Old 04-25-2012, 09:30 PM   #1
gharwell
Default cost estimate for vac leak
i recently bought a 1982 244 t and need to repair a vaccum leak in order to pass smog. anybody have any idea roughly what im looking at as far as a price for the repair? thanks for your time.
gharwell is offline   Reply With Quote
Old 04-25-2012, 09:45 PM   #2
atrokz
super cage design genius
atrokz's Avatar
At LEAST $2000!
sorry, accidentally added a few zeros. Depends on the source. Could be a $2 vacuum hose (most likely culprit), or a intake gasket, or component leak. Check all the little rubber hoses coming out from your intake manifold for cracks or ageing. Replacing all the 4mm lines is less than $10 and 5 minutes under the hood.
'06 BMW E91 3.0 DD
91 945 SE - Modded the turbobrick way
98 BMW E36 2.8 - Wife's car
92 245 DL WAS NOT TO BE -RETURNED FOR ZERO SPACE
91 745T RIP
94 850 NA RIP
95 850R GONE
Rob Ford was Canadas greatest president
atrokz is offline   Reply With Quote
Old 04-25-2012, 09:48 PM   #3
lummert
lummert's Avatar
It sounds like one of these estimates: How much money do you have on you?
Old 04-25-2012, 10:20 PM   #4
cleanflametrap
cleanflametrap's Avatar
Hi gharwell,
Almost any vacuum leak I can think of is cheap to repair. The expensive part is finding it and being sure fixing it will solve the emissions problem. Something tells me whoever claims it is a vacuum leak is guessing, or she would have told you exactly what is leaking and how she would repair it.
-Art
Old 04-25-2012, 10:28 PM   #5
lummert
lummert's Avatar
I'm still trying to figure out the part about asking a "she" about the vacuum leak. Does he have a female mechanic? We need more female mechanics.
Old 04-25-2012, 10:32 PM   #6
atrokz
atrokz's Avatar
What's this about a female mechanic?
Old 04-25-2012, 10:52 PM   #7
badvlvo
Bad for Babies
badvlvo's Avatar
How was this determined? Pressure testing the evap? It's common for the tank vent hoses above the rear axle to deteriorate on 240's and cause the evap to fail the pressure test. Both of my 240's did this when being tested, both were repaired for free by my smog guy because I use a test and repair shop.
If it's an engine vacuum leak that's really easy to find and fix, even if it's an intake gasket. 240's are very simple cars.
Died at age 35
Old 04-26-2012, 12:14 AM   #8
sim
300+ ziptie club
sim's Avatar
I've got a '75 245 through BC emissions by introducing a small
vacuum leak in the right place...
It leaned it out, in practice.
Best strategy is to fail once, and note what you failed on, do
some research, and make adjustments in the direction of fixing
your problem. Even with a carb/k-jet system, you can push it in
the direction you want with the right tweaks.
I can't really recall the Ontario standards, but in BC, you only
need to be as good as the car was when stock. It's low hanging
fruit. If you have retrofitted a modern EFI/IGN system. It is one of
the advantages to owning a seventies 240.
If you are modding an old 240, you can work towards the period
standards with no trouble.
The modern control systems will ensure that your motor does not
blow up. They will be also enough to ensure that your motor will
not spew out egregious amounts of hydrocarbons or CO. If your
motor is running really inefficiently emissions-wise, your motor
will be running really inefficiency power-wise.
A good tune that is good for your track times is just as good as for
your emissions numbers.
Burning fuel for no reason is inefficient, no matter the situation.
I have a Volvo with some half-done, homemade crap in it.
http://forums.turbobricks.com/showthread.php?t=244534
sim is offline   Reply With Quote
Old 04-26-2012, 12:42 AM   #9
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
a vacuum leak can be anything from a broken rubber elbow to a cracked intake.
i say somewhere between $5 and $2000 depending on who does it, parts involved and labor to diagnose the problem.. is that not very specific? neither were you.
-Matt
1989 Volvo 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1998 Volvo S70 T5m- Stock, 229k
1998 Jeep Cherokee XJ- Stock, 154k
1983 Ford F150- '89 5.0 H.O, C6/4x4, F+R LSD 4.10, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, HR-Titan 19p.
500dollar744ti is offline   Reply With Quote
Old 04-26-2012, 12:52 AM   #10
WindowsBreakerG4
ALDORF THE DESTROYER OF WHITE SHIRTS
WindowsBreakerG4's Avatar
What's it failing on?
ovlover: Its an auto. Problem found, Manual swap. Problem solved
Originally Posted by cosbySweater View Post
She was pretty damn hot. And she folded my clothes and made me breakfast in bed
Towery wants to get me drunk but doug already is. Don't trust a drunk Towery he will slip you the old stiff one eye
I AM ALDORF THE DESTROYER
1985 744ti M46 -3rd, 15g, 3" exhaust, Ported Head, 333,333 miles
91 945 Turbo 3 pedal auto, DD
83 242 Turbo Flathood
15 Golf TDI 6 Speed
Doug <3 me. Not scottyd. doug was here again
WindowsBreakerG4 is offline   Reply With Quote
Old 04-26-2012, 02:00 AM   #11
jerryc
jerryc's Avatar
She's a wrench. Just... drop the 'r'.
What's the female equivalent to a dick pic? twat shot?
There isn't one because dudes aren't grossed out by unsolicited vaginas.
jerryc is offline   Reply With Quote
Old 04-26-2012, 05:33 PM   #12
ODDmanout
ODDmanout's Avatar
What does she look like? Where does she work?
ODDmanout is offline   Reply With Quote
