Old 07-14-2013, 06:17 PM   #1
Homer
OEMplus++
Homer's Avatar
Default Porsche Cayenne brakes on a 240? Sure
GROUP BUY HERE! http://forums.turbobricks.com/showthread.php?t=286247
Well. It works. Pedal feel is fantastic, firmer than stock 240. Modulation is excellent and its quite capable of throwing you into the dash. I haven't tried to lock up the 245s yet.
Details.
Front calipers. 17Z L and R from a 2005 Porsche Cayenne V8. 6 pot (330mm rotors)
Rear calipers. 2005 Porsche Cayenne V8. 4 pot
Master Cyl. 1.0625" bore from a 1994 Mustang GT
Rotors. S60R front and rear. Brembo.
Pads. OEM Pagids all around.
The adapters were designed by me. I'm considering doing a run of kits for this conversion. Overall the pricing is on par with the S60R brembo swap. Can be a little cheaper if you get lucky on ebay.
Because of the staggered pistons and the fact that on the Cayenne the calipers are mounted leading edge, I had to flip the crossover pipes and bleeder screws to retain the even pad wear.
Comparo.
Removing unneeded lines and draining fluid.
Always helping.
I notched the brake line holders so I can swap strut tubes when I fancy up the suspension.
Crossover line removal.
Rear 240 rotor with the rotor portion cut off. This retains the stock parking brake.
Trimming the backing plates to fit.
(The bleeder screw was just a dust plug)
The patient and owner.
Master Cyl.
Wat.
The only modification needed is extending the pushrod on the booster. ~.8"
The rear port is M10 bubble flare, front is M12 bubble flare so a reducer is needed.
Yes the triangle is coming out.
They're there. Hiding. Waiting.
-Jacob:
2017 allroad - Comfy DD
Old 07-14-2013, 07:43 PM   #2
Karl Buchka
That looks awesome! Good job!
Old 07-14-2013, 08:01 PM   #3
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Nicely done my friend! One of the problems with the R calipers is they are technically backwards and instead of crossover tubes they are plugged. Well a few of us tried and the plugs are impossible to remove. Glad this worked out!
Old 07-14-2013, 08:16 PM   #4
Corey
Corey's Avatar
awesome! i love this car
sig pic
'81 242 turbo
Corey is online now   Reply With Quote
Old 07-14-2013, 08:43 PM   #5
GTJordan
Been here for too long
GTJordan's Avatar
Do the outside edges sit more inwards then the s60r calipers? I don't really know how to describe it...
Old 07-14-2013, 08:54 PM   #6
Crazychopstick
(/// _ - )
Crazychopstick's Avatar
Location: Receiving Transmission from David Bowie nipple antenna
Wow
Crazychopstick is offline   Reply With Quote
Old 07-14-2013, 09:05 PM   #7
Lord_Athlon
Chuckie Blows
Lord_Athlon's Avatar
Ive never seen anything so amazing.
Great work.
Yet Asher here went with...
Old 07-14-2013, 09:54 PM   #8
Homer
OEMplus++
Homer's Avatar
I know what you mean. Outside face of caliper to outside face of rotor. Not sure. I've never had an R caliper in my hands. I can measure if you want though.
Old 07-14-2013, 10:07 PM   #9
ashvolvo
2 > 7
ashvolvo's Avatar
Well done. Looks super neat. Great conversion.
Likes good coffee & fast volvos. Builds stuff. Races stuff.
f: https://www.facebook.com/DvsPerformanceParts
twitter: ashd61 | w: http://www.dvs.net.au
1998 V70T5
2004 Holden Commodore wagon
ashvolvo is offline   Reply With Quote
Old 07-14-2013, 10:08 PM   #10
Homer
OEMplus++
Homer's Avatar
A few more pics.
Old 07-14-2013, 10:12 PM   #11
GTJordan
GTJordan's Avatar
I'd be interested in that measurement. Then see f someone with an R conversion could do the same. Or I'll measure on the next R that comes through the shop
Old 07-15-2013, 08:31 AM   #12
i'm surprised you still had the triangles until now.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 07-15-2013, 08:39 AM   #13
Karl Buchka
Road hugging weight. http://1.bp.blogspot.com/-e9Q1u-NH_A...4Mercury1a.jpg
Old 07-15-2013, 08:44 AM   #14
T101
I like starting projects
T101's Avatar
Could you provide further details on the adapter bracket?
1986 244GL, Engineless, Suspensionless, Interiorless
1994 850 Base 'BATWGN' 300K
1998 V70 XC, So many probs, 120K
Failure is a resource you can manage - Scott Adams
T101 is offline   Reply With Quote
Old 07-15-2013, 09:21 AM   #15
Originally Posted by Karl Buchka View Post
homers got that now with those rotors.
advantage kansas
Old 07-15-2013, 09:47 AM   #16
towerymt
the real Towery
towerymt's Avatar
Four door utility and two door styling...I like it!
Old 07-15-2013, 09:47 AM   #17
Homer
OEMplus++
Homer's Avatar
My car is roadable too.
Like?
Material is 7050 for the rears and 7075 for the front. They hold the calipers all good.
Old 07-15-2013, 09:49 AM   #18
T101
T101's Avatar
Scratch that, put me at the head of the line when you start producing.
Old 07-15-2013, 09:52 AM   #19
T101
T101's Avatar
Like?
I was guilty of skimming your post, did not read.
you made and designed them.
I have been trying to decide which way to go with my brakes.
Do you think this will fit under borbet type-e's?
16 x 7.5, 20mm et at the moment.
Typing on my phone on the train, excuse the brevity.
Old 07-15-2013, 10:00 AM   #20
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
Why aren't they painted a gaudy bright red?
Hello My Glorious!
Old 07-15-2013, 10:13 AM   #21
towerymt
the real Towery
towerymt's Avatar
Almost certainly no way they would fit under 16"s. Not without a smaller diameter rotor.
Old 07-15-2013, 10:17 AM   #22
JohnMc
JohnMc's Avatar
Awesomeness!!!
Random question: Does your spare tire still fit onto the car?
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 07-15-2013, 10:30 AM   #23
Homer
OEMplus++
Homer's Avatar
As towery said, they will most definitely not. 17s are a min.
I'm sorry I let you down.
Or stock 240 brakes
Awesomeness!!!
Good question, it will not. I've got a random 17" volvo wheel on the way. I'll have to get one spacer made. But it's just about the same price in the end as a S60R spare. I'd rather have the full size spare.
Old 07-15-2013, 11:14 AM   #24
Chuck W
Chuck W's Avatar
Excellent work! I like the tip for retaining the rear parking brake. I was looking at a couple options for brakes for the '77 when I get to serious wrenching on it, and that just might suit my needs.
Whole set-up looks great.
'78 264GLE
'97 854 T5 (Eventually to be 5spd)
'80 264GLE (B21FT/M46/MS) - SOLD '77 242DL (B21F/M45) - SOLD '75 245DL SOLD '85 244GLT DEAD
'83 Tbird Turbo (2.3T/T5/MegaSquirt)
My feedback thread
Chuck W is offline   Reply With Quote
Old 07-15-2013, 11:24 AM   #25
Gene_GaTech
Round Fender Spender?
Gene_GaTech's Avatar
fantastic work, great 240!
Project Vroom
round fender mender > round fender sender > round fender spender?
Current:
87 FJ60 | 02 M3
Past:
90 740T (R) | 89 760Ti | 70 1800e | 67 122s | 02 MX-5 SE
Gene_GaTech is offline   Reply With Quote
