 PM   #17
beepee
how hard can it be?
beepee's Avatar
op updated.
Old 08-22-2011, 02:45 PM   #18
linuxman51
linuxman51's Avatar
fyi, purging the feed does a couple of things.. it lets you know you've got oil going to the turbo (and thus some degree of oil pressure), and it gets any crap that was in the line out.. the latter more than the former, but if it's not working then well you'll realize there's a feed issue before stuff melts down.
Old 08-22-2011, 03:47 PM   #19
MrBill
MrBill's Avatar
Well bryan, time to use that warranty you talked about
Old 08-22-2011, 04:22 PM   #20
beepee
how hard can it be?
beepee's Avatar
see, these are things I know, however it wasn't necessary because [insert excuse] and
I did run compressed air through all of the oil orifices and then shop vac them out thoroughly, including the AN lines. Really shouldn't be anything in there. Regardless, I'm checking it first thing when I get home. I knew I wasn't done getting covered in oil.
Also gonna buy a bunch of -6an hose to replace those trans cooler hard lines and hopefully run them somewhere less intrusive.
anyone have tips for reducing the footprint of the power steering pump/hoses? don't say "remove it", 'cause I refuse.
Still gotta get the rest of the exhaust swapped out, figure out the correct way to do the shifter linkage, reconnect the OD solenoid, and all the other stuff that got skipped.
shopping list:
- 20" 6an hose
- sandwich plate oil cooler
- thru-radiator zip ties
- ? turbo??
- smaller belt for PS/water pump
Old 08-22-2011, 04:23 PM   #21
linuxman51
linuxman51's Avatar
move the ps pump to the driver's side, get an electric alternator.
Old 08-22-2011, 04:26 PM   #22
beepee
how hard can it be?
beepee's Avatar
i was gonna go for a bicycle-style alternator on the front driver's side tire but i like your solution more.
Old 08-22-2011, 05:05 PM   #23
towerymt
the real Towery
towerymt's Avatar
...an electric alternator.
huh? aren't they all?
get an electric power steering pump, keep alt and a/c on the intake side as-is.
i think that counts as a generator.
if you come over a rise at night and your headlights are REALLY bright, the cop is going to pull you over.
Old 08-22-2011, 05:39 PM   #24
Karl Buchka
You have a car? I thought you just sat in the basement and played with LH all day.
Old 08-22-2011, 08:01 PM   #25
gdogg16
You're a Subtotal
gdogg16's Avatar
Sounds awesome BP.
Greg
'66 Locort
'72 Fulvia 1600HF Lusso
'74 142
'83 911SC
'99 2500 Ram
'13 TDI Sportwagen
'15 TDI Sportwagen
gdogg16 is offline   Reply With Quote
