The worst thing you can do to that manifold is to port it up to fit a T3 turbine.
The T3 turbine housing should be welded instead and ported to the shape of the manifold.
Never make the manifold larger at the turbine flange.
If you do you might as well us an old 240 manifold.
Erland
and here's some great advice.
You guys aren't really thinking about it systemically - you want a smooth transition into the volute, which on most t3 flanged turbos, is not going to be any larger than the outlet of the 90+.
It might look great in pictures, but you've effectively dispersed any sort of pulse energy you might have gotten from the updated design by taking the volume right there at the flange area and increased it immensely, only to have it neck right back down to the size of a penny. A large to small taper is great if you're dealing with something that's larger already at the turbo flange (i.e. on a tubular header with a nice collector, you have that taper that starts there, if you can continue that into the volute on the housing it will work nicely).
What op is wanting to do essentially, is create an expansion chamber between the manifold and the turbo. That's all that you're going to gain by hogging out the manifold and a td04hl housing (or any housing really).
The restriction in the system is more the turbo itself, and the turbine housing. no amount of porting at the turbine housing flange is going to have a profound affect on that. While it might look good, and you might could get it to read awesome numbers on a bench (well, just the manifold, not the turbine housing, see above), at best it won't do anything at all, and the downside...well goes down from there.
think about it as a series of pipes or straws.. you start at the cylinder head with let's say a 1.5 inch diameter pipe. it reduces down to .75 over the span of a foot, and there it attaches to another piece of pipe that's .75 which further reduces down to the size of a drinking straw over the course of another foot. What good is it going to do if you take the transition between the two and make it a 3 inch piece of pipe? Think about water flowing through that if you need to visualize it. What good is a 3in x 1in wide piece of pipe going to do between the two .75 flanges?
Further consider the turns involved, and by going into that 3in section the water suddenly doesn't turn as sharply into the other segment, what's the situation going to look like right there? it's going to back up, bounce around, and lose velocity.
