Old 09-04-2011, 09:20 PM   #1
B-dub
OG
B-dub's Avatar
Default The 242 Hotness of Doom
Updated: 4/19/13
This build starts with these two cars:
523whp 245
242 Group A replica
Pat (Group A) made this beauty with me when it was intended to be a GP race car and a initially a daily driver. The guy builds works of art. And now I'm going to enhance it.
Upgrades on the way marked in BLUE
The basics:
1983 242 DL
Engine:
'93 B230f Squirter motor
RSI long rods
RSI spec Weisco pistons
RSI stage V 531 head, 1 of 1 298 CFM@28" .600"lift
Header - Designed, built by, and welded at RSI World headquarters
GT3076R turbo - UPGRADE! GTX3076R should be good for another 100 whp
Twin Tial MVS 38mm v-band wastegates
Tial "Q" BOV
Full 3" mandrel exhaust
Nickle coated brass PTC fittings for all vacuum lines
Nathan in Wa Intake Manifold! (bolt on 60+whp, dyno verified)
Transmission/rearend/Wheels:
Getrag 265 - TKO when the Getrag dies
Volvo OE Hydraulic clutch Master cylinder - Wilwood master w/adapter by NIW (Shhhhh, he doesn't know yet)
Volvo OE Slave cylinder - OE GM clutch slave
RSI 13lb flywheel w/60-2 VR pickup - Yoshi CAS adapter
Custom 4puck clutch w/high pressure plate
1031 rear, welded w/3.31 gearing - Ford 8.8 limited slip 3:73 final
RPF1 17x9.5 all the way around
Nitto NT01 255/40-17 tires
Extended studs
Chassis/Suspension/brakes:
Stitch welded chassis
RSI Short Strut Coilovers
Bilstein custom valved short strut inserts
RSI Engine mounts - I love them BTW
IPD Adjustable panhard rod
IPD Adjustable torque rods
IPD 25mm sways
Complete poly suspension mounts - Kaplhenke Spherical bearings
IPD Stainless brake lines
Fuel:
Walbro 255hp intank
Bosch 044 inline - Dual 044's w/surge tank
--Both run with independent 30a relays
Stainless braided-10 supply lines -8 return
Aeromotive -10 FPR
Injector Dynamics 1000cc injectors
Electronics:
MSPro
DIYAutotune race coil packs
Custom made plug wires
Generic fuse block
Hand wired chassis
Gauges:
Speedhut gauge set
Autometer 5" tach
Autometer boost gauge
Autometer Wideband
Other gauges to be determined
The idea is a full interior, fully streetable, and track monster. She has much work yet to be done, but I have a good start.
Pre transplant:
That's better! Maybe not the color combo...
"Sometimes nothin' is one cool hand"
242: Stage X It's a process.
RSI-online sales!
B-dub is offline   Reply With Quote
Old 09-04-2011, 09:20 PM   #2
B-dub
OG
B-dub's Avatar
Here is the whole process to date. I apologize the 4th update is not attached.
Swapping, stitch welding, gutting, wiring, moar faster....
Strip and deep clean the interior.
Fate knew that I would be facing Nathan at some point and left me some wood screws to keep the doors from being blown off.
Won’t need any of this.
Completely strip the interior.
I’ll be hand laying the whole harness from scratch.
Remove all the sound deadening tar paper.
Strip engine bay down to sexy smoothness. No need for unsightly wires here.
Old 09-04-2011, 09:22 PM   #3
B-dub
OG
B-dub's Avatar
This stuff is everywhere! All must go.
Needs moar power!
Tar paper removed.
Prep all seams for stitch welding.
More seam preparation.
Stitch welding for days.
Old 09-04-2011, 09:22 PM   #4
B-dub
OG
B-dub's Avatar
This whole process of stripping the interior, taking out the engine, taking out the tar paper, prepping the seams, welding, cleaning the residue off, painting and primer took a solid two weeks.
I could not be happier with the result but it was one of the more time consuming PITA parts of any build I’ve done.
Aaaaaand the stitch welding continues…
Now that all the tar paper is gone, only the residue remains. Why do a job half assed? Off with the residue!
Once everything was made shiny clean primer and paint were layed down.
Some “green” paint to seal it all up, and have more than just primer peeking past the carpet and interior.
Here sits my wagon… ready for disassembly. It’s a sad day, but it’s going to be awesome when it’s done.
Subframe out of the 242. I will swap over the one from the wagon as a whole unit.
Suspension out of the 242. Some stitch welding showing through.
Effed up battery tray going bye bye.
Engine bay all painted for protection from the elements.
I will be using my chassis media blasting system on this and it will be repainted after the drivetrain and the rest of the chassis is dialed.
Interior will stay the same though. Deal with it.
Old 09-04-2011, 09:23 PM   #5
B-dub
OG
B-dub's Avatar
The old Saginaw steering pump bracket was broken. No real surprise there. This will be changed out to a late model pump.
Ripping her heart out.
And now she’s leaving me. :tear:
I Loooove this hotside. So sexy.
A B230 that isn’t caked in oil… It doesn’t seem right, but I’ll allow it.
Firewall pieces and crossmember installed.
In she goes!
I used some of the polycarbonate from the wagon windows to make templates and other bits for the interior of the 242. Here is a plug for the heater intake. I will be using a Mohave unit from Summit instead of a stock system.
Getting started on the MS relay board.
Mocked up the center console for wiring and function… Not going to stay this way.
Old 09-04-2011, 09:31 PM   #6
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
Looks like your going to be way baller than me!, wait.....I'm starting work on my car again!
962j 815/692@27psi
THIS IS FORSALE V
Old 09-04-2011, 09:40 PM   #7
doucheNozzle
doucheNozzle's Avatar
I've heard it's pimp. One question: did the color scheme change?
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 09-04-2011, 10:15 PM   #8
940guy
940guy's Avatar
its night here on the east coast so post pictures!!!!!
93 944t
b230+16v+holset hx35 16cm hot side +75shot CRUSHED
01 v70 boring DD
88 745 racewagon lots of around cones goodies
940guy is offline   Reply With Quote
Old 09-04-2011, 10:29 PM   #9
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
Originally Posted by Group A View Post
He put all the drive-train from the wagon in it. Won't be a GP car anymore.
I have a hunch...
94 940T "Deb" build under way http://forums.turbobricks.com/showthread.php?t=354303
B5.5 passat wagon, low af sexier than most wagons here.
Old 09-05-2011, 12:58 AM   #10
B-dub
OG
B-dub's Avatar
Originally Posted by Wilford Brimley View Post
I have a hunch...
Old 09-05-2011, 05:10 AM   #11
RvolvoR
Originally Posted by B-dub View Post
takes a genius to figure that one out...
Old 09-05-2011, 02:47 PM   #12
Mylesofsmyles
WHat a teazeee!
I mean rly...not even an old pic of that green 2-door....or a nice carnage shot of the donor????
tell me you pulled off that lumpy SOHC top end, and sold it to a kid in Botswana....telling him it'd make his bamboo bike rly fast...or did we "simply" salvage what was left of the 11-second hearse and strap that biatch in to da green monstahhh??????????
Come on, i'm on the edge of my seat herrre...juss give us a tasteee
Old 09-05-2011, 03:06 PM   #13
towerymt
the real Towery
towerymt's Avatar
I've been known to lock project threads that lack pictures and/or information. Better get to work!
Old 09-05-2011, 03:34 PM   #14
Mylesofsmyles
Uh oh.....
don't anger Mr. T
Old 09-06-2011, 06:22 PM   #15
B-dub
OG
B-dub's Avatar
Oh Towery, powerful and almost as fast as Pat, Spare my thread!
I've added pictures. Specifications, and build plans to follow.
Old 09-06-2011, 06:30 PM   #16
RCArmy434
RCArmy434's Avatar
Planning on using a tru-trac or G80 instead of a welded diff?
-Scott
242 Build
RCArmy434 is offline   Reply With Quote
Old 09-06-2011, 07:09 PM   #17
Cameron
ドクターマリオ
Cameron's Avatar
Looks OK I guess
Man, did Jordan rub off on you for that color scheme?
For serious though, really nice progress man. I'm sure it will be just as cool or cooler than the wagon
Cameron is offline   Reply With Quote
Old 09-06-2011, 07:16 PM   #18
Mylesofsmyles
Better hope so...don't want another one backwards into a wall.
Oh, B-Dub, two green's won't make it right.
Old 09-06-2011, 07:21 PM   #19
euroshark
euroshark's Avatar
Is the engine bay only going to be half way painted?
I loved the wagon. Can't wait to see how this turns out.
euroshark is offline   Reply With Quote
Old 09-06-2011, 07:23 PM   #20
Mylesofsmyles
It makes the engine look better, by comparison...
You know, like when a cute girl brings along, well, her, umm...not so cute friends.
An evil trick.
Old 09-06-2011, 07:23 PM   #21
B-dub
OG
B-dub's Avatar
Some sort of limited slip option in a Ford 8.8. For now the welded will stay as I make other adjustments on the car.
Old 09-06-2011, 07:24 PM   #22
towerymt
the real Towery
towerymt's Avatar
look forward to riding in it this year.
time to ditch that old, heavy power steering pump
Old 09-06-2011, 07:26 PM   #23
Karl Buchka
Looks like you're doing it right. Excellent work so far!
So no heater box at all or are you installing an electric heater? Also, lexan center stack? :'(
Old 09-06-2011, 07:31 PM   #24
B-dub
OG
B-dub's Avatar
An evil trick.
The color is temporary. Once everything is dialed in the motor is coming out, and it's getting repainted.
Old 09-06-2011, 07:38 PM   #25
B-dub
OG
B-dub's Avatar
Thanks!
I'm going with a Mojave heater for a little cabin temp and defrost.
Don't worry about the center panel, It's all I had laying around for mock-up. That'll be aluminum or steel when it hits the street.
