Old 12-28-2012, 04:54 PM   #1
yorkadam
Default Bad reverse switch harness - diagram needed
I've got a 1983 volvo 245 turbo, manual transmission conversion...and the reverse lights don't work.
So I jacked/standed the car and tested the wiring AND reverse switch. After much swearing I managed to test everything...I now get the 'small hands help' comments.
Test results:
switch on transmission - OK
wiring harness from transmission to ?? - BAD/weak
reverse bulb - OK
bulb connection in the tail light - OK
Fuse & voltage - OK
So as best I can tell the wiring harness from the transmission to the ?relay? is bad...or maybe the relay is bad? Does anyone have diagrams of where the wire harness or relay are located?
yorkadam is offline   Reply With Quote
Old 12-28-2012, 06:25 PM   #2
vlvman
vlvman's Avatar
Check the site in my signature.
Robert
http://www.volvowiringdiagrams.com/
82 244DL, 2004 S60R AWD, 2008 S40 GF's
Had: 77 242 DL, 80 242 DL, 82 245 DL, 89 740 GL, 94 850T, 95 850 GL, and a 02 S60 2.4T
vlvman is offline   Reply With Quote
Old 12-28-2012, 06:44 PM   #3
Mylesofsmyles
There is no relay for that.
The wire from the trans switch goes right back to the lights
Old 12-28-2012, 08:34 PM   #4
yorkadam
Funny - after looking at the diagram my time cursing under the car was pointless. You can diagnose it from inside the car with the wire harness connector that comes from the floor and goes into the dash. Oops.
Appears to be faulty somewhere between the connector (H in diagram) and the tail light...I'll need more wires to be able to test the entire length of the circuit.
Old 12-28-2012, 08:49 PM   #5
vlvman
vlvman's Avatar
I bet it is at the tail lights, check for power at the left tail light harness first.
Old 12-28-2012, 09:15 PM   #6
yorkadam
I played the wire swap game on the rear tail light. The bracket and bulb work.
The issue is between the wire that goes to the left tail light and the ignition switch. I'll need some extra wire to see on which side of the harness connector (H) it is. There is an added complication with a remote lock system wired into the mix.
Old 05-08-2013, 12:20 PM   #7
yorkadam
Last update: Apparently volvo ran part of the wiring from the fuse panel to the transmission switch under the drivers feet somewhere. That wire was broken though the rest of the wiring to the tail light, switch, and ignition were good. I simply ran a new wire UP under the dash to get the power to the reverse switch.
