@ stage -5 currently
Cant add any performance parts as per rules. Was thinking of runnin coolant thru the evap core. Anything to help cool it on a 1.9 mile road course. Getting lines made is easy. Has anyone done this? Results. I searched but really didnt know what to put.
![]() Join Date: Jul 2009
have your heater on while your racing
1988 Volvo 244, B21ft, unitek stage 4 531 head and cam, ms2v3.0, "gt35" Aw71 http://forums.turbobricks.com/showthread.php?t=223946 |
#4 |
Don't be me
![]() Join Date: Aug 2003
940 NA radiator has the inlets/outlets in the right places.
-Jacob: I put a whiteblock in my 240. ![]() Need a short throw shifter for your M46/M47/M90? Give me a shout. |
#5 |
Hunting with Ray Charles
Buy a 3 core brass or aluminum and paint the tanks black so they look like plastic.
#6 |
Turbo & Parts Supplier
What year, make, and model?
89 CSX - 99.7mph trap and climbing 85 GLH - 102mph trap and focusing on MPG!? 94 855 - all apart Couple of 19T Compressor Upgrade Kit left, PM me if interested. |
#7 |
Bypass the heater valve, or switch to a four port. This will keep head temps more even, increase overall cooling capacity and reduce coolant pressure. And yes YMM would help us help you.
#8 |
ive got a tropical fan clutch if you have not gone for an e fan
#9 |
I use since years the Nissen cooler, filled with osmozed water + high quality anti-freeze (Total racing fluid). My car don't have any heating issue now...
#10 |
the real Towery
Stock radiator worked fine in our 240.
![]() Lack of details gets relatively useless responses, though. |
#11 |
Stock radiator with a low temp t-stat and a efan work fin on my 240 even after 10 hours of track abuse.
#12 |
Emerged as Ugly Butterfly
You should probably tell us about the vehicle. You know. So we can help you.
'97 GMC K2500 Suburban 6.5TD - FailBus
'84 245GLT - FailWagon '92 245DL - The iFixit.com Lemons Car '95 850T5R - ButterCup Cheap 2/7/9 Camber Plates! Now w/Weld-In Steel! BrickSpeed - For Making your car fast. Not low. |
#13 |
240 series - I run a diesel radiator that has had a 3-row 16 fin/inch core installed. Looks stock.
'82 242 5.0L; '08 Cooper Clubman; '00 Accord (M.I.L.'s 42k mile car) |
#14 |
what makes you think its going to over heat. the stock cooling system is more than adequate for cooling the engine even in hot temperatures and high loads.
do you have a blown head gasket? a blown head gasket will put a lot of heat into your coolant. |
#15 |
....or will let a lot (like all) of coolant escape....
#16 |
Im starting a chumpcar. 92 940 turbo. has electric fan. Cant run coolant or water wetter etc. already ditched heater valve and orig hoses. fan is always on ( workin to reroute ducts to either on driver or out window). Also trying to find extension housing with fitttings to run OEM cooler. Car cant be changed from stock type setup without penaly laps. You tell me where to find a diesel 940 radiator and i'll plunk the coin down.
#17 | |
#18 |
Im a 10 yr volvo tech. I remember when it was prestone green and not the weird blue it is now.
Im getting this free 940 together. Im gonna hammered with laps i think. Im thinkin about heading to the VA race with my brothers for a weekend. Im ready to get destroyed first year or two. The AIV thing is killin me. |
#19 | |
#20 |
Im trying to run in 2013 @ NJMSP cuz its the closest they come to us. Im just trying to think of everything i can to keep it alive. Every Non performance part edge i can get, i want. I dont want anything to raise a flag cuz then questions get asked.
EDIT: rules say water only so thats what ill do |
#21 | |
Owner of a Loyal Pit Bull
Seriously afflicted with CVOCD. Link to my build thread : http://forums.turbobricks.com/showthread.php?t=203083 Link To My Oil Temp Sender Drain Plug Thread: http://forums.turbobricks.com/showth...=smokeyfan1000 Link to my B&S Feedback http://forums.turbobricks.com/showth...=smokeyfan1000 Please Help Keep the South Beautiful, Put a Yankee on the Bus... |
#22 |
Makes sense. I know drag strips wont let you take a pull if your car is leaking at all. And if you leak on the track you get fined. I saw this honda kid blow up his b16 at RMR and he had to pay $80 clean up fee. This is even more important on a circuit where lateral acceleration is taking place.
#23 | |
JDM yellow fogs
#24 |
"Cant run coolant" What is it - an air cooled engine series? Gonna be hard to keep it cool without coolant. Suspect you meant you can't run antifreeze. WATER is the coolant.
The stock 9 series radiators that came in the turbo cars should be more than sufficient. And most of us have run the heater on full blast to help. |
#25 |
the real Towery
the big 940 turbo rad is plenty. use a 82C t-stat and it should do fine.
| Thread Tools | |
| Display Modes | |
