Old 07-29-2012, 12:41 AM   #1
volvoboy90
volvoboy90's Avatar
Default IPD Sport exhaust...
Hello all! Well my shortened exhaust on my 89 failed me yesterday with the end of the catalytic loping off, and sounding like a lawnmower... So I am looking at replacing the whole thing since I know there will be no separating the catalytic pipe from the resonator... For 30 dollars more, I am looking at IPD's sport exhaust... Reviews look good, but I am wondering if anyone may have some better ideas... my budget is extremely confined, I am nearly fainting from looking at $335 to replace the cat and back.
Originally Posted by 92Sedan View Post
Alright, however I am curious to know how they handle without their sway-bars.
Originally Posted by TrickMick View Post
like a squid on shore leave after a 9 month cruise...
volvoboy90 is online now   Reply With Quote
Old 07-29-2012, 09:31 AM   #2
TrickMick
TrickMick's Avatar
within the last month I sent the "DIY SPORT EXHAUST" stuff to a
fellow TBrix fettler....can't remember if it was a PM or an "off list"....
if he sees this maybe he can "copy to this thread"??
I had all of the "genuine part numbers" listed as well as all links tested....
hmmmm....
In a closed society where everybody’s guilty, the only crime is getting caught. In a world of thieves, the only final sin is stupidity.
TrickMick is offline   Reply With Quote
Old 07-29-2012, 09:37 AM   #3
Go to the JY and jank a 60mm one off of a 240T for $35.00.
It's what we do in Cali.
Originally Posted by Ricardo Montalbán View Post
Be careful what you wish for.
Old 07-29-2012, 09:38 AM   #4
volvoboy90
volvoboy90's Avatar
Just looking for the best bang for my 350 dollars, lol. Getting a magnaflow cat for less than a hundred and Ipd wants 235 for the sport exhaust after ship.
Old 07-29-2012, 09:39 AM   #5
volvoboy90
volvoboy90's Avatar
And unfortunately no jy's close to me here in the rust belt.
Old 07-29-2012, 09:44 AM   #6
Somebody had a new one in for sale the other day.
Did you even search bro?
Old 07-29-2012, 09:51 AM   #7
volvoboy90
volvoboy90's Avatar
I searched... It sold.
Old 07-29-2012, 09:52 AM   #8
Old 07-29-2012, 09:55 AM   #9
volvoboy90
volvoboy90's Avatar
I searched Ipd sport exhaust and it popped up... A few days late, I'm afraid.
Old 07-29-2012, 09:56 AM   #10
beigebricker
beigebricker's Avatar
I got a good setup from fcp groton. Its a 240 turbo muffler, under axle pipe, intermediate pipe and a 1980 240 non turbo header pipe (has longer secondarys). All u need to do is get a 2.25" to 2" pipe adaptor from autozone and weld the header pipe to the intermediate pipe. This setup is better than ipd, bc that id what i had on there before, and its cheaper.
1987 244. Hydras, Manual Steering Rack, Straight Ball Joints, 28/25 Sways, Adj Endlinks, B&G Springs, GT Plates, Billy HD Fronts, Koni Rears, Boxed Control Arms, Poly, Braces, Adj Panhard Bar, adj torque rods
B23 w/ flat tops. M47, 3.73 gears. B21 valvetrain in 530 head. No A/C, No Pwr Steering, K&N Panel Filter, Airbox Mod, K cam, pre 81 head pipe, 240 turbo exhaust no cat, LH2.2, Trunk Monkey.
Tehboh Wheelz
beigebricker is offline   Reply With Quote
Old 07-29-2012, 10:15 AM   #11
volvoboy90
volvoboy90's Avatar
Hmm..... I'll look into that. The welding might be a problem, though.
Old 07-29-2012, 10:20 AM   #12
Most exhaust shops will tack something together for you for $30-$50.
Old 07-29-2012, 01:17 PM   #13
smokeyfan1000
Owner of a Loyal Pit Bull
smokeyfan1000's Avatar
IPD 240 Sport Exhaust is about as cheap(money wise) as one can do an *ALL NEW* cat back exhaust system on a 240.
Back in 1997 it cost me 200 bux for cheapo muffler shop cat back 240 system with universal muffler and all in 2"OD pipe, at the local "Muffler Shop". Fit was poor, they snapped a ex. mani stud, and the Universal muffler was pretty damned restrictive too.
If you plan to keep the car 5 more years or more, an IPD Sport ex. system is about as cheap as it gets (money wise) and it's mandrel bends & appears to me to be pretty good quality kit IMHO. (I bought one & sold it in FS)
And you won't have to worry about possible deadly exhaust leaks, or passing state inspections due to bad ex system.
Buy a MagnaFlow 53000 series cat, as this series is very close to same dimensions/size as OEM cat, and is available in 2"/2.25"/2.5" in/out pipe diameters. I bought my 2.5" cat from www.summitracing.com *AFTER* looking up the part number on MagnaFlow's cat website page. Here is the link for you. > http://www.magnaflow.com/02catalytic...IC%20CONVERTER
Pay attention to the location of your 240's Oxygen Sensor as Volvo moved it's location over the years a bit. On my 91 LH 3.1, the OEM OS location was in the cat itself. And consider replacing the OS while you're at it. Get a BOSCH unit.
Most very early 240s have OS in ex. mani and in header pipe/before the cat in "mid years" 240s, and as mentioned in cat on some LH 3.1 equipped 91-93 models(IIRC)
You can determine LH 2.4 or LH 3.1 by VIN number. Or by just looking if you know the diffference.
Also inspect your header pipe closely especially the welded on bracket spanning the 2 secondary pipes that allows it to be bolted to the bell hsg's bracket.
They love to rust/break there.
If needed a OEM Volvo header pipe is BEST, as aftermarket one's are made poorly/very restrictive in the "collector" portion of it I have pics of how restricitve a Starla header pipes collector is if needed
I opted for 2.5" SS custom system though. My custom set up cost me waaaaaay more than 200+ shpg though
Seriously afflicted with CVOCD.
Link to my build thread : http://forums.turbobricks.com/showthread.php?t=203083
Link To My Oil Temp Sender Drain Plug Thread: http://forums.turbobricks.com/showth...=smokeyfan1000
Link to my B&S Feedback http://forums.turbobricks.com/showth...=smokeyfan1000
smokeyfan1000 is online now   Reply With Quote
Old 07-29-2012, 01:46 PM   #14
volvoboy90
volvoboy90's Avatar
Just replaced the header pipe last year, and the o2 was in the old header pipe, so I had to have one welded into the one I bought... What I am looking at is a magnaflow cat... http://cgi.ebay.com/ws/eBayISAPI.dll...p2045653.m1253 I just had to buy one for my mom's 93 240 and it worked perfectly. All I needed to know, though, smokey. Thanks a bunch for all of the responses, guys.
Old 07-29-2012, 02:03 PM   #15
smokeyfan1000
I bought that one 1st exhaust "go around" I did on my car. It didn't fit at all for me. Bends didn't work for mine. Seemed to be welded to pipe at wrong "degree"................when bolted to header pipe, the cat's pipe faced down..............
The universal cat 53000 series cat in 2" will work if welded on. You're likely going to have to have some welding done anyway, But try it if you like...
If I were you, I'd buy the universal 53000 series in 2" and have it welded on to fit, doing away with one of the flanes, as they are not available separately from Volvo. You'd have to cut the ones off your old OEM Volvo cat, and weld them to new cat to keep it a "fully bolt on" cat. Trust me you're gonna have to have some cutting & welding done even with the "OEM fit cat" and IPD system
Or buy the 2.25" cat and have it welded on after I'd also had the 2" collector swaged to close to 2.25" to fit the 2.25" IPD System, and do away with the IPD kit's 2" to 2.25" "funnel pipe" for added exhaust flow.
But that'll cost more $$, unles you can swaged & weld it yourself.................
Old 07-29-2012, 03:16 PM   #16
nate2k5
the ipd kit is the starla kit with the first muffler removed and an added straight pipe. nothing fancy or free flowing.
nate2k5 is online now   Reply With Quote
Old 07-29-2012, 04:06 PM   #17
smokeyfan1000
The IPD 240 Sport Exhaust is 2.25" mandrel bends using a Starla Turbo muffler.
I'm unsure if Starla makes the same complete system or not. Stock n/a pipe diameter is 2", and IPD kit is 2.25.
OEM Volvo 240 turbo exhaust is slightly larger diameter than 2.25.
Old 07-29-2012, 08:48 PM   #18
volvoboy90
volvoboy90's Avatar
From what I could see from the pic on the ebay listing I pulled up, the flange looks likes it matches in angle with my current header pipe... I was slightly concerned since My mother's flange on her header pipe was free and spun to conform and mine is welded solid... I guess I will have to pull the header pipe so I can cut those darn flange bolts loose. The order for IPD goes in on Tuesday. Wish me luck!
Old 07-29-2012, 10:19 PM   #19
smokeyfan1000
Looks can be deceiving The OEM header pipe fooled me, as I figured it was just like the Starla in the beginning. Knowing what I know now, I would have started with & then modded an OEM Volvo header pipe, but what I ended up with is as good or better.........
FWIW, a OEM Volvo header pipe's collector is less restrictive than a Starla header pipe is inside the collector.
Likewise a true 4-2-1 header (SAMS 4-2-1 header is a good example here) keeps pretty close, if not a total 100% of it's secondary pipe diameter compared to the more(compared to SAMS) restrictive OEM Volvo or Starla header pipes.
But you are correct bout the Starla's rotating flange for cat, vs the OEM Volvo's welded flage. The Starla flanges looks like a bad leak just waiting to happen IMO, and why I cut it off and welded cat to header pipe, but the "cat back system" bolts to cat.
It's what's inside/what you can't see until you cut them open that hurts performance on the Starla header pipe
I modded my Starla header pipe because of this bad restriction.
Also, collector outlet needs to be as close to 2.25" diameter as possible to make the most of the IPD Sport Ex. System.
OEM header pipe, has all mandrel bends and both secondary pipes dump into collector keeping thier almost all of their same "upstream" diameter (primary pipes are actually the cast iron manifold part on stock n/a system, I am using " 4-2-1 racing header terminology" here)
SAMS 4-2-1 header of course has all mandrel bends & as mentioned above the SAMS 4-2-1 header keeps 100% of it's secondary pipe diameter inside the collector compared to OEM Volvo or Starla header pipes.
The Starla header does not have mandrel bends & it's secondary pipes are reduced to exactly 1/2 their original "upstream" size inside the collector ..here see for yourself, here's what I found when i cut open the Starla pipe .............
And I plan in the near future to mod my secondary pipes & collector again, to make it like the SAMS 4-2-1 header's collector is
Looking into Starla header pipe's collector from the secondary pipe's ends
OEM collector looking in from secondary pipe end. (and thanks to 1983_240 for this pics):nod:
FWIW, here's pics of my current header pipe mod, 2.5" in/out MagnaFlow cat and 2.5" SS mandrel bends custom exhaust using 2 different length & outside diameter cased MagnaFlow straight through mufflers, & I used an "L" taipipe as opposed the the OEM "S" style tailpipe on my 91 244. And it is a rather very expensive system too.
I just prefer stainless steel. And I wanted "NO RUST" as I'm a detail/clean freak. LOL This sytem flows great, and is pretty reasonably quiet, but with a "sport" sound.
In case you're wondering......RJ's Custom Piping, in Raleigh NC built this sytem for me, per my specsifications
Old 07-29-2012, 10:38 PM   #20
impolvo
impolvo's Avatar
they hack em all off here, sux
my feedback: http://forums.turbobricks.com/showthread.php?t=221335
Originally Posted by Stephen View Post
Thats why you get a mans car... A 740
impolvo is offline   Reply With Quote
Old 07-29-2012, 11:02 PM   #21
volvoboy90
volvoboy90's Avatar
The unfortunate thing here is my restrictive budget and no welding skills, nor access to a welder or anyone who would do it for me on the cheap/free. I just need at least something that will work for now, and at least come close to doing it right. I went and looked at the flange on my mom's 245 and the flange with the cat attached is the exact same way of the orientation of my flange so it SHOULD work since I will be buying it from the same seller what a coincidence, Summit Racing's store on ebay.
EDIT: Very nice welds on that exhaust btw.
Old 07-29-2012, 11:07 PM   #22
smokeyfan1000
And if not hacked off, they are crushed by the forks on the front loaders they use to move the cars around the yard at most JYs in NC.
Old 07-29-2012, 11:47 PM   #23
smokeyfan1000
They are TIG welded. Just use an OEM volvo header pipe, the Starla one SUCKS, the diffference is INSIDE the collector.
Old 07-30-2012, 10:47 AM   #24
Ryan_R
IPD kit is Starla last I checked. Starla simply is junk, IMHO.
OEM Volvo cat back is best.
Any reason NA performance folks don't run EGR stuff?..... not gonna be as good as custom, but also not as pricey.
-Ryan
Athens, OH
1987 245 -- 330K -- Dog Waggin'
1990 245 -- 150K -- Looks nice when it's wet
1991 745 -- 320K -- Regina powered B234F!
http://www.ohio.edu/people/ridgely/Volvo_docs/
Ryan_R is offline   Reply With Quote
Old 07-30-2012, 02:19 PM   #25
smokeyfan1000
-Ryan
Have you priced an OEM 240 Volvo cat? I did, $800.00+at dealership,(for my 91 244), hence the the MagnaFlow cat recommendation. Not bad for less than 80 bux, IMO
Also Starla header pipe sucks, OEM header pipe is much better made
The n/a 240 IPD Sport Ex system is 2.25" diameter pipe and the piping is made well and uses mandrel bends.
The "ordinary' Starla systems for n/a 240s are 2" pipe. The IPD kit is a pretty good deal at 200 bux + shpg IMHO. You're not gonna save any more having a mufffler shape make it for you.
Also, if I used the n/a IPD 240 2.25 Sport Exhaust, I'd utilize a 2.25" in/out cat & 2.25" MagnaFlow or other straight through muffler & ditch the Starla turbo muffler. But that'll require welding some hangers/rods on the MF muffler.
As in the usual n/a 240 exhaust system thread goes, here on TB, ...The OPs never have the $$/welder/desire to do it in a fashion where the most possible gains can/will be seen It's always a "buy cheap, bolt on & run deal".
