Go Back   Turbobricks Forums > General > showroom > projects & restorations
Old 11-08-2011, 01:53 PM   #1
Roy 940
Roy 940's Avatar
Default '94 945 TIC RS project
Hi all,
Here is a short story about my DD 945 TIC ( I apologize for my bad english )
I've bought this car in 2002, just before my daughter was born. It'll replace my Alpine A310 V6.
Mods actually done :
Engine :
-ported to be gasket matched and polished 530 head, sandblasted intake ports, modified valve seats, Group A cooling holes, deshrouded exhaust valves...so : Evo II
-RSI Stage 2 camshaft, at +0°
-90+ ported and polished manifold
-Ported 19T @ 19psi, + Forge adjustable 1.3 bar wastegate actuator
-full 3" JT exhaust with 300cpsi cat
-KL Racing intercooler
-3" throttle body
-Nathan intake + fuel rail
-Yoshifab phenolic spacers
-Bosch 3" 012 AMM
-Wasted spark ignition system
-Magnecor 8.5mm leads
-Bosch WR5DC+, gapped at 0.80mm
-TLAO chip ECU, 6500 RPM
-TLAO chip EZK, 6500 RPM
-Dale's gear and underdrive pulley
-Gates Kevlar timing belt
-3rd motor mount
-Denso/Fiveomotorsport flow matched 44lb/hs injectors, resistor pack suppressed, 2.5 bar FPR!
-Bosch 044 fuel pump
-Hifi paper air filter, in a modded airbox
Transmission :
-M90
-stock Diesel clutch
-1041 rear axle
Suspension :
-Kilen springs front and rear
-Poly bush
-Brand new front sway bar link + IPD Poly bushes
-camber mod -0.75°
-caster mod +3mm
-IPD sways bar
-handmade lower strut brace
-SAM upper strut brace
-Bilstein Touring shocks
-all ball joint new
-960 lower reinforcement brace
Wheels :
-Volvo 850 T5-R rims
-Pirelli P zero nero, 215/45 17 front
-Pirelli P zero nero, 225/45 17 rear
-25mm spacer front
-28mm spacer rear
Interior :
-OMP racing seats
-OMP "velocita" steering wheel, 350 mm, leather...
-AEM wideband
'94 945 RS project:
http://forums.turbobricks.com/showthread.php?t=247082
Roy 940 is offline   Reply With Quote
Old 11-08-2011, 02:25 PM   #2
Roy 940
Roy 940's Avatar
Pics :
Old 11-08-2011, 02:28 PM   #3
Roy 940
Roy 940's Avatar
Old 11-08-2011, 04:42 PM   #4
Roy 940
Roy 940's Avatar
Mods to be done :
-RSI Stage2 cam
-3" AMM + 500ccm/min injectors
-tubular exhaust header
But now, this car run pretty well...
I'll also find a dyno near my town, but the price scared me (180 chf per pull, 150 usd... )
Old 11-09-2011, 05:49 AM   #5
MadDog_945
MadDog_945's Avatar
Ouh man.. that intake looks awesome..
Fuelrail also... nathans Stuff eh?`;)
012AMM.. as said.. i beleive i got one for u, but havent been able to test it...
how much boost do you have?
MadDog_945 is online now   Reply With Quote
Old 11-09-2011, 06:50 AM   #6
Roy 940
Roy 940's Avatar
Yes, this nice intake is Nathan stuff!!! I like it so much !
I'll check my money, to buy your AMM, asap!
I've 0.95bar boost now, it's very good like it.
Old 11-09-2011, 09:24 PM   #7
DNAsEqUeNcE
†500DollarSparkMap
DNAsEqUeNcE's Avatar
who did your porting job? souper smooth.
Matthew 10:28
And fear not them which kill the body, but are not able to kill the soul: but rather fear him which is able to destroy both soul and body in hell.
Originally Posted by Karl Buchka View Post
Any ECU, when improperly wired, tuned, or installed will be unstable and unreliable.
Long live the pen15hood.
Old 11-10-2011, 02:26 AM   #8
Roy 940
Roy 940's Avatar
Thanks! I do it myself, after job time...
Old 11-10-2011, 04:34 PM   #9
Roy 940
Roy 940's Avatar
I've found today 4x 850 T-5R rims in a very very good shape, for a very good price !!! Too much happy!
Old 11-10-2011, 05:53 PM   #10
MadDog_945
MadDog_945's Avatar
i c MSD blaster there? also installed an 6a?
Old 11-10-2011, 06:00 PM   #11
Roy 940
Roy 940's Avatar
No no, just Bosch "red" coil ( I don't remember the numbers ), and without MSD Blaster...
I never had any issue with this ignition setup...
Old 11-10-2011, 07:11 PM   #12
harribert
M90s are lame anyway
harribert's Avatar
Beautiful port work.
'94 944T
'11 Fit Sport...at least it's a manual.
'92 944
Uberhoopt; '91 244
harribert is offline   Reply With Quote
Old 11-11-2011, 03:11 AM   #13
Roy 940
Roy 940's Avatar
Thanks! I like to do it! When I've time, I'll mod my other head, with bigger ports
Old 11-11-2011, 03:42 AM   #14
harribert
harribert's Avatar
Might have to send you some of my own hardware then
Also, pics of your Renault?
Old 11-11-2011, 03:54 AM   #15
MadDog_945
MadDog_945's Avatar
You should go for 15g with straight flange..
That conical housing is crap... have the same here... bottleneck...
how did ya do the portwork? tools?
Old 11-11-2011, 05:35 AM   #16
harribert
harribert's Avatar
Actually that conical housing looks more open than a stock flat flange.
Old 11-11-2011, 05:35 AM   #17
harribert
harribert's Avatar
Old 11-11-2011, 05:55 AM   #18
Roy 940
Roy 940's Avatar
Thanks for the compliments!!!
But I think the shipping price to my country will scare you...
I just have old pics of my Alpine, but I'll try to scan it and post it
Old 11-11-2011, 05:57 AM   #19
Roy 940
Roy 940's Avatar
Right, I had open it more then a flat one... But it is possible to port it a bit more, but I was affraid to do it... I think the lifetime will be reduce too much!
Old 11-11-2011, 06:23 AM   #20
Roy 940
Roy 940's Avatar
About tooling, just "normal" carbide tool, + a lot of sand paper and 3M Scotchbrite ( and oil )... Ah, and a lot of time...
Old 11-11-2011, 06:48 AM   #21
Roy 940
Roy 940's Avatar
Old 11-11-2011, 06:55 AM   #22
MadDog_945
MadDog_945's Avatar
the portwork rly looks great.. but the problem with conical housings.. you can see it on your pics.. the crack between turbine and wastegate... its almost factory.. but gets bigger.... even more when used under performance..
/edit
do you have also ported your manifold?` when i c your flange its heavily ported ;)
Old 11-11-2011, 07:47 AM   #23
Roy 940
Roy 940's Avatar
Yes, you're right about cracks...but what I've seen ( and read ), it's not a problem...
It's a pic of my manifold in a previous post, you can see how it's ported...
Old 11-11-2011, 06:51 PM   #24
Roy 940
Roy 940's Avatar
Leaky water pump fixed tonight... And I add new special anti-freeze + osmozed water, to improve cooling efficiency
Old 11-11-2011, 07:43 PM   #25
cookiemonster
cookiemonster's Avatar
holy fukin 90+ That is awesome i wish i could get my stuff ported like that!
2001 f250 powerstroke, 535hp 715tq
1983 c30 dually, 350/350 6/8 drop
91 240, m47, ipd springs, sweet cone filter!
cookiemonster is offline   Reply With Quote
