propav8r
F*ck Edgar
- Jan 17, 2010
- Franklin, NC
Ok. so Derrick and I got my motor installed today. The only stumper I ran into was the mounting for the transmission.
When I bought the swap package from Vince, he included the crossmember he had used in his car-it's just a piece of 1/4 steel welded to the stock crossmember. With the way the holes to bolt the trans mount to my car are, I can't get the right position,and when I get the holes close (about 1/2" or so) from lining up, the mount only bolts in with 2 bolts, one in each side. I could drill 2 more holes in the bottom plate to bolt the mount down, but that still leaves the problem that the crossmember is only held by 2 bolts.
If I move the mount forward, and bolt it to holes 1 and 2, the crossmember hits the transmission, and it won't work. My old M46 mounted on holes 3 and 4.
I'm thinking that the later cars had holes in the frame in slightly different locations, and that's why the crossmember worked for Vince.
