Old 10-29-2011, 08:54 PM   #1
gsellstr
gsellstr's Avatar
Default 7/9 Updated Heater Control Valve
I've been researching this for a while, finally came up with a viable solution for us 'grandpa' series owners. Hopefully this will help a few of you...
The factory heater control valve on the 7/9 series cars is normally closed unless you have the heat on. Normally this wouldn't be an issue, however the way the system is designed and the coolant flow run, when the valve is closed, there is limited, if any coolant flow around the backside of the head. If you have the heater on, coolant can leave the back of the head and return to the water pump by way of the heater core. Given the recent discussions on cooling system issues, plus my lack of a working heater since the last valve broke after just a year, I went searching for a solution.
I came across this little piece of plastic, which so far seems to be a great solution. The cost was $34 from Napa, not sure the application, but the part number is 660-1357, and the local store had it on the shelf. The only thing you'll need to swap the stock valve for this one is 2 extra hose clamps.
NAPA 660-1357 is the front heater valve for 90-95 Chevy Astro Van and GMC Safari Van
Installation goes in place of the factory unit with the 'front' marking getting connected to the hose from the head. The bottom 2 ports get t'd into the return line from the core, which you'll need to remove about 2" from. This valve operates the same as the stock unit, except that it will bypass the core and send coolant back to the pump when vacuum is supplied, rather than simply being closed. When open coolant runs to the core and back via the normal return path.
Initial results also show it allows more coolant to flow thru the core, which in turn means you can bake biscuits easier with the heat from the vents.
And now the pic's (don't have one of it installed, cam was dead).
RIP
Ken Rogers "Redwood Chair" 9/26/2022 - 'Raise the lowered', and always 'Return it to stock'
Nick Fengler "fengler" 8/6/18
74 144
90 745Ti
Still your local Superpro dealer!
Old 10-29-2011, 10:30 PM   #2
740tankDriver
Post-Hypnotic Sigma
740tankDriver's Avatar
nice
Happy Passover!
Great Victory!
740tankDriver is offline   Reply With Quote
Old 10-29-2011, 11:18 PM   #3
MistrThou
Masked Moogle
MistrThou's Avatar
sweet.
refresh my memory... are the to and from heater lines the same size? I sorta thought one was smaller...
Originally Posted by 404: Signature not found
MistrThou is offline   Reply With Quote
Old 10-30-2011, 07:30 AM   #4
buzz
To inspamity, and beyond!
buzz's Avatar
Originally Posted by MistrThou View Post
sweet.
The lines are the same size. Something like a 5/8" ID.
Originally Posted by RĂ¥da View Post
I usually don't get compliments on my penis from guys, but thanks!
I used to be indecisive. Now I'm not so sure.
The Phoenix
buzz is offline   Reply With Quote
Old 10-30-2011, 07:39 AM   #5
Henry10
Originally Posted by gsellstr View Post
...however the way the system is designed and the coolant flow run, when the valve is closed, there is limited, if any coolant flow around the backside of the head. If you have the heater on, coolant can leave the back of the head and return to the water pump by way of the heater core
After the water jackets, the back-side of the head is the 2nd place Coolant from the WP goes to.
What am I missing?
Henry10 is offline   Reply With Quote
Old 10-30-2011, 02:24 PM   #6
gsellstr
gsellstr's Avatar
Sure, coolant can go there or is already there in static flow, but how does it leave? The exit from the back of the head is via the heater core, but if you block that, you can't get the coolant to leave the head. That's where the bypass here comes in, allowing it to circulate out of the back of the head one way or the other.
Heater performance last night in 50* weather was greatly improved as well, even with the fan on high. Normally it would give more air but at a cooler temp than on the next speed down. Same temp at any fan setting now.
Also checked head temps between front and back of the head and the back of the head dropped 15-20* compared to the stock heater control valve, and temps were fairly even front to back now.
Old 10-30-2011, 02:34 PM   #7
canyoneagle
Striving for mediocrity
canyoneagle's Avatar
Thanks for trying this out and providing the initial results!
I'd love to see a sketch of the installation just to make sure I understand correctly (I'm one of those visual types) - I'm about to do a full cooling system replacement, and this looks like a great option.
For the "Tee", do you have the lines going from each of the bottom units into a tee on the core line?
canyoneagle is offline   Reply With Quote
Old 10-30-2011, 02:46 PM   #8
Henry10
On my whiteblock, coolant goes: WP -> water jacket -> back-side of head -> front-side of head -> return to WP.
I don't remember my redblock, but it can't be any other way.
Heater line is tapped off the block, and Valve stands on its way -- HV is closed by vacuum until Climate Control Unit reduces vacuum and opens it.
Old 10-30-2011, 04:13 PM   #9
gsellstr
gsellstr's Avatar
The heater core supply is off the back of the head, goes to the valve, thru the core, then returns via the hardline to the water pump. If memory serves, the pump provides a feed to the head and block, but I don't recall there's any way for it to return if the valve is closed. Even talking with a well respected Volvo guru, he suggested finding a way to do this as well, which is what got me looking for a solution.
Old 10-30-2011, 05:12 PM   #10
Henry10
Like I said, in my whiteblock coolant travels across the head, from back to front and it returns to the WP via the Pipe manifold. This mainfold (outside the motor) collects all returns -- head, heater core, radiator, oil cooler. The heater core circuit is an "add-on" kinda thing, and it has no bearing on coolant flow inside block and head.
If anything, having the bypass would delay warm-up, even slightly.
I don't know the circuit of redblocks, but I would be shocked if it is otherwise.
Old 10-30-2011, 08:32 PM   #11
gsellstr
gsellstr's Avatar
It won't delay warmup any more than having the heater turned on, and actually, it'll still warm up faster than with the heater on in a stock setting, since there's no cooling effect of the core. The whiteblock routing is quite a bit different, especially with that manifold across the back, which the redblock's don't have.
I've been trying to locate a coolant flow diagram but haven't found anything that actually applies to the redblock itself, even in the greenbooks...
Old 10-30-2011, 08:51 PM   #12
Henry10
Yeah, I got a rudimentary Parts Diagram of the B230 and it looks nothing like what I have in my car.
Old 10-30-2011, 08:53 PM   #13
gsellstr
gsellstr's Avatar
There's some VERY helpful info in this thread regarding coolant flow as well, if ya got time to read it. Thomas has some basic info in there that might help it make sense, along with some of the reasoning for doing this swap.
http://forums.turbobricks.com/showth...t=coolant+flow
Old 10-30-2011, 09:57 PM   #14
Henry10
I see it. Like you said, Thomas's concern was for uneven head cooling, when speeds of 4200 rpm or greater are sustained for hours (racing situation), or turbos.
Good thinking Doug. Results prove it.
Old 10-30-2011, 11:03 PM   #15
Otis
I think you may be proceeding from an incorrect premise:
I understood that valve was normally open. So coolant always circulates through the heater core, regardless of where you set the temperature slider, *unless* you also selected "Max AC". At that point, vacuum would be routed to that valve, and it would be closed. For all other settings of the HVAC, the water keeps circulating through the core.
A quote taken from the thread you linked:
Originally Posted by Yea, Right View Post
The only time that vacuum is supplied to the heater control valve (to close valve) on all 700/900 series cars is when the climate unit is set to max AC.
And from Matt:
Originally Posted by Matt Dupuis View Post
I know that the heat control in a pre-90 (at least) 700 is managed by an air door that adjusts the mix of cold and warm air, from 0-100%, and I know that this valvey-thingie is not part of the heat controls.
As I understand it, that valve is normally open, not normally closed.
So, if I understand this properly, the issue that you have solved only arises when you're both driving hard and also running "Max AC".
Interesting mod, but that's a pretty rare circumstance (for my own driving style & local climate, at least) where it would be a real benefit.
edit - your temperature results are really interesting. I wonder if that's because of generally better flow that's possible with this unit, relative to the OEM. Or maybe you were already documenting the test with the Max AC position selected. Or maybe I'm the one who has it backwards.
Otis is offline   Reply With Quote
Old 10-31-2011, 12:33 AM   #16
gsellstr
gsellstr's Avatar
Not sure on the lore of the heater valve only being closed at MAX AC, as that is not the case. It is closed normally, and the moment you slide the temp control lever slightly off the cold side, the vacuum to the valve is killed, allowing the valve to open and coolant to flow to the core. The temp control is indeed based on an air door setup, but coolant flow is vacuum controlled. This updated valve is normally open with no vacuum, same as the OEM valve. The control head provides vacuum to the valve unless you have the temp slider off the coldest setting.
If the valve were open with the AC running you'd have a hot heater core fighting against a cold evap core, leading to mediocre cooling at best. Also, the only thing the MAX AC setting does is flip the system from outside air to recirc, with the rest of the system behaving the same way.
Not quite sure where some of the comments from that other thread came from honestly. Even the greenbook data goes against the stuff you quoted from that other thread, let alone my findings on my own vehicle.
Old 10-31-2011, 01:38 AM   #17
WindowsBreakerG4
ALDORF THE DESTROYER OF WHITE SHIRTS
WindowsBreakerG4's Avatar
I actually think my 85's green book does say something like that (the max AC thing) but I don't think it's right or maybe it's only true for the early cars?
ovlover: Its an auto. Problem found, Manual swap. Problem solved
Originally Posted by cosbySweater View Post
She was pretty damn hot. And she folded my clothes and made me breakfast in bed
Towery wants to get me drunk but doug already is. Don't trust a drunk Towery he will slip you the old stiff one eye
I AM ALDORF THE DESTROYER
1985 744ti M46 -3rd, 15g, 3" exhaust, Ported Head, 333,333 miles
91 945 Turbo 3 pedal auto, DD
83 242 Turbo Flathood
15 Golf TDI 6 Speed
Doug <3 me. Not scottyd. doug was here again
WindowsBreakerG4 is offline   Reply With Quote
Old 10-31-2011, 01:50 AM   #18
jerryc
jerryc's Avatar
So some basics that I think I gleaned; use this valve, GrpA the holes in the head, use a Hepu pump, and for a low/mid hp DD all will be fine, forever. That about right?
What's the female equivalent to a dick pic? twat shot?
There isn't one because dudes aren't grossed out by unsolicited vaginas.
jerryc is offline   Reply With Quote
Old 10-31-2011, 08:36 AM   #19
Henry10
Technically the Heater Valve is open -- when car is NOT RUNNING. The moment engine starts, the vacuum pulls the valve closed, which makes it "Normally closed". Climate Control then controls its variable opening by modulating the vacuum. Some cars do it with a cable.
Like I said, when heat is off, this bypass in effect provides a loop -- hence a head cooler. Results show it. I also like the fact that Volvo heater ports are used, i.e. inferring here that volume of coolant diverted to bypass is calculated somehow. This is the "restrictor" Thomas and Matt were talking about in the other thread.
Old 10-31-2011, 09:58 AM   #20
gsellstr
gsellstr's Avatar
Actually Henry, there is no modulation in this valve. It's either go or no go, with temp being controlled by an air door in the dash. This valve only supplies or prevents flow to the core.
Also, thanks to Alden for digging this up...application data...
Chevrolet Astro 1990, 1991, 1992, 1993, 1994, 1995 FRONT VALVE
GMC Safari 1990 FRONT
GMC Safari 1991, 1992, 1993, 1994, 1995 FRONT VALVE
Old 11-02-2011, 09:13 PM   #21
Bensin
Garrett whine rules
Bensin's Avatar
Brilliant! nice work
Bensin is offline   Reply With Quote
Old 11-08-2011, 11:28 AM   #22
gsellstr
gsellstr's Avatar
Update, since it's actually cold now (37*F on the drive to work).
Warmup time for the engine seems to be unaffected with the heater on full hot and blower on high. Temp from the vents is warmer and it has very limited variance depending on fan speed.
Temp from the plastic/alum heater core is actually closer to what the temp was with the all metal core now. Yay, heat this winter! I actually had to turn the temp down a little on the drive in, after turning the fan completely off, since it was staying quite warm inside the car.
Old 11-08-2011, 03:18 PM   #23
Magnum TE
Broke another B230F+T
Magnum TE's Avatar
I'm running one on my Gray car so far so good. I can't say that it's working better because my heater blend box control is broken and my blower motor is frozen, but when I get that stuff repaired it's gona be great.
Goldie Bricks - '92 940T : B230F+T MSnS-e...
The Black - '98 318i : stock drive-train DD
I have some cool stuff done to my cars
The Gold Car: Owner since 2001
B230F+T MS1nS-E / Ford T5, 1pc DL
ebay FMIC / Mechman Alternator
T3 60/.63 ATP WG / 98#/hr injectors
Full 3" Turbo to tail / IPD TP Cam
IPD bars / Coilovers
Koni Dampners / Lower Chassis brace
NIW-T3 camber plates / Full poly front end
Full Kaplhenke Rear end
-Torque rods -PH Bar -Subframe
Daily Parker
Magnum TE is offline   Reply With Quote
Old 11-10-2011, 10:17 PM   #24
stealthfti
Excellent find there, Gary. I like the design. Thanks for doing the legwork on that.
TF
stealthfti is offline   Reply With Quote
Old 11-10-2011, 10:44 PM   #25
Volvoist
Volvoist's Avatar
Thumbs up!!
Mike Rausch
Newark, Delaware
Vintage, classic, and unusual vehicle and parts sales. Specializing in ALL Volvo RWD models
www.swedishbrickyard.com
Email: mike@swedishbrickyard.com
Feedback here: http://forums.turbobricks.com/showthread.php?t=228756
Volvoist is offline   Reply With Quote
