~Uwaooo! Kupo!
Nearly superb body (for WI anyway[{s}])
93 240. 186xxx miles. M47. Havent checked to see if its round or square tooth. Has a build date of 92. Rear parking brakes are frozen up solid. Car's been sitting for over a year. ![]() ![]() ![]() ![]() ![]() And the wife's toyota helping anchor the 240 to the driveway... Sure is a bitch to move with a frozen rear end. Need to get that tackled asap. ![]() The interior is amazing. The seats are 9 out of 10. Future plans are turbo it. Should be fairly simple to do being its already LH2.4. I saved the turbo guts from my 91 940 turbo. As well as the ecu/ezk.
Post-Hypnotic Sigma
cowabunga!
awsome!
talk is cheap; hills are steep; sorrow is deep the u.s. federal government is to be destroyed. |
not yet good enough
do it to it! hope you hang on to this one for a while... or maybe i'll just buy it from you
#4 |
Whooty patrol
total score
'82 242t turbo+, intercooled, 3" exhaust, 13" brembos, coilovers, saabspoiler, 18"s, flathood, dying m46, etc. '97 f-250 psd, d60, locked, chromoly axles, shortened and bob'd. '91 940irs rallybil, holset, gutted, olive drab rollered on paint, browntops etc '90 F-250 project. Lots of links, tube, and coilovers. |
#5 |
~Uwaooo! Kupo!
Halleluiah! It runs!
Fresh battery, fresh gas, jumped fuses 4 and 6! The fuse block has some pretty funky corrosion. I ran it just for less than a minute to jump for joy, then shut it down. Fresh fluids abound! Also, for those who didn't know, this is a replacement to the last car that was totalled. (I like to say my wife didn't like that car and wrecked it, but she was rear ended). See here. |
#6 | |
~Uwaooo! Kupo!
And buzz would have dibs. |
#7 |
Spending Money On The 760
![]() Join Date: Jan 2003
awesome find there!
85 760t 16Valve, holset turbo, getrag 265, twin disc 06 V70R 6mt, springs, sways, full exhaust, flywheel |
#8 |
To inspamity, and beyond!
MIDWEST MADNESS VII ~ June 23/24, 2013 I used to be indecisive. Now I'm not so sure. The Phoenix |
#9 |
That is a nice 240. Looks like it is in great shape.
FCP Online Support Team ![]() FCP Euro - European Car Parts Specialists FCP Import - Import Replacement Car Parts |
#10 |
dinner plates... yes
![]() -Vagabond 1980 242 DL - shake a tail shaft! 1980 242 DL - (the ugly twin) sold :-\ 1986 s10 blazer, smallblock, bagged, suicide doors. RIP 1991 244 N/A - stripped and left for scrap. |
#11 |
#12 |
~Uwaooo! Kupo!
#13 |
~Uwaooo! Kupo!
Drove it into the garage under its own (battery) power. Cleaned up the fuse block area with a dremel and mini wire wheel. Electronics work pretty good.
Beat the hell outta the rear rotors to get them off and disconnected (for now) the parking brake stuff. In my attempts to free up the parking brakes, the right rear rotor developed a nice size crack in it. I'm going to buy all new brake parts anyway. |
#14 | |
Junkyard Smuggler
I've always had a soft spot for late model red 240s. Looks good!
K-Jet to Megasquirt Article |
#15 |
Herp McDerpington
Careful jumping fuses. PO of my POS 89 245 did that with one of them, forget which one, whichever one it was that has the power windows and the reverse lights - one day I put it in reverse to back up and it immediately died, a few seconds later the cabin was full of smoke and the well oil-soaked foam insulation under the shifter was alight. Fortunately I had quick access to a fire extinguisher or I would've lost the car. Turns out the reverse light switch wiring was completely shot and it had grounded out against the shifter linkage assembly.
'84 244ti - LH2.2 swap - project '90 765ti - some stuff, soon some different stuff. - dd '10 International really big diesel thing - work dd old stuff brickspeed "Meth might be a hell of a drug but it does wonders for intake air temps.." -Sam (RoadRacer4Life) ![]() |
#16 | |
Bummer Life Tour Guide
be careful man |
#17 |
~Uwaooo! Kupo!
So... I pulled the driveshafts and center support, worked my way up to the front and went to remove the clutch cable...
WAAAAY outta adjustment. So I adjusted it. And put everything back together and drove it 'round the yard. As far as I can tell, there is absolutely nothing wrong with that clutch. I even goosed the gas in gear with my foot on the brake to see if it slipped or something... NADA. So some brakes, a driver's handle, and registration and I got me a nice 240. |
#18 |
Can play the blues
Good find! Nice work on the fixes. That'll be a nice car to drive when you get it completely sorted for the road.
Dave, 1982 242 turbo. MVP coilover front and rear suspension. Bilstein HD. IPD 25/25 bars. 3" MVP exhaust. Cosworth Sierra hot side T3 .48 with upgraded stock .42 compressor. Ported 90+.True Track diff. Flat hood 1979 front grill Ecode park/turn lights with H4 Hella. 321k miles. Had it since 1995. 1993 245 Classic, 340k miles, enem V15. Genuine Volvo stock over the axle exhaust. |
#19 | ||
GL with it man.....awesome color!
-1998 V70 XC: Sirius setup : Whelen LED's : 221k Daily --1995 Dodge Ram Van 3500 5.9L V8 145k Hauler: Party Van ![]() VOLVO FAMILY-4-Life |
#21 | |
~Uwaooo! Kupo!
Since its so bent, I'm gonna try and pick up a heat gun. I've wanted one for ages. |
#22 |
Looks like 2 trips to Pull-a-part and $30 in car care products and it will be a nice, red 244.
#23 |
~Uwaooo! Kupo!
*UPDATE*
Spent a little bit of time on it today. ![]() I pulled the rear bumper off of it. The aluminum core is pretty gnarly. It looks like I can get some steel plate and just run 4 1" wide strips with holes drilled for the bumper support. Then I'll be looking for a better bumper cover. ![]() Oh, and replaced the MAF (scavenged it to fix the sis's 740) and replaced a few missing hose clamps, fixed the battery charger given to me, and swapped fuel pump relays. It starts all by itself now. ![]() Freebie battery charger: ![]() |
#24 |
Awesome!
-Sina ![]() 1992 Volvo 240 Wagon (daily $waggawagon) 1991 BMW 318i/4 E30 (expired tagz, at home) 1983 Peugeot 505 STI (project with pops) |
#25 |
Man I want a red 244 so badddd. Jealous
| Thread Tools | |
| Display Modes | |
