Owner of a Loyal Pit Bull
Looking for new P/S pump for my 1991 240. yep the one with pump mounted reservoir/all in one P/S pump.
While an OEM Volvo pump would be best quality(if not NLA) I was wondering...... Anyone had success with a remanned CarDone P/S pump on a 91 240? Are there better remanned ones? Is there any company making them NEW? If so, where?
Seriously afflicted with CVOCD. Link to my build thread : http://forums.turbobricks.com/showthread.php?t=203083 Link To My Oil Temp Sender Drain Plug Thread: http://forums.turbobricks.com/showth...=smokeyfan1000 Link to my B&S Feedback http://forums.turbobricks.com/showth...=smokeyfan1000 Please Help Keep the South Beautiful, Put a Yankee on the Bus... Last edited by smokeyfan1000; 05-17-2012 at 03:41 AM.. |
That is a saginaw pump. They where used on Mopar products for years. You might check a dealership or maybe Year One.
Robert http://www.volvowiringdiagrams.com/ 82 244DL, 2004 S60R AWD, 2008 S40 GF's Had: 77 242 DL, 80 242 DL, 82 245 DL, 89 740 GL, 94 850T, 95 850 GL, and a 02 S60 2.4T |
The 91 is a Saginaw pump? thought that was the older 78-85 pump?
#4 |
~*WWD denialist*~
The later pump definitely isn't the same as the Saginaw unit. I can't comment as to the quality of the rebuild, but I have an A1 Cardone axle in my 850 and haven't had any issues with it.
#5 |
IINM this P/S pump was used only one(maybe 2?) year of 240 production. That year being 1991 240 Pic below...
#6 |
So... everybody else's 1991 240 still has the OEM Volvo P/S pump on it heh?
#7 |
No one?
#8 | |
2 X 1991 244 original pumps (both over 210K miles 1 X 1993 245 original pump (over 240k miles)
In a closed society where everybody’s guilty, the only crime is getting caught. In a world of thieves, the only final sin is stupidity. |
#9 |
well mine seems to be making an intermittant knocking sound & making the P/S belt work harder too. At 191,XXX miles too.
Guess I'll have to be the TB Guinea Pig, and try a remanned CarDone one. |
#10 | |
there are SEVERAL "seal kits" listed all less than $25 USFRN.... I'd try one of those FIRST (assuming that the drive shaft isn't wobbling around like a dick in a shirt sleeve)... ![]() |
#11 |
I'm interested to see what you make of the rebuilt unit. I need a P/S pump (for a much older car though) and I've been looking with interest at rock autos prices, I don't usually trust parts that seem too cheap though.
79 poo brown 245 - B23E/M46 swap. 405 head, K cam @ 4 deg adv. Bil HDs, dual sways, 2.5" exhaust etc. 5% tint, loud stereo and some sketchy wiring 82 yellow 244 - Slow as **** but nice and clean, gfs car |
#12 | ||
Porkchop Sandwiches
Why not just get one from a junker? Quote:
#13 | ||
one lesson after another
That failed in time, back to a used single piece original.
#14 |
knox motorsports
hey smokey,
the later pump you are looking for is a saginaw TC model, the early one with the metal resivor is a saginaw P series. i would recomend pulling the flow valve and cleaning the screens in the pressure relife valve before replacing the pump. i can get the maval rebuilt pumps for a good price if you need one.
#15 | |
Not much to choose fro in local JY for 91 240 that isn't already gone. Might have to look though |
#16 |
Slowest in the West™
and summit sells brand new saginaw TC for less than a c note
V A F (1976 265dl/b27/m46 killed in battle, 1991) (1976 265dl/b27/bw55 bring out ye dead, 2000) 1980 262c/b28/m46 'Black Knight' (getting roof/ext resto and engine swap) 1982 244t/b21ft/aw71 'Vicious Chicken of Bristol' 1989 780/b230ft/aw71 'Brave Sir Robin' |
#17 |
knox motorsports
#18 |
#19 | |
all i did was select the right thread size from the list, something like 16mm IIRC Last edited by Coupe' de Grace; 05-16-2012 at 04:39 PM.. Reason: because Knox Motorsports is awesome and knows WTF is up |
#20 | |
#21 |
knox motorsports
cardone < mavel < jac(hard to find) < new. none of them will come with a new resivior, that will be a dealer item.
#22 | |
shows * 2 * pumps listed (both remmaned) ONE comes *WITH* the reservoir and the other is *naked*....hmmmm |
#23 |
Cardone shows one "nekked" and one with reservoir. but unsure if reservoir is a new or a used reservoir. I suspect it's a used one?
I may call dealership tomorrow & price a new P/S pump if it is not NLA. I'm figuring @200 bux for OEM one. |
#24 |
Maval's has NO reserv. & has 12 month, 12,000 mile warranty for @ 110.00. cardone, comes with reserv., & has 3 year, 36,000 mile warranty for @70 bux
http://www.carparts.com/details/Volv...donea120476041 |
#25 | |
listed as "PSC" on the TOP line of the description ( which I normally read as "Power Steering CARDONE"- but the SECOND line lists it s "TIC Pumps" which is some larger reman outfit....) http://www.autopartsway.com/Part.cfm?W0133-1680286/MAV (lists a veritable SHlTLOAD of *JEEPS* that the pump fits...hmmmmm).....MAVAL!..... http://www.volvopartswebstore.com/sh...=0&modelYear=0 I'll wait while you see the price and then crap yer shorts..... ![]() *if* it's on the website..it *should STILL be available*....I'd try a SEAL KIT for less than $10 USFRN before I'd pay out THAT amount of DO$H! |
| Thread Tools | |
| Display Modes | |
