Old 12-06-2012, 05:20 PM   #1
Andreas
Andreas's Avatar
Default Volvo 242 2,9 16v widebody 700+hp build
Warning, get ready for a ****load of pics and lots of bad english :P :P
hi guys and girls, my name is Andreas and im from norway! Always been a volvo guy and been trough my sheere of old bangers :P Well, im not one of those how only like volvo! i also love the good old Audis with the boxy 90s styling i happend to also own a 89 Audi V8Quattro, 4,2 6 speed manuel, with i have done some small mods to, engine wise.. miled down the pistons to 9:1 comp and made a couple of manifolds and bolted on a couple of garreth tb0368 from volvo 740 turbo! with Nira I3+ engine management it put down 385 hp and 630 Nm (nm at 3300 rpm!!) at just under 0,5 Bar of boost. plan to take it up to 1 - 1,2 bar when im finishd with my volvo project! enough audi talk?? :P
so, after a year or so with only sneaking around on the forums i thought id make a little build thread here :p What im talking about is my old brick ;) it started its life here in norway in 79. Then it was sold to a new owner in 81 with kept it until 2005! thats when i bought it!
Not so good looking, but i got it cheap, and there was close to 0 rust on the underside. Thats the important part! engine and driveline i dont realy care about :P
Did some small adjustments, looks 10x better if you ask me!
I also built a engine with some light mods like
-ported 531, 40/46 valves
-Kg 2t Camshaft
-KS pistons
-FK rods
-Tec3 ecu
-Ebay / china manifold
-Rosenkranz Race turbo
-Bmw 262 gearbox
never dyno`d it, but i think somewhere around 300-350 hp should be a good estimate.
The car rearly went straight so i was happy :P
I have spent the last 4 or so years on more custom work. since i dont have the patience to wright the whole story and add like 100`s of pics, ill give you the short story!
What i have done/ doing to the body:
- -Cut and welded the front fenders so they are built out about 3 cm
-Rolled the lip flatt to get as much wheel clearence as i can
- -Rear panel (behinde the rear wheel) as been lowerd 5 cm
-Rear wheel Arc has been cut out and replaced with Golf mk1 arches, raised 5 cm
-Rear fenders has been cut below the window and filed in to widen the car, about 4 cm
-Streched the rearpanel a little extra at the wheel arces
-And the Golf arches is a little wider the the volvo ones, bringing the total widening up
to 8cm (3" to you US guys :P) on each side!
- -Custom hood :P
- -Custom "one pice" bumpers
- -Volvo 7 series rear axle adapted to fitt the 200 series rear subspension
-Gaz adjustable rear coilovers
-Myranes Adjustable tourqe rods
-Myranes 40- 110mm lowering Coilovers in the front++++
-Myranes top plates
What i have done and/or will do to the Interior:
- Sam Rollcage + some custom
- Sparco Pro 2000 seats
- Stack gauges
- Custom Dash (carbon)
Wheels:
rear
18x12 inch Rota GTRD 335/30 Pirelli Pzero Corsa
front
9,5x18 Rota P45r 265/35
All wheels is of the same designe. but not of the same colors, i have bought lots of powder paint in the bright red color!
:P
engine:
2,5 liter crack
16v ported head
custom intake with 4x 43mm Itb
Custom manifold
Bullseye S362 Batmowheel turbo
Sleeved cranckcase
drysump
custom rods and piston to get a good rod to stroke ratio
Cams: 275 degree dur, 11,4mm lift, solid lifters
Nira Ecu
4" downpipe, 2x2,5" exhoust
Goal: 700- 750 hp and around 900nm for now, but with a bigger turbo, 1000 hp shouldnt be a problem
My build..
cars: Audi A8 W12 6.0, 89 Audi V8 3,6 quattro, 89 Audi V8 4,2 twinturbo quattro, 79 volvo 242, Honda Cbr Fireblade
Andreas is offline   Reply With Quote
Old 12-06-2012, 05:27 PM   #2
Andreas
Andreas's Avatar
Default Volvo 242 2,5 16v widebody build PIC HEAVY!
Ill add a bunch of pics :P
Old 12-06-2012, 05:30 PM   #3
M.H. Yount
M.H. Yount's Avatar
Looks like a rear upper torque arm used for the motor mount.....just guessing though.
Old 12-06-2012, 05:35 PM   #4
Andreas
Andreas's Avatar
Servo, Opel
Old 12-06-2012, 05:37 PM   #5
Andreas
Andreas's Avatar
Gearbox:
Mid Vally Engineering 4 speed straight cut dogbox (Nascar)
Old 12-06-2012, 05:39 PM   #6
revolve40
big boostin' a B21FT
revolve40's Avatar
'06 S40 T5 - 1 - 2 - 3
'83 Volvo 242 GLT
Feedback
revolve40 is offline   Reply With Quote
Old 12-06-2012, 05:40 PM   #7
Andreas
Andreas's Avatar
Custom Water intake, since i dont want to boil my motor :P
Old 12-06-2012, 05:44 PM   #8
Andreas
Andreas's Avatar
custom pistons from Wiseco
Custom Pauter X beam, 158mm
Wiseco / K1 crack, 86mm = 2,5 l and its 300g lighter then the stock crank!
Drysump
Old 12-06-2012, 05:47 PM   #9
Andreas
Andreas's Avatar
LA sleeves, made custom sleeves for my engine :P
Old 12-06-2012, 05:49 PM   #10
Andreas
Andreas's Avatar
thats correct, with some poly bushes its not going anywhere :P
Old 12-06-2012, 05:51 PM   #11
hoggen
Drives 15.400Bhp!
hoggen's Avatar
Looks good
BTW, keep the NAF stickers on the windshield
hoggen is offline   Reply With Quote
Old 12-06-2012, 05:53 PM   #12
Andreas
Andreas's Avatar
Originally Posted by hoggen View Post
Looks good
BTW, keep the NAF stickers on the windshileld
haha, i should ducktape the service book from this car in the windshileld :P its been checkd by naf twice a year from 79 to 2003-4 ish :P
Old 12-06-2012, 06:00 PM   #13
hoggen
Drives 15.400Bhp!
hoggen's Avatar
My car has a similar history, 84' model, bought by previous owner when it was two years old. He kept it for 16 and then I bought it. Checked every year at the same shop in Skien and he kept all receipts for any parts bought.
Every oil change, oil filter and air filter receipt. Bursted the stock Volvo vinyl document holder...
/:Edit
And you have the snow cap! Digg! First one on the forum? (After me of course )
Old 12-06-2012, 06:12 PM   #14
FunkyStankyChicken
Rad Panda
FunkyStankyChicken's Avatar
This is awesome!
‘02 V70xc
‘96 F350
‘93 525it
‘88 325is
‘84 533i
‘79 242
FunkyStankyChicken is offline   Reply With Quote
Old 12-06-2012, 06:49 PM   #15
Bob
Away
Bob's Avatar
This looks awesome:
Bob is offline   Reply With Quote
Old 12-06-2012, 06:55 PM   #16
Old Iron
I Roll
Old Iron's Avatar
I'm not really a huge fan of wide body car, they always look awkward and way out there, but this thing looks really nice, very tastfully done. The body lines still look like they are in line with the original lines of the 240 body styling, except improved.
Nice job.
Your doing the 81+ European front end?
Turbobricked
Originally Posted by Anonymous View Post
No sarcastic replies from Redwood Chair necessary
Old 12-06-2012, 07:06 PM   #17
Andreas
Andreas's Avatar
Nice job.
actually, i agree with you! i dont like widebody kits and widebody stuff thats just glued on the side of the car! it looks stupid.. i tried to keep the volvo lines, just wider :P
if you look at the car from the side, and with your head at window hight, you`l probably not even see anything diffrent then the Golf wheel arches :P
81+ front yes, it fits the style of the car best! (my opinion at least)
Thanks for your kind words guys
Old 12-06-2012, 07:16 PM   #18
stevE85
Formerly 1983_242
stevE85's Avatar
Very impressive build. You really mean business...by sleaving a Volvo block and all. I can't wait to see more.
1982 244-"Ivory Blanco" GM L33/5.3L, T56, Mcleod twin disc, Gen 2 billet 7875, 44mm gate, 2.50 Hot/Cold sides, LJMS Stg2 turbo cam, PAC springs, H2O/Meth, 9.5psi/@13*, Etc.
stevE85 is offline   Reply With Quote
Old 12-06-2012, 07:47 PM   #19
Old 12-06-2012, 07:51 PM   #20
Andreas
Andreas's Avatar
Originally Posted by Bob View Post
This looks awesome:
hehe, thanks!
btw, notice the side mirror
Old 12-06-2012, 07:53 PM   #21
Andreas
Andreas's Avatar
hehe, it should be "bullet proff" now!
Old 12-06-2012, 08:22 PM   #22
pwschuh
Rolling...
Posting in epic build thread.
"No man would listen to you talk if he didn't know it was his turn next." E. W. Howe
Old 12-06-2012, 08:38 PM   #23
Old Iron
I Roll
Old Iron's Avatar
You have more picture's of when you widened it, did you cut and fill like the first picture? Or did you pound it out and then just fill in the under side of the wheel well like in the picture you showed. These cars were the stance I always wanted for my GT, but yours is really one up-ing them.
Old 12-07-2012, 04:56 AM   #24
Andreas
Andreas's Avatar
if you look at the weld just behind the door, you can see that i have filled in about 1-2 cm of steel there. and on the topp of the panel, i have filled inn up to 3 ish cm.
Old 12-07-2012, 10:25 AM   #25
slow240
Home Schooled
slow240's Avatar
well there goes my hopes of running p45Rs, i could never pull them off this well....
I'll polish your face
