Old 03-18-2012, 01:26 AM   #1
Bishop242
Bishop242's Avatar
Exclamation headlight wireing help
hey any of you know any thing about the wiring for the headlights?
i just put single rounds in my 245 (had quad rectangles) but have the bulb out light on all the time now and no high beams.....
any info would be of much help thanks
and yes i looked and am still looking on here for previous threads but no luck
Bishop242 is offline   Reply With Quote
Old 03-18-2012, 10:38 AM   #2
TrickMick
TrickMick's Avatar
1) do you have appropriate wiring diagrammes?
2) WHAT YEAR is the 245 (this info REALLY helps us help YOU...
3) and *YES* most of the crew here "knows anything/something" about wiring headlamps....
In a closed society where everybody’s guilty, the only crime is getting caught. In a world of thieves, the only final sin is stupidity.
TrickMick is offline   Reply With Quote
Old 03-18-2012, 01:29 PM   #3
Bishop242
Bishop242's Avatar
i have the basic books with the basic diagrams
mine is a 1983 245Ti GLT
Old 03-18-2012, 05:34 PM   #4
TrickMick
TrickMick's Avatar
one GROUND per lamp
one LO BEAM POWER per lamp
on HIGH BEAM POWER per lamp
use the ORIGINAL *ROUND LAMP CONNECTORS" (or go to NAPA etc and get
a pair of NEW ones)
with a test lamp and the wires laid out where you can see them - pick ONE OF EACH
(as listed above and hook them up)
tape over any remaining "open" terminals to precloude 'lektrikal shorts
I'm NOT trying to be a prick here - rather I'm asking YOU to "decipher" the wiring diagram
for YOUR CAR so that if "faecal matter strikes the air circulation device" you'll be able to
fix it properly - in the dark - in the rain - alone - on a deserted road - with nowt but a pocket
knife and some duct tape (or cable ties).....
Old 03-18-2012, 05:57 PM   #5
Bishop242
Bishop242's Avatar
when i pulled the headlight and there buckets from the parts car at the yard i got them from i got there connectors with them, i matched up the wires from my car to the colors on the ones from the yard so my connectors and the salvaged ones match. result low beams only....
could it be a relay?
deciphering it is not my issue, as thats what i did to get this far but with the diagrams i can find its not much help
i have done or been apart of all work on this car from when we got it tell now.
im fighting with many other things on the car also so im alittle spread out....
Old 03-18-2012, 06:45 PM   #6
TrickMick
TrickMick's Avatar
the colour code remains the same :
BLUE is LOW BEAM
RED is HIGH BEAM
BLACK is EARTH
pull your power and make the ground using the OUTER SOCKETS on YOUR car
which *SHOULD BE* "three terminal sockets"
(tape off the INNER *two wire* connector which is the "original HIGH BEAM ONLY bulb")
TP30808-1 is the GREENBOOK that has the diagrams you require starting on page 43
or there'bouts
