So, here's what happened this morning:
-got in, inserted key. -cranked and started...idles very rough like it was just about to stall but did not. -gave it just a little throttle, and it seemed to settle on a steady idle. -pressed the brake pedal and pumped 3 times and car stalled. My wife told me that yesterday the car stalled on her 3 times, each time right after pressing the brake pedal. What could this be? Do I need a new brake booster or that little white valve that's on the booster with a hose attached to it? The plugs, cap, rotor have about 10,000 miles.
1992 VOLVO 240 N/A 1989 BMW 325i 1992 Vespa PX200E |
pull the vac line at the manifold and plug the nipple on the manifold....
does it die the same way?? if NO....carefully remove the "valve" from the booster and apply vacuum to "booster side" of valve (it's a ONE WAY VALVE..if it passes vac *(BOTH WAYS* it's due for retirement) connect the vac line back to the manifold...partner in crime starts engine whilst YOU hold thumb over valve opening - modulate thumb (listen for HISS indicating valve is allowing "vacuum" to pass can you make the engine die as noted?? while yer out there under the bonnet *LISTEN* for the tell tale HISSSSS of a vacuum leak....I stuff a small diameter 3 foot length of hose NEAR my ear and wave it about poking at injectors bases / accordian hose to Throttle Body Idle Air Control motor / Flametrap / etc....wave it over the BOOSTER CAN and listen for a CONSTANT HISS (the booster will reach it's "low pressure state" fairly quickly) - if it has a CONSTANT HISS the diaphragm is faulty (sometimes you can eve hear the "hisss" INSIDE THE CABIN (under the dash near the brake pedal "rod" that goes into the booster / master cylinder) the "stalling / dying" may be related to brake boost use *OR* it may just be the "straw that broke the camels back" and there is ANOTHER VAC LEAK you need to address... booster valve is *$ALTY* at $25 USFRN: http://www.fcpgroton.com/product-exe...category_id/45 this is one part I get irritated when I have to replace --- it's freakin PLASTIC dammit! ![]()
In a closed society where everybody’s guilty, the only crime is getting caught. In a world of thieves, the only final sin is stupidity. |
#4 |
#5 |
ok...i'm going to look into soon then, and will report back.
#6 |
So things seem to be repaired and all good.
I removed the booster check valve and blew into it and drew air from it and it definately allowing air flow one way...from the booster to the manifold. I hooked everything up again and started the car...it idled very inconsistently and i had to open the throttle just slightly to keep it smooth. Then I looked at the ISV. I tapped it with my screwdriver handle and it idled smooth again. I went and pulled the ISV and cleaned it out...all the stores were closed and all i had was seafoam and carb cleaner so I dribbled a little seafoam into the ISV and let it all drain out. cleaned both in and out tubes on it, reinstalled and it idled like a dream. went for a test drive and pulled over a few times to shut it down and restart the car...no issues. pumped the hell out of the brake pedal...no issues. im guessing the ISV just needed a cleaning? will the seafoam cause problems in the future? For peace of mind i may get another ISV and put it in there amd the xar will stay ok for a day or two until i get the new. |
#7 | |
didn't cook the insulation off the motor itself....I've had to replace TWO of them since Moby Dick was a guppy...you'll be fine... save yer do$h for other bits (a j/y part will suffice if you feel the need)... clean it w/the "Mass Air Flow" stuff (working to keep the liquid out of the motor part) and then pack yer "freshened up" part in a bag w/a bit of the "rust proofing paper" that lots of things come with these days (it's the brown sheet that you "wonder whutinell is THIS") http://shop.advanceautoparts.com/web..._T|GRP2030C___ GOOD JOB (looking elsewhere *and* FIXING IT!) |
| Thread Tools | |
| Display Modes | |
