Old 08-14-2012, 08:24 PM   #1
940guy
940guy's Avatar
Default name this fitting!
got a large oil cooler from a older benz and cant find the correct size fittings.
93 944t
b230+16v+holset hx35 +75shot
project
http://forums.turbobricks.com/showth...68#post3449268
Originally Posted by Stephen View Post
i think the people upstairs are having sex -_-
940guy is offline   Reply With Quote
Old 08-14-2012, 08:41 PM   #2
burstcurse
its from a benz to its metric. and the shape of the flare is rounded like a bubble
so im going to say its a metric bubble flare you can measure the size in milimeters and it will be a xmm metric bubble flare.
good luck trying to get new fittings in the USA. ps you cant get new fittings but you probably already knew that.
burstcurse is offline   Reply With Quote
Old 08-14-2012, 08:48 PM   #3
cosbySweater
cosbySweater's Avatar
get a an fitting welded on
1988 Volvo 244, B21ft, unitek stage 4 531 head and cam, ms2v3.0, "gt35" Aw71
http://forums.turbobricks.com/showthread.php?t=223946
From what I can gather around here, it's de rigueur to run 700# front springs / 500# rear springs, and sawblades to do some parking lot racing, and then part and crush the Volvo and move onto BMW's.
Old 08-14-2012, 09:02 PM   #4
Volvorules
Has a Built Trans!
Volvorules's Avatar
Ralph
Rob
Volvoless
how psi a stock can support?
Originally Posted by MrBill View Post
not even thieves like 7/9 series.
Volvorules is offline   Reply With Quote
Old 08-14-2012, 09:08 PM   #5
2fast242gt
cheeseland highschool kid
2fast242gt's Avatar
Carlos
1980 241gt
*6.0 lq4 swaped*
Old 08-14-2012, 10:52 PM   #6
donalson
donalson's Avatar
sorry don't know the name but it's pretty much the same thing volvo used...
Project [S]wede-10... volvo powered S-10?
'91 945ti (new family hauler) - 16t | Hi-tuning MBC | TLAO fuel chip | Hi-Tuning ignition chip | Browntops | 3" AMM | DIY CAI | Mallory coil | cravingboost plug wires | PBR metal master front pads | needs a cam and exhaust
donalson is offline   Reply With Quote
Old 08-14-2012, 10:56 PM   #7
olov
doing something stupid
olov's Avatar
weld a new one on :P
88 244 - m47 - on the bumpstops - 366k on the clock
83 245t - m46 - the green monster - 130k - 260whp/280tq with a lot on the table
94 z28 - t56 - pull me over red - 100k
olov is online now   Reply With Quote
Old 08-15-2012, 10:29 AM   #8
One side of the Volvo oil cooler hose is a light-12 and the other is an English-8 or perhaps a light-8 and English-12 I can't remember excatly what the hose guy said, I did have to go to a metric hose place to have one made.
80 DL/GT B21F turned into a B21FT, lh2.2, M47, G80
Old 08-15-2012, 07:24 PM   #9
vvpete
On the Volvo hose the flare seal is separate from the steel tubing, it's not welded or crimped or permanemtly on there. I bought a few compression ferrules at a local truck hydraulic shop to repair the 740 oil cooler I have on my 245, and just cut the old off and sleeved the new ferrule onto the old steel line, which is 12mm OD. Once the new ferrule is tightened onto the line it is crimped onto it.
You can cut them off and put new ferrules on the steel tubing if there's enough line left that wasn't crimped in the first place. Or you can have a shop cut the line and weld on a new end then put a new ferrule on it.
vvpete is offline   Reply With Quote
Old 08-15-2012, 08:27 PM   #10
ryanfay
more bounce to the ounce
ryanfay's Avatar
DIN37
Originally Posted by falunbrick View Post
You are a walking facepalm
ryanfay is offline   Reply With Quote
Old 08-15-2012, 08:52 PM   #11
adam young
The theads on the Oil Cooler are M22x1.5 and it takes a 1-1/16" wrench on the Oil Cooler Line Nuts.
adam young is offline   Reply With Quote
