#51 |
![]() Join Date: Dec 2006
Info on how to make your 541 chippable here.
http://forums.turbobricks.com/showth...t=simon&page=2 I do have a couple of lh2.2 ezk bins that are already modified. I got from another member here. I haven't tried them as I don't have a 40 pin programmer. Mine only does up to 32 pins. Also the chip you program is also the main processing chip so you need to buy that first. You can't just erase it and reprogram it. Plus to get that 40 pin original chip out it's easiest to cut the legs off and then you can pull each leg out of the holes and clean them up and put a socket in there. The chip is a MAF 8049H PB A066 Philips. http://www.happytrees.org/chips?page...t=MAF_8049H_PB Simon
![]() 1977 242 16v AQ171C M47 1984 245 D24 M46 ARP 11mm head studs Metal headgasket Biodiesel grown by Oregon farmers. 1990 745 B230FT M46 13c A-cam 3.31 528K MILES. 1991 744 RSI rods pistons Penta 2.5L steel crank 16v PZ cams Holset HC1 Getrag no sunroof no ABS 1041K 3.31 Aluminum hood 80's bumpers E85 quartermaster 7.25 twin disc MS3X-email tune from a reputable emailer. 1991 740SE B230FT motor blew... Last edited by sbabbs; 04-27-2012 at 01:05 PM.. |
#52 |
The MAB8050H has 256 bytes of RAM. That's twice the amount of the stock chip.
Maybe usefull for switchable tables or something. Last edited by mark244turbo; 04-29-2012 at 07:17 PM.. |
#53 |
Thanks for all the added info...
#54 |
"YOU'RE" is a word.
philski o flood has a chipped 2.2 ECU in the FS forum BTW. check it out.
1975 244-Turbo. 2550lbs. Ethanol 1990 245-28mpg M47 DD |
#55 |
Ballsdeep in wire.
im 99.8 percent sure if you got a 2.4 fuel harness and a 2.2 ignition harness, itd work fine.
#56 |
#57 |
Ballsdeep in wire.
You wouldnt have to go 60-2
#58 | |
But if you had the programmer, then any 8749H eprom should work as a reprogrammable replacement for the 8049H originally fitted by Bosch. They come up on Ebay for $20 from time to time, like now: http://www.ebay.com/itm/Vintage-Inte...item2a1be99159 |
#59 |
What would be a good affordable programmer for these chips?
Can they be programmed with the Willems and Top853 programmers? |
#60 |
Benchracer Tribe
"you can't leave your thingy hanging in public... you can get arrested." "What's Arkansas supposed to be, Kansas for pirates?" Forg "I think I can touch the tire. Damn! I can touch the tire! That hurts!" 240Psycho (on the back seat of my 94 Jetta while I was driving to a J/Y) "Use the barbed adapter like what I use to inflate the air camping mattresses and my dates." FTF Engineering i am inspired. i will replace my windsheild... with an intercooler.swedishK Feedback! |
#61 | |||||
Emerged as Ugly Butterfly
Worst idea. Quote:
'97 GMC K2500 Suburban 6.5TD - FailBus
'84 245GLT - FailWagon '92 245DL - The iFixit.com Lemons Car '95 850T5R - ButterCup Cheap 2/7/9 Camber Plates! Now w/Weld-In Steel! BrickSpeed - For Making your car fast. Not low. |
#62 |
Hunting with Ray Charles
This thread isn't about MS, it's about trying to make something out of nothing (LH2.2). Try a little tact, it goes a long way.
#63 |
I have extracted the bin file from a 591 ecu (LH2.2 turbo) and posted it on the ecuproject forum. For those who like to experiment with it.
My personal opinion is that the car runs better with the 591 ECU than it did with the original ecu (518 or 541?). It seems to revv faster with the 591. |
| Thread Tools | |
| Display Modes | |
