Old 09-05-2012, 01:55 PM   #1
Anomorato
Default Volvo s80 T6, 2.8. electrical problem, car won't start at times
I have a 1999 volvo s80 T6, 2.8. About a month ago I went away for a couple of weeks, gave a family member the keys to run it every few days. Came back and the car wouldn't start, the battery was dead (car alarm flash lights had went off one night and the battery drained). I replaced the battery with a rebuilt one, was fully charged and in good working condition. Soon after that I started having the following problem:
Car all sudden wouldn't start, cranks, theres power but wouldn't start until after a few tries and waiting on it a few minutes.
When it does start, sometimes it doesn't start or run normally, what I mean by that is: dashboard (odometer, speedometer, temp, gas all stop working n get zerod out), car feels very rough (rough idle, as if its running on high rpm and feels like its dying out at times) .
Changed the spark plugs, didn't help.
Volvo mechanic put on scanner, no relevant codes showed up, said it might be the instrument cluster? But I.doubt that it is, since the problem is more then the display gages.
my temporary solution has been disconnecting n reconnecting the battery, which seems to reset the electrical issue. The negative battery cable is loose, will need to change it because its not tightening well.
Whats your take on this??
Thank you
Anomorato is offline   Reply With Quote
Old 09-05-2012, 02:12 PM   #2
volvo944ti
first things first get a good terminal on there.
i had one that sent me for a loop. would start and run fine. shut it down wouldnt' start untill you disconnected the battery for about 5 minutes. spent lots of time fault tracing. in frustration i did an ecm reload. customer hasn't had the issue in over a year. not saying that is your problem. just a possible cause if everything else tests o.k.
i've never had a cluster cause a no start. the intermittant cluster issue's are normally solder joints on the chip in the cluster. bba does rebuilds on them.
the alarm could be the alarm siren in the right inner fender. they are prone to water intrusion and causeing all sorts of issues. basically anything controlled by the uem like the sunroof could have issues.
also how much amperage is your starter drawing. i've had bad starters still crank but cause no starts. (1st time i saw this, it was recomended to try by the local dealer we get parts from)
also any etm codes on that sheet from the volvo tech?
lots of other things it could be without seeing it in person.
volvo944ti is offline   Reply With Quote
Old 09-05-2012, 02:15 PM   #3
496truck
496truck's Avatar
It's a 99 S80 T6. If you can get it started, running and driving, drive it straight to the scrapyard. I think they are paying about $180 per ton delivered.
Seriously, though. I highly doubt there were no codes. If you want to throw parts at it, start with the ignition switch in the column, back side of the lock cylinder. They have been known to go wonky and cause strange electrical issues like that. After that, don't get me started on everything else that could be wrong with your 99 S80 T6.....
Oh, and I agree on the siren also. We replace those all the time.
90 745 Turbo, gutted and cut stock airbox, 15g, S70 T5 white injectors, TLAO chips, RSI stg 1 cam, custom 2.5" cat back through a cheapo Summit turbo mufflerator
My Build Thread
87 GMC K5, 4" lift, 35s and a whole bunch of other stuff that Volvo people don't care about
496truck is offline   Reply With Quote
Old 09-05-2012, 05:53 PM   #4
Anomorato
could any of the following be causing this? Ignition coils, voltage regulator, CEM module?
I know this sounds pretty broad, but it could be one of several malfunctions, only if you ran into such a particular problem before you might have a clear what it is.
Ill get the codes the tech got on the scanner in the meantime
, although they were unrelated to the problem ( they were related to o2 sensor, heater, tail light, had cap etc)
Thanks for yurt inputs guys
QUOTE=volvo944ti;4305433]first things first get a good terminal on there.
lots of other things it could be without seeing it in person.[/QUOTE]
Old 09-06-2012, 01:59 PM   #5
496truck
496truck's Avatar
You could throw parts at that thing all day long and not be any closer to solving the problem. That car has an overcomplicated electrical system. Without a doubt, the faulty siren module killed the battery initially. Have you replaced that? You also said you replaced the battery with a "rebuilt" battery and you have a faulty cable end. That car is HEAVILY DEPENDANT on a good electrical system. You NEED to have a good battery as well as clean and tight connections at the sources (battery, alt, starter) or you will be chasing ghosts.
1st suspect is the rebuilt battery and faulty cable end(s). Fix those with new cables or just ends and a good "NEW" battery. Then replace the siren module as that can not be removed or bypassed from the system and is currently causing you problems. Start with that.
S80s are nothing like the older cars. They can not be hacked back together with cheap fixes, junkyard parts, educated guesses, duct tape, etc. Not saying this to sound like a dick, just giving you the truth. I have been dealing with them since they were brand new in our showroom.
Old 09-14-2012, 02:35 PM   #6
volvo944ti
didn't volvo come out with a download to remove the siren module from the system. or was that later models?
agreed s-80's can't be hacked. they suck and with the problems he's having probably is going to cost more than the car is worth. mainly due to not teh end of his problems by a long shot.
Old 09-15-2012, 09:09 AM   #7
496truck
496truck's Avatar
Well, I just went into the catalog and found a software for "Alarm Remove" part number 9438408 and would cost $20.27 plus whatever the dealer wanted to charge for labor, we get 1 hour. This is new to me and my lead tech isn't here today, being saturday and all, so I'll look into it next week.
Old 09-15-2012, 10:50 AM   #8
RP80242GT+T
R-Sport Cluster Guy
RP80242GT+T's Avatar
A gallon of gas and a match. Problem solved.
RP R-Sport and OEM Stock Instrument Cluster Restorations, Sales, parts, service, and customizing. LED Conversion Services
Volvo GT Stripe Kits.
1980 242 GT Turbo
2006 Mini Cooper S GP number 1148
1989 240 Wagon " The Beast" Daily Driver
RP80242GT+T is offline   Reply With Quote
Old 09-15-2012, 03:05 PM   #9
professor245
professor245's Avatar
LOL, today I was at my Volvo mechanic, great mechanic...and we was talking about Volvo's and electronics...at one point he said
''Man I know their electronics by hard, but '99 S80 T6 that's the worst year, it almost unfixable...it has problems with EVERYTHING''
Then I came home and saw this thread...
To OP, not meaning to rain on your parade or discourage you in fixing your car...but be careful..
''I was so ugly the doctor slapped my momma when i was born!
Then he took out his pocket knife and cut off my horns...''
WAYLON
My seller/buyer feedback
professor245 is offline   Reply With Quote
