Old 01-01-2012, 02:10 PM   #1
M.H. Yount
M.H. Yount's Avatar
Default 5-panel tail light to 6-panel tail light
A pretty easy project -- but perhaps something I learned will help someone else. Step one is removing the old units. Usually pretty easy -- although 30 year old gaskets/goop is always pretty. Be sure to take careful measurements. It almost always ends badly if you don't measure carefully - there are a number of interference points on the 6-panels compared to the 5-panel. Use lots of tape - if you slip it may save damage on good paint/rubber/bumper. I used a small cut-off wheel on a Dremel tool. Made short work of the sheet metal. Towels in the trunk to minimize debris in the carpet - and a shop vac handy with the brush attachment to clean up debris as you go. It's like surgery - things go better with cleanliness.
Here they are after the cut, filed edges, paint touched up.
Last - get ready to bolt them in. These replacement units came from IPD -- and I found that trimming the gaskets was helpful in terms of fitment. I trimmed around the bottom of two openings where the housing/bulbs stick through, and I also trimmed 1/8"-1/4" all the way around the outside of both gaskets. I then used a bit of Armor All to lube things up so they would slide and not bind when being compressed. All of this after carefully cleaning the openings before re-assembly.
Before with the tired - 30 year old 5-panels --
After --
One of the light bulbs in the new tails was broken upon arrival. I simply replaced it with one of the bulbs in the set I removed. Worked -- but, of course, set off the 'something's wrong with your lights idiot' idiot light. So I pulled the matching bulb out of the other original housing and put it in the same spot in the other new housing. Problem solved - as usual - replace bulbs in pairs to keep the light-safety gods at bay. I also opened up the factory plugs (on the end of the harness) and pulled each wire/clip out and squeezed the ends together so it would make fresh/tight contact when I plugged them in. A sharp dental pick makes this a piece of cake.
Light was good for a couple of new pics....
Old 01-01-2012, 03:18 PM   #2
M.H. Yount
M.H. Yount's Avatar
Oh - and I have an original, working set of 5-panels if anyone's doing a restoration. The left side has one fatigue crack (not leaking that I can tell) in the amber turn signal panel, but other than that they are probably about as good as you're gonna find -- and likely MUCH better than any you happen to come across in the bone yard. If you're interested - PM me and we'll see if we can agree on a price. Meanwhile I'll get 'em photographed and in the classifieds.
Old 02-04-2013, 03:26 AM   #3
frodosm3
frodosm3's Avatar
im assuming no wiring work was done since you followed a write up format and its not mentioned about any re-wiring. good thread by the way
1976 Volvo 242DL Holset HE351 16 Valve
1983 Volvo 242DL New Daily
1993 Volvo 244 For Sale
1966 Volvo 122S Amazon
frodosm3 is offline   Reply With Quote
Old 02-04-2013, 08:48 AM   #4
M.H. Yount
M.H. Yount's Avatar
The old harness plug connected to the new 6-panels without any changes.
Old 02-04-2013, 03:10 PM   #5
frodosm3
frodosm3's Avatar
thats awesome, makes the swap even easier
Old 02-04-2013, 11:20 PM   #6
940guy
940guy's Avatar
oh wow nice!
93 944t
b230+16v+holset hx35 16cm hot side +75shot CRUSHED
01 v70 boring DD
88 745 racewagon lots of around cones goodies
940guy is offline   Reply With Quote
Old 02-05-2013, 01:56 AM   #7
Roy 940
Nice job and nice car also!
project Blue is Better
http://forums.turbobricks.com/showthread.php?t=247082
Roy 940 is offline   Reply With Quote
Old 02-05-2013, 10:47 AM   #8
Bob
Away
Bob's Avatar
Looks great. I'm going to use a fair amount of tape like this when I trim my rear quarter lips in the back.
Wish it was easier to go from 6 to 5 panels, my favorite taillights are the Euro 5-panels!
Bob is offline   Reply With Quote
Old 02-05-2013, 11:53 AM   #9
M.H. Yount
M.H. Yount's Avatar
Yup - tape is cheap. Repairing the errant mark in nice paint with a cut-off wheel - not so much.
Old 02-05-2013, 12:17 PM   #10
530turbo
THE POLE CLIMBER
530turbo's Avatar
Looks really good mike!!
530turbo is offline   Reply With Quote
