Hello
going to pick up parts tomorrow for my +turbo project (1990 245) and the donor car is a 1991 740 turbo. Have been reading many forums and threads and I see some great writeups for a 2.2 to 2.4 ezk etc.. but not much for a lh2.4 to lh2.4 - are there any wiring issues for the ecu or ezk? - how much of the ezk wiring do I need? i see the 2.2 conversion needs some extra bits.. - do i need the amm from the 740 or will my 240 stock amm work? - do i need to convert to 850 injectors or will the stock ones work? (not interested in using any resistor packs etc... I'd just rather buy new injectors that work if needed) - can i reuse my current intake manifold or is there a difference and a need to get the turbo intake, whats the difference? here is my parts list, anything missing? - Turbocharger - oil feed and return lines for turbo - exhaust manifold - intercooler and all of its piping - brakets and retainers for the intercooler and radiator, - ezk and ecu - ?? thanks Gord
----------------- Last edited by 542; 07-06-2012 at 11:44 PM.. |
ARRRRHARHAR
![]() Join Date: Dec 2002
get the 850 injectors and the lh & ezk computers from the turbo car. should plug in and just work like that.
"They bum rushed them in their own crib, they drank all their beer, they partied with their ladies and they left with the trophy" Megasquirt Tuning! Plug and play LH 2.4 Megasquirt, now with stealth mode! ported volvo heads |
ARRRRHARHAR
and it's 850 turbo 'orange top' injectors you want
#4 |
Hello 542... Doing a similar thing soon, but just curious: How are you going to do your oil return?
'93 245t - DD / Project '09 V50 2.4i - The Familymobile |
#5 | |
I have the donor car plumbing but not sure yet, I've been reading re the oil pan weld bung or oil pan drill method. I do have access to the donor car oil pan so maybe I'll take that off and experiment with it. Any other members have an elegant solution? Has anyone done a clean job of drilling the block somewhere on a b230 (1990 245)? Not interested in doing a hack temp type job jb weld. Cheers, Gord |
#6 |
Anyone used a remote oil filter housing and somehow tapped into that to feed the turbo oil instead of going the oil pan drill/weld route? In my initial readings it would appear that as long as I stay below the level of the turbo for gravity I should be ok?
anyone actually done this and can recommend the remote filter setup? Cheers, Gord |
| Thread Tools | |
| Display Modes | |
