![]() Ok guys, here's a set of instructions for the installation of the wasted spark boards. We're focusing pretty heavily on the installation of the board itself. There are far too many combinations of ignition modules and coils to provide comprehensive instructions on that part of the project. The disclaimer is basically this: Some brain power required, some assembly required, batteries not included. It would be much appreciated if people could post some instructions and impressions relating to the specific parts they used for their installs.
Read this entire post thoroughly and completely before posting any questions. Your shipment should include the following items:
1. Directions for installationThe conversion board has been designed to be mounted inside the EZK box. On 240's the EZK box is mounted on the front right corner of the firewall, right above the foot well. On 740's and 940's it is mounted under the dash, above the throttle pedal. Remove the EZK box from the car, and using a torx screwdriver, remove the four screws on the end of the case and the three screws around the connector. This should allow you to open the housing of the EZK box and gain access to the circuit board itself. The conversion board has 8 labeled solder pads. The four pads labeled "5v", "GND", "Out", and "VR" need to be tied to the four labeled points on the EZK board [fig 1]. "VR" goes to pin 7 of the LM2903 IC. If you tin the leg of the IC you can easily attach a wire to it. The "Out" pin is actually intended for pin 16 of the main connector, but we find soldering it to the indicated resistor leg makes for a cleaner installation. If you want to solder your wire directly onto pin 16, feel free to do so. The 5v and GND supply points should be self explanatory. Make sure you don't reverse them. That would be bad. We recommend potting all the wire-to-PCB connections with hot glue to secure the wires from vibration. The two pins labeled 1-4 and 2-3 are the new logic-level spark outputs. They need to come out of the box and go to the proper pins on your power stage/coil. If your car is not equipped with EGR you can piggyback on those pins, or you can just drill a hole in the box to pass the wires through. Using the supplied screw and mounting washer, attach the board to the body of the main EZK connector [fig 1]. Depending on clearance to the housing, it may be necessary to mount the board in an inverted fashion. We recommend the use Bosch Motorsport 2x2 wasted spark ignition coil (part #: 0 221 503 407). This is the only ignition coil we have found with documented dwell characteristics that match the built-in EZK dwell. The stock ignition module has one output stage, but since the wasted spark system requires two outputs you can either install an additional stock ignition module or replace it with a multi-channel equivalent (eg. Bosch 0 227 100 203, Volvo 960). A sample wiring diagram is shown in [fig 2]. It is important to note that these parts are simply suggestions. You are free to use any suitable combination of ignition modules and coils. 2. Adjustable hard-cut rev limit (experimental)NOTE: This feature is considered experimental. This means we don't guarantee it will work well, or even at all. It means use at your own risk and we are not liable for any damage caused by its operation. Basically don't be an idiot. Your wasted spark conversion also comes with an experimental hard-cut rev limit/launch control/flat shift feature. In essence it allows you to hold the engine at any rpm, even whilst applying full throttle. This should enable more consistent launches from a standing start. It is important to note that this is not an "anti-lag" function since ignition timing is not being retarded. Recommended wiring diagrams for the arm and set features are shown in [fig 3]. The dash-mounted set switch should ideally be momentary and the clutch switch must close to ground as the clutch is depressed. It is important to note that the launch control feature will be completely disabled by simply not connecting anything to the set and arm pads. 3. Tachometer optionsDepending on how you have the system wired, there are a couple of different ways to drive the tachometer. The first (and arguably easier) method works if you have left the stock power stage and wiring intact. Simply move any wires currently connected to the stock coil's two spade terminals to the "85" and "86" terminals of an automotive relay. To keep the relay from clicking you should open the body of the relay and remove the contactor assembly. If you have chosen to remove or modify the stock wiring, then driving the tachometer can most easily be done by building a circuit similar to the one listed in the MS-Extra manual under "Option for High Voltage tacho" (http://msextra.com/doc/ms1extra/MS_E...l.htm#tachoout). The base of the transistor should be connected to the stock EZK spark output pin. Note that this solution uses the same modified automotive relay as mentioned earlier. -------------------- ![]() Figure 1: Preferred connection points inside the EZK box. Note the multiple 5v and Ground suggestions. ![]() Figure 2: Suggested ignition module wiring. ![]() Figure 3: Suggested launch control wiring. Last edited by Karl Buchka; 10-28-2011 at 05:26 PM.. |
![]() I'll provide an (un)educated guess and say no, it won't.
#4 |
Prius Owner
![]() Join Date: Jul 2008
#5 |
![]() So for the tachometer you suggest we do this?:
#6 |
![]() Yes, that's the one. The stock spark output goes in place of the "MS PCB" in that diagram.
#7 |
![]() Here is the pinout on the 0 221 503 407 unit:
![]() and the 0 227 100 203 unit is pinned out as (the unit is used to run 3 sets of wasted spark cylinders): Pin 1-#1 negative coil Pin 2-#1 Input Pin 3-#2 negative coil Pin 4-ground Pin 5-#2 Input Pin 6-#3 negative coil Pin 7-#3 Input This should be the setup using these two parts: Out From EZK: -> Into 203:____ Out From 203: -> Into 407: 1-4 output -------> Pin 2 _________ Pin 1 -------> Pin 3 2-3 output -------> Pin 7 _________ Pin 6 -------> Pin 1 Pretty picture: ![]() I'm assuming pin 3 & 5 of the 203 unit won't be used to run any cylinders. Also, "Switched 12+", I mean 12+ when cranking too. Karl looked it over, and thinks it looks right, but if somebody sees something wrong with it, please point it out. Paul
Paul Last edited by malloy1; 10-22-2011 at 10:17 AM.. |
#8 |
knox motorsports
![]() if you leave the stock power stage and wiring all in place this circuit isn't necessary.
i have been running a dummy coil in place of the stock coil for my tach signal since the installation of the beta buchka motorsports electronic engineering super happy fun time luxury A+++ wasted spark conversion board. ![]() so that is over 3 months (over 4000miles) no glitches what so ever
#9 | |
Prius Owner
![]() Quote:
#10 |
![]() Thanks for posting that Lawrence. I just added a section on tachometer driving.
#11 |
![]() any info on where to source that dummy coil substitute?
- Will Z 1989 244 DL - - - Beige N/A 1988 245 DL - - - Original owners/Dad's Car 1991 244 Turbo - DEAD ![]() ![]() |
#12 |
![]() Read the section I just added.
#13 |
†John3:16
![]() Join Date: Jan 2009
![]() Excellent article, Excellent product.
I've been on board with the second test board in operation. I'd like to add my installation notes. Another option for an ignition module (with built in 12v 4 cyl tachometer output): Mitsubishi J702T Ignition module, coming off 90-98? mazda miatas (1.6l being the most common). This module works great, and just solder up 1 wire for a full functioning volvo tach. Also the coil packs off same said car work perfectly, I made 300whp on them, 500dollarmatt made 360whp.
#14 | ||
ALDORF THE DESTROYER OF WHITE SHIRTS
![]() Quote:
I understand though that LS coils WILL NOT work as they require longer dwell than a wasted spark config can provide. (for those who are thinking about that)
ovlover: Its an auto. Problem found, Manual swap. Problem solved Quote:
I AM ALDORF THE DESTROYER 1985 744ti M46 -3rd, 15g, 3" exhaust, Ported Head, 333,333 miles 91 945 Turbo 3 pedal auto, DD 83 242 Turbo Flathood 15 Golf TDI 6 Speed Doug <3 me. Not scottyd. doug was here again Last edited by WindowsBreakerG4; 11-02-2011 at 03:51 PM.. |
#15 | |
![]() Quote:
#16 | |
![]() Ok I see people doing it so I guess the miata people (
![]() LS1 Coils seem to be 5.6-8MS depending on who you ask :P supposedly factory is around 6 though. It also seems that the dwell varries based on which LS coil it is (IE LS1 has diffnerent dwell than LS2 Coils) http://www.msextra.com/doc/ms3/ignition.html Quote:
#17 |
![]() Is there enough dead output pins on the ECU to run the waste spark through the plug instead drilling a hole in the case?
Paul |
#18 |
Prius Owner
#19 |
![]() As I mentioned in the original post, a non EGR EZK will have enough free pins. Beyond that, I'm not sure.
#20 |
†John3:16
![]() yah, the 2 EGR pins. they shouldnt have the hardware, so solder the outputs to the legs (but dont lift them, they break)
I see no reason to not be able to parallel up the LS1 coils to a mitsu igniter.. split the 12v out each way and have enough to trigger all 4, unless i'm incorrect in my assumption. correct me if I am wrong. |
#21 |
weapon of mass detonation
![]() bret, wahat wire did you solder the tach output to? did you leave the stock ignighter in place? what post numbers are the egr pins?
91 940 SE, 119K, GOLD 03 540i M sport 6 gears of go! 200k, White 05 S80 2.5T, RED 09 XC70 3.2L, BLUE 10 335xi, (fun has a price), black 17 expedition El, (short bus), black 85 RX-7 GSL SE(efi'ed), BLACK 76 Suzuki RE5, BLACK |
#22 |
![]() From this post: http://forums.turbobricks.com/showth...t=75838&page=2
EZ116K: 1: OBD diagnostic socket (in some markets: serial interface) 2: Coolant temp sensor 3: Check Engine Light output, shared with ECU pin 22. Signals: 12-off, 1-on 4: PRE-IGNition, output to ECU pin 28. Signals: 0-Preign, 6.5-stable, 12-knock 5: 12v supply, constant 6: 12v supply, switched 7: Throttle idle switch 8: Load Signal Tq, from ECU pin 25 9: 10: Engine speed sensor 11: Engine speed sensor (shield) 12: Knock sensor (shield) 13: Knock sensor 14: EGR, Ground connector on engine (power ground) 15: EGR, converter, control 16: Igntion amplifier drive, trigger 17: Engine speed signal output. Signals: 6.5-cranking, >8-idle 18: Selector wire. Signals: 5v-disabled, grounded-enabled 19: Selector wire. Signals: 5v-disabled, grounded-enabled 20: Ground connector on engine (signal ground) 21: 22: EGR, temperature sensor 23: Engine speed sensor 24: 25: Looks like 18, 19, 21 and 25 has something to do with timing advance/retard, so those should be not used. That leaves 9 and 24 as empty, but who knows if they don't go anywhere inside the EZK box (the post shows them as grounds)? Three pins are EGR pins (14, 15 and 22), so looks like those three can be used as wasted spark output for non EGR boxes. ![]() Paul Last edited by malloy1; 11-02-2011 at 10:52 PM.. |
#23 |
![]() thanks paul!
#24 |
†John3:16
![]() I used a mitsubishi (mazda 1.6l miata) J702T ignitor, and the tacho output pin off of that wired directly to the volvo tach.
#25 | |
![]() Probably best to post this over here too on the J702T ignitor:
Paul |
