Old 08-26-2011, 06:36 PM   #1
940 16 valve
940 16 valve's Avatar
Default My 940 16 Valve, finally turbo'd!
So I suppose now that I've got the car running, I'll cross post my thread that I originally had on the Calgary Volvo club website.
Been wanting to turbo it for about 6 years now, and have been saving up parts since. I've decided to pull the trigger and just turbo the stock b234 in my 940, see how it goes, and either keep on with that for a while, or if I run into any problems, I have a low-ish mileage 90' b230f on an engine stand, and some brand new b230ft pistons with valve reliefs waiting.
A little history on the car... It's a 1991 940 gle. I remember going to the dealership with my dad when I was about 4 to pick this car up. There's a lot of memories in it, and it's been my baby for the last 7 years that I've owned it. I always loved it though..I was the one that talked my dad out of trading it in when they bought a second car when I was 14! Thank god I did that.
A few years back the auto tranny went, so it got swapped over to a m46 (thank to Rojer for his help there). About a year later I was tired of always filling up the leaky m46, and it didn't shift very nicely, so I did a ford t5 swap. (thanks to Dale and matt for the kit, and the guidance). Also did wilwoods in the front, pretty sure that was prior to the t5 swap.
So the plan of action now:
-stock b234, ~350k kms.
-15g turbo
-90+ manifold with yoshifab adaptor
-sealed power valve springs
-fred's 16 valve chips
-Possibly install the saab apc I found a few weeks ago if all goes well.
I figure I may as well turbo this old engine that doesn't owe me anything, and any lessons I have to learn, can be learnt on an engine that is basically expendable. If it runs well, I'll have some fun with it, if something goes wrong, I'll take it as a sign that it's time to do it with proper low compression pistons, and possibly megasquirt.
I installed a 92+ intercooler that I had a few weeks ago. Pictures are here:
http://forums.turbobricks.com/showthread.php?t=239793
Step 1: Me and my buddies pulled the head to drill out some broken exhaust studs (probably going to get helicoiled), and to put a new headgasket in for posterity's sake (I'm sure it's about due to go at 350K). While I'm in there, I'll be putting in new valvesprings. As it sits now, the head is at the machine shop getting hot tanked and skimmed. In the meantime I'm going to be doing odds and ends getting everything ready for when the head comes back Monday/Tuesday.
Keeping all the valves/buckets/seats sorted. I figured the trunk was a safe place for them...
Boxes of parts removed/turbo parts (manifold/intercooler pipes/oil cooler stuff)
And the best part, 15g with new oil seals, chips, valvesprings, and exhaust adaptor!
Well started up the car today. No leaks or anything which is great! No exhaust hooked up yet, just the downpipe, so it's insanely loud! turbo's attached, but I don't have it hooked up to the intercooler yet. Hopefully have the exhaust and intercooler plumbed in in the next few days, and I can take it for a spin!
Basically what's happened in the last couple of weeks.
-Head hot-tanked, sealed power valvesprings installed, new valve stem seals, and headgasket.
-Battery relocated to passenger side to make room for air filter (and fixed the rust that was under the battery)
-turbo installed, oil feed and drain plumbed in
-turbo chips installed
-new oil pump gear, timing belt, and newer waterpump (had a spare low mileage one)
I highly recommend getting the updated oil pump gear for any b234 owners. Under $80, and it beefier. My old one fell apart when I took it off to inspect it. I also recommend using the old timing belt to hold the pulley, rather than the allen key method posted online. I have my suspicions that that didn't help the old gear out any. Anyways, here's a comparison showing how much beefier the new one is (you can see the extra meat around the bolt hole)
The carnage
Threw the chips in!
Lookin good!
A fair bit of progess has been made since that last photo. I'll post up some more recent pics in a bit.
1991 940 - stock b234+t -retired http://forums.turbobricks.com/showthread.php?t=243308
1989 760 - T5 +T5 swapped http://forums.turbobricks.com/showthread.php?t=341191
Last edited by 940 16 valve; 04-13-2018 at 07:29 PM.. Reason: Broken photobucket links, imgur much better!
940 16 valve is offline   Reply With Quote
Old 08-26-2011, 06:41 PM   #2
WindowsBreakerG4
ALDORF THE DESTROYER OF WHITE SHIRTS
WindowsBreakerG4's Avatar
Looks like a nice build! I'm going to tell you right now, that 15g is going to be too small. Might consider making it a 19t.
Basically the 15g is going to run out of steam really fast.
Other than that, looks like a nice build!
ovlover: Its an auto. Problem found, Manual swap. Problem solved
Originally Posted by cosbySweater View Post
She was pretty damn hot. And she folded my clothes and made me breakfast in bed
Towery wants to get me drunk but doug already is. Don't trust a drunk Towery he will slip you the old stiff one eye
I AM ALDORF THE DESTROYER
1985 744ti M46 -3rd, 15g, 3" exhaust, Ported Head, 333,333 miles
91 945 Turbo 3 pedal auto, DD
83 242 Turbo Flathood
15 Golf TDI 6 Speed
Doug <3 me. Not scottyd. doug was here again
WindowsBreakerG4 is offline   Reply With Quote
Old 08-26-2011, 06:51 PM   #3
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
I had the same thought about the 15g
Old 08-26-2011, 09:38 PM   #4
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
Build looks good...Ill agree on the Turbo. I had a Evo3 16g on mine at first. Way restrictive and EGT went through the roof. Any throttle input at cruise results in boost. I like running a larger turbo, keeps fuel mileage in check!
962j 815/692@27psi
THIS IS FORSALE V
Old 08-27-2011, 11:09 AM   #5
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
one of those mitsu truck turbos!
Old 09-11-2011, 01:35 AM   #6
940 16 valve
double post
Old 09-11-2011, 01:35 AM   #7
940 16 valve
Hahaha, lots of Bigger turbo comments, good ol' turbobricks. Appreciate the replies and comments guys. I would of course like a bigger turbo at some point, but one thing at a time right? I didn't realize how easy it would get into boost though, like you say Nathan (and thanks again for the fuel rail ;), I was on the highway, and it goes into boost if you even think about touching the gas. Never gone up hills so effortlessly though!
So a little update.
Haven't driven the car in about a week and a half. It was guzzling gas like crazy, I'm assuming due to me having the smaller injectors, with the fuel pressure turned up to compensate, which probably made them leak (hopefully that theory is correct, and it's not something else). Got some 50lb/hr ones on the way, just been waiting on them. Plugs definitely suggest the car was running wayyy rich, got some replacements ready to go in too.
So since I can't have any turbo fun, I've been taking advantage of the downtime to get some less essential/fun projects done.
First, I was walking through the junkyard a couple of weeks ago, and happened to notice an 850....R! I had always wanted the R seats, but figured chances were slim I would ever find some. It was 1/3 off day too, score!
Putting manual rails on them, I bet the three motors in the lower part weigh over 10lbs. Kept the power back adjustment though.
Installed
I also always wanted somewhere less conspicuous for my radar detector, and had had this project in the back of my mind for a while.
Aaaand the car sitting waiting for the injectors...
[img]https://i.imgur.com/J8ZwMNwh.jpg/[img]
Old 09-11-2011, 01:50 AM   #8
nathaninwa
nathaninwa's Avatar
Your car looks so familiar! Glad its all workin out for ya.
Old 09-11-2011, 02:36 AM   #9
WindowsBreakerG4
The bad MPG might actually have to do with that turbo size to be honest, when chris stuck a 15g back on from the 19t his MPG went down around 5 iirc. He put an ebay turbo on and now gets close to 30.
Basically the 15g is so small it's always spooled so if you step on the gas just a little bit it hits boost. The injectors prolly aren't helping much either.
Looks good!
Old 09-11-2011, 02:37 AM   #10
WindowsBreakerG4
Looks good!
Old 10-04-2011, 11:29 PM   #11
940 16 valve
So a little update. Finally got some new injectors, s60R injectors aka "green giants." 40lb/hr which is what fred's chips called for. seems to run pretty well now when driving, just doesn't idle very well which has me confused. when I first got the turbo all hooked I started it with the stock b234 computers, and it idled great, threw in the chips and now it has a hunting idle, and it sounds a bit like it's misfiring at idle! Also sometimes bucks a little bit when you just bareeely have your foot on the throttle.
Hoping a few days of driving and the chips will adapt. My earlier theory was that it was running rich, but the proper injectors should have fixed it....
Just waiting for some free time to install the wideband and apc, and then it's time to go have some fun...hopefully
Old 10-04-2011, 11:36 PM   #12
+Kardboard+
Chinese guy/Swedish rides
+Kardboard+'s Avatar
Looking good, subscribed!
'08 XC90 V8 Big Björn|'88 245DL Uncle Sven, sold|'95 945T Darth Haul, sold|'82 242GLT B23E Lumpy the Angry Viking, sold|'77 244DL, sold|'90 744T, sold
mtd240: I suspect "the wives" have a super-secret forum to discuss whether or not they will let us buy Volvo parts.
DavidSamuels: Not a website, a panel discussion/reality show. Real Housewives of Gothenburg.
-Feedback-
+Kardboard+ is offline   Reply With Quote
Old 10-05-2011, 04:26 AM   #13
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
nice build.. wheres your FPR located ? Do you have a pic ?
Old 10-05-2011, 10:41 AM   #14
Canuckvolvo
Drunk as ****
Canuckvolvo's Avatar
Dude, bring it out for a spin this weekend! Check the CVC- Ahmad and I want to get out for sure and you need some miles on those chips!
Currently Volvo-less
Canuckvolvo is offline   Reply With Quote
Old 10-05-2011, 11:26 PM   #15
940 16 valve
Would looove to, but I only have one day off, and with recent developments it's looking unlikely. Raincheck?So it started leaking oil pretty good today, noticed a decent sized puddle that appears to be coming from the bellhousing. Did the rear main about 3 years ago, so I'm thinking maybe my pcv box needs replaced. Well that should keep me busy!
While I was under there I hooked up my wideband to get a definitive answer to why it's not running great. So it idles around 10:1! Rev it up and it still stays around 10:1. Tried turning the fuel pressure down, as low as the regulator allows, got it to 10.6:1 at best. Crap. The oxygen sensor for the ecu was all covered in soot when I pulled it to check it. Anybody heard of "fouling" an O2 by running too rich? Anyhoo, looks like I know what the issue is. I guess first step is to try a good O2 sensor and see what happens. Any input on the problem guys?
P.S. FPR is on the strut tower, the hood didn't close with it on the rail. I'll snap a pic on the weekend.
Old 10-07-2011, 04:16 AM   #16
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
That would be awesome What rail you use ? Nathans?#
/regarding you Problem...
i dont know what the problem is.. normally it should idle like crap but on the leanside cause LH tries to find the right sparkangle..
tried one of stonis 012AMM chips 3 days ago.. idled like crap for a few minutes.. sinus between 18.5 and 21~(maxscala) and then it came instanly and now idles @ constandtly 14.7 like a boss :D the first tries it went off about 25 times...
Try to disconnect the Battery again and let LH try to start from scratch try with 3bar pressure @ first... FPR should be linear so 3bar basic +- intake pressure.. pressure while idling should be 2.4 bar... depends on cam..
Old 10-07-2011, 11:47 PM   #17
940 16 valve
So as they say, 2 steps forward, 1 step back.
Figured out the running rich problem it looks like
So turns out it was my fault I guess when I pulled the O2 sensor to put it in the downpipe, I slightly crushed it (hard to see in the crappy cell phone shot). I'm guessing that was the issue. Seems to idle wayyyy better now, doesn't sound like it's misfiring, so let's hope this tank of gas lasts a Lot longer. Still wants to stall about 1 time in 10, but I'm thinking I just need to readjust the throttlebody.
So problem solved by soldering in a ford connector, so I can use a mustang O2 sensor (at 1/3 the cost!)
Might see about using the narrowband out on my wideband, but I figure one thing at a time.
So that was 2 steps forward....but then. Took it out for a spin to confirm it was running well, and my oil dipstick had shot out! Realized I still had the flame trap in there, and it looked naaasty when I took it out. So it's reassembled without the flame trap now, and seems ok. Fingers crossed that I didn't blow the rear main out, but I have a feeling I'll be pulling the tranny at some point.
I guess now I just need to write a final exam, and then I'll have some time for the wideband and APC/knocklight install, and then I won't have to hold back anymore!
Oh and crappy pic of FPR as requested..
Old 10-07-2011, 11:47 PM   #18
940 16 valve
dp
Old 10-09-2011, 05:35 PM   #19
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
thx!
and which rail are you using?
Old 10-16-2011, 04:05 PM   #20
940 16 valve
that's one of Nathan's rails. Very nice piece.
so an update on my progress. Wrote a final a few days ago, so I've finally had some time to get my wideband wired through the firewall so I can actually use it! Only thing is I'm just more confused now... The idle got way better with the new o2 sensor, but it's still not perfect, and it wants to stall sometimes.
so when I first start the car (it's been around 0C in the mornings) it starts around 11:1, but leans out closer to 14 pretty quick. Runs around 12:1 once I'm in boost (which sounds good to me).
thing bothering me is it goes to stall sometimes when coming down to idle. Goes as lean as 16 or 18:1, then comes back to around stoich(but still doesn't idle very happily). What afr are you guys finding your cars idle at?
It's got me confused how it can run well everywhere but at idle. I'm trying to think of things that I've changed since the turbo, and I'm thinking either it doesn't like my amm extension, or the ecu/chips perhaps.
any thoughts guys?
Old 10-16-2011, 04:24 PM   #21
adrianpike
adrianpike's Avatar
I find my B234 will idle hunky dory around 13-15, but it's been a while since I've checked. The cold star behavior sounds normal to me. How new are the plugs?
Cool project!
I'm looking to buy, PM me if you've got any of it: LS bits, 93 850 bumper, ford 8.8", T5 WC, T56, Mustang IRS
Adrian is omniscient, you will never escape his wrath. - 500dollar744ti
doug was here
adrianpike is offline   Reply With Quote
Old 10-16-2011, 08:39 PM   #22
940 16 valve
Thanks!
Brand new plugs, although I suppose I could have fouled them with it running so crazy rich before. I'd hope all the soot would have just burned off though
Old 10-28-2011, 06:09 PM   #23
940 16 valve
I'll let these speak for themselves...
Old 10-28-2011, 11:38 PM   #24
DNAsEqUeNcE
†John3:16
Lol!
Nice
Old 10-29-2011, 01:17 AM   #25
940 16 valve
Thanks. Now if another APC Saab ever shows up at the yard for the shielded knock sensor wiring, I can hook up the knock light above the wideband! Little by little I'm getting there.
