Old 06-25-2012, 12:35 AM   #1
Super Matty P
Das Bear Juden
Super Matty P's Avatar
Default turbo actuator tension??
So I finally got around to installing my new 15G from "tryingbe" and took the car for a drive and it won't build boost. When I was installing the turbo I was able to slide the actuator arm over the wastegate hinge without any effort. Put the clip in and moved on. Tryingbe told me the turbo would come pre-set for 7psi or so and would need no adjustment so I assumed this was how the actuator arm was supposed to feel being clipped back on. The rod IS adjustable but I'm assuing this came off an 850 and was already set at the right tension. Maybe the revised mounting location caused an issue where the wastegate is either too close or not close enough?
Can someone verify/debunk this?
after I heard Lil wayne's lyrical talent of "I gots ten toilets, I can **** all day" I now understand why he connects with the youth of today.
Super Matty P is offline   Reply With Quote
Old 06-25-2012, 01:14 AM   #2
vlvman
vlvman's Avatar
It sounds like it is too loose. Tighten it up and use something like a bicycle pump with a gauge to test the setting. It should just start to open the wastegate with the desired psi applied to the wategate.
Robert
http://www.volvowiringdiagrams.com/
82 244DL, 2004 S60R AWD, 2008 S40 GF's
Had: 77 242 DL, 80 242 DL, 82 245 DL, 89 740 GL, 94 850T, 95 850 GL, and a 02 S60 2.4T
vlvman is offline   Reply With Quote
Old 06-25-2012, 01:21 AM   #3
Super Matty P
Das Bear Juden
sadly, I don't have a bicycle pump or vacuum tester here at my garage. I'm taking it to the shop tomorrow to have the ac system leak-tested. I think I'll take a look at it once it's on their lift.
Old 06-25-2012, 01:29 AM   #4
vlvman
vlvman's Avatar
If you have a boost gauge just start slowly adjusting the wastegate arm shorter until you get the desired boost level.
Old 06-25-2012, 01:34 AM   #5
Super Matty P
Das Bear Juden
The last thing I want to do is be anywhere near that exhaust after hitting boost. I'll have to make like 1 adjustment every 3 hours.
Old 06-25-2012, 03:14 AM   #6
Soundmonster
Soundmonster's Avatar
Tighten the son of a bitch up as far as it'll get. Then set your MBC so it'll open easy. Slowly tighten your MBC 'till you get desired boost level. You do have an MBC on there right? And you do have a boost gauge , right? I hope you have a wideband on there too. Put these things on the list pronto. Save some trouble later if you don't.
1990 764 TIC/ '95 Squirter Block,
IPD Turbo Cam, Nuke Adjustable Gear/(Adv. +2*),
TLAO "5xx" chips/227 400 149 Goldbox ECU, Bosch 280 000 563, 15G Turbo, MBC, 012 AMM, Cosmo FPR, CX Racing Intercooler, 3" air, 3" DP/...What Cat?
Motorcraft E5ZE Browntops, Airtex FP, AW-71 w/ accumulator mod.
Boge Turbo gas (front), raised rear w/ IPD conversion springs w/ Nivos. '91 Bertone Rear-end 3:73 with sways, IPD 24mm front sways. New plastic, leather, gauges, .....gotta love it!
Soundmonster is offline   Reply With Quote
