Old 07-05-2012, 02:41 PM   #1
kendogg
V8 Guy
Default V8Volvos.com LS Motor Mounts are here!!!!
First off - Mods, if this is in any way a violation of terms of service or any other rules, please immediately delete and please send me a PM.
The moment everybody has been waiting for, the arrival of the official V8Volvos.com 700/900 series motor mount kit! These mounts are not hodge-podged pieced together, fabricated mounts from arbitrary parts – they were designed & engineered from day one specifically for use in this car, with any LS based engine (car OR truck). They allow for clearance not only at the hood from both the truck intake manifold and alternator, but also on the passengers side for the stock a/c compressor, and in the front for use of the stock Volvo 960 larger radiator & electric fan (depending on transmission used and how far forward that pushes the engine, of course). They’re slotted left and right to allow for precise chassis fitment (since honestly there are so many different transmission, header, and accessory combinations, there are endless ways people will want to use these mounts to locate their engine). They were also designed to keep the engine as low and as far back as possible in order to help keep CG as low as possible for those of you using either automatic or short manual transmissions. They’ve also been designed to adapt to the longer T56 6 speed transmission that so many people use. Unfortunately however, the T56 is a long transmission and does put the engine a bit farther froward in order to line the shifter up correctly with the shifter hole in the car.
The V8Volvos.com kit uses BMW motor mount bushings for a variety of reasons. One of the biggest reasons is that the design of the V8Volvos.com kit mimics that of a stock European (BMW, Volvo, etc.) motor mount design, whereas the arm is attached rigidly to the engine, and then the engine assembly sits on top of the OEM rubber isolator. The BMW bushings were designed exactly for this purpose, and have been long tested to withstand the abuse of high-hp engine loads. They’re inexpensive, reliable, and replaceable. There is reasonable aftermarket support for purchasing replacement bushings later on, or upgrading to something of ‘higher performance’. And in case of an accident, they can shear and still allow the engine to submarine under the vehicle instead of being pushed directly into the firewall like the original factory Volvo mounts. We recommend the OEM rubber for most installations.
We can also upgrade your mounts to use polyurethane bushings from for an additional $40. We’ve teamed with a manufacturer that is building nice isolated polyurethane bushings for us, meaning we do NOT use or recommend the bolt-thru style of polyurethane engine mount bushing. However, the kit was designed with the aforementioned bushings in mind, so we cannot guarantee fitment with another vendors bushing. Any replacement parts are available on an as-needed basis. Pre-order prices INCLUDE shipping to the continental US. For international orders, please email ken@v8volvos.com for a shipping quote.
Whats included:
(2) V8Volvos.com motor mount arms
(2) OEM Sach’s BMW E36/E46 M3 motor mount bushings, or (2) Polyurethane BMW E36/E46 M3 motor mount bushings.
All necessary installation hardware
Pricing:
Standard V8Volvos.com Motor Mount Kit w/OEM BMW M3 mount bushings – $349.99 – Pre-Order price of $319.99
Upgraded V8Volvos.com Motor Mount Kit w/polyurethane M3 mount bushings – $389 – Pre-Order price of $359
Send all paypal payments to ken@v8volvos.com. Please indicate in the notes what isolator option you’re choosing, or if you’re ordering more than 1 set of mounts. We’re working on getting e-commerce setup to be able to purchase directly from the site within the next 1-2 weeks. Thanks, and as always, if there are any questions – please post in the forum, or email ken@v8volvos.com directly!
http://www.v8volvos.com/store/volvo-ls-motor-mount-kit/
kendogg is offline   Reply With Quote
Old 07-05-2012, 03:45 PM   #2
paulcurran
Are these bolt in or welded? Are they the same for all 700/900 all years? With a T56 in a 95 up 960 will the stock radiator & electric fan still fit?
paulcurran is offline   Reply With Quote
Old 07-05-2012, 03:59 PM   #3
kendogg
V8 Guy
They are bolt-in. Same for all 700/900 series cars. Unfortunately, the T56 is so long, it requires moving the motor forward a bit, and I cannot guarantee what radiator or fan combo will fit. Probably also depends on what accessory setup you're running as well. They were designed with the truck intake and accessories, so basically the setup that will protrude the most in any direction. Some of the car setups may fit? I don't know unfortunately, I don't own a T-56, the development car had an auto trans in it.
Old 07-05-2012, 04:27 PM   #4
MrBill
JohnMc=500Dollar Mistake
MrBill's Avatar
Dumb question -
This is for an existing 8-valve redblock crossmember? A 16v car or inline-6 960 won't work?
I just bought a 97 960 and want more powerrrrr.
Originally Posted by 500dollar744ti View Post
something i feel strongly about because even if it doesn't appear so, i am a strong advocate of safety.
84 244 - Wilbur - Lemons hopeful
97 960 - New DD/beater
97 960 - Other new DD/beater
Old 07-05-2012, 04:46 PM   #5
kendogg
V8 Guy
Originally Posted by MrBill View Post
Dumb question -
Dev car was a '95 960
Old 07-05-2012, 04:52 PM   #6
2fast242gt
cheeseland highschool kid
2fast242gt's Avatar
these have already been available from yoshifab for quite some time now just letting members know there are more options out there
http://www.ebay.com/itm/Volvo-740-94...#ht_500wt_1180
make some 240 mounts and a t56 crossmember!
1980 241gt
*6.0 lq4 swaped*
Old 07-05-2012, 05:00 PM   #7
kendogg
V8 Guy
I've had a good bit of interest in 240 parts. However - don't have one! And realistically, there's no enough profit in this for me to go buy a car just to build the mounts. If somebody wants to bring me a car, we'll gladly build the kit and compensate owner of the car one one form or another. A member on v8volvos.com has expressed interest in building them, so lets see where that goes!
And it's odd though, that the ones you listed ONLY bolt into 8v cars? Something doesn't seem right there. Not to mention they look like solid mounts, please correct me if I'm wrong? The JTR kit appears that it was developed in an 8V car, and it bolted onto my '95 960's subframe without issues.
Old 07-05-2012, 05:18 PM   #8
2fast242gt
2fast242gt's Avatar
seems odd they would bolt in 8v and 16v considering the have diffrent crosmembers.. can you post pics of yours?
also his are not solid, looks to me they use ls mounts. theres no way your 8v kit will bolt in a 16v subframed car as they are diffrent unless you have pics of these mounts?
Old 07-05-2012, 05:20 PM   #9
kendogg
V8 Guy
I'll hopefully have pictures next week, I haven't been able to get to the shop in a few weeks. I have a cad drawing, and a single picture of the prototype arm I can post, 1 second. As far as I'm aware, if they aren't finished at the steel shop, they're at or on their way to the powdercoater.
And here is the JTR page showing a few different cars, all using the same kit - which is the same kit that bolted onto my 960 subframe. '85 740 would be an 8V car, right??
http://www.jagsthatrun.com/Pages/Volvo_700_V-8.html
Old 07-05-2012, 05:26 PM   #10
2fast242gt
2fast242gt's Avatar
just to make you aware. JTR is only chevy 350 stuff...
Old 07-05-2012, 05:28 PM   #11
kendogg
V8 Guy
Doesn't make any difference when referring to the way it attaches to the subframe. And yes, I'm fully aware of that - I own their kit, used it with a set of LS adapter plates, and realized how poorly it fits with an LS, hence why I've developed this kit.
Old 07-05-2012, 05:38 PM   #12
2fast242gt
2fast242gt's Avatar
well if your not going to bother realizing there is a diffrence in the crossmembers and acutually end up selling to a b234f owner what are you going to tell them?
b234 crosmember
http://forums.turbobricks.com/showthread.php?t=232016
Old 07-05-2012, 06:00 PM   #13
kendogg
V8 Guy
b234 crosmember
Unless the mount locations are narrower, see where those 3 studs are sticking up? Thats where the factory motor mount attaches. Mine will fit wonderfully
Old 07-05-2012, 10:34 PM   #14
Volvo244GLE
Volvo244GLE's Avatar
b234 crosmember
he can tell them to cut off the mount for the left hand engine mount. that is the only difference. the cross members are otherwise the same. I helped convert a 940 8v to 16v by welding on the additional mount, and subsequently that mount was cut off again when it was converted back to 8v.
244GLE Project - The fun daily driver. Rebuilt B23, ported 405, 37.5 exh. valves, BMW oil squirter's, MS2e, VX3 cam, King Springs, Bilstein HD's, upper+lower chassis braces, 26mm Falcon front sway bar, 21+19=24mm rear sway bar, SAAS bucket seats, hi flow rear muffler, almost every factory option.
164 Project - The impulse buy
242GT Project - who likes rust?
Volvo244GLE is offline   Reply With Quote
Old 07-06-2012, 01:09 AM   #15
740volvo
The CM's are different for the 16v engine cars, one mount is on the CM and the other is on the engine, unlike on the 8v CM's where both mount are bloted on to it. Yes, but what about the other side?? Only on one side though.
740volvo is offline   Reply With Quote
Old 07-06-2012, 01:59 AM   #16
shaved240
body work hell
shaved240's Avatar
the moment we've all been waiting for guys!!!
http://media.tumblr.com/tumblr_lizoavPjKZ1qexvtu.gif
242 turbo:b230f+16v, Holset HX40, Getrag
Old 07-06-2012, 02:12 AM   #17
Angus242164
Angus242164's Avatar
Looks like a nice product!
760 V6 crossmembers are different again, they have two small pieces which can be cut off with a grunder if fitting a 4 cylinder, or these LS mounts.
Originally Posted by Dauntless View Post
Boost FTW.
It's great finally having a car with air conditioning!
I have over 275 parts for sale to suit 100, 200, 700 and 900 series Volvo's, for more info see: http://zyrex.org/gallery/Cars/acw/volvoparts/
Updated May 12th 2013.
Angus242164 is offline   Reply With Quote
Old 07-06-2012, 02:34 AM   #18
DNAsEqUeNcE
†500DollarSparkMap
DNAsEqUeNcE's Avatar
Well it looks like it's been answered before I could chime in.
Matthew 10:28
And fear not them which kill the body, but are not able to kill the soul: but rather fear him which is able to destroy both soul and body in hell.
Originally Posted by Karl Buchka View Post
Any ECU, when improperly wired, tuned, or installed will be unstable and unreliable.
Long live the pen15hood.
DNAsEqUeNcE is online now   Reply With Quote
Old 07-06-2012, 03:14 AM   #19
Super Matty P
Das Bear Juden
Super Matty P's Avatar
I'm pretty interested in doing an LS-swap in the volvo until I did a cost v.s power comparison. I think for what I'd spend on a power-train and wiring and troubleshooting I'd just invest that same amount of cash into my 8v and make more power with less weight. I guess if I ever inherit a wrecked z28 or something I'll think about it more but for now I'm going to pass.
after I heard Lil wayne's lyrical talent of "I gots ten toilets, I can **** all day" I now understand why he connects with the youth of today.
Super Matty P is offline   Reply With Quote
Old 07-06-2012, 03:23 AM   #20
2fast242gt
2fast242gt's Avatar
Ls1 weighs less than a 8v if not its about the same
Old 07-06-2012, 03:49 AM   #21
Super Matty P
Das Bear Juden
Yeah if you get one that's all aluminum but then the price jumps way up. The iron-blocked truck engines are much less expensive though. I've been cruising craigslist and pul-a-part for a day or so on this.
Old 07-06-2012, 07:18 AM   #22
stylngle2003
stylngle2003's Avatar
get an alloy 4.8 truck motor for ~$800 with harness, add a cam and snails, profit.
escargot, indeed
-Billy
1993 945ti "titebox" (DD)
1985 744GLE (perpetual +t project)
1996 Chevrolet Tahoe Vortec 2WD
1990 Mazda Miata track toy
Old 07-06-2012, 01:12 PM   #23
kendogg
V8 Guy
I like the swap for a few reasons. I LOVE the low-end grunt that you will never get with a boosted 4. I love the availability of cheap go-fast goodies, the range of very, very complete tuning software thats available for the stock ECU without having to get real crazy. And I love the sound Of course, there are other reasons too, but it's really personal preference is all.
Old 07-06-2012, 01:18 PM   #24
2fast242gt
2fast242gt's Avatar
you said ls swap not me all ls motors are aluminum. i myself am using a lq4 the iron 6.0
Old 07-06-2012, 01:37 PM   #25
kendogg
V8 Guy
In the grand scheme of things, all 'LS-derived' engines are considered an LS. Be it an LQ4/LQ9, an LS1, or an LS6. They're all Generation III GM V8 engines. Mine is an LM4, aluminum 5.3l.
