- Jan 1, 2006
- Southern Maryland
It's MikeP's brown244 - Morley.
MS box is a Kenny Howard assembled unit. 2.2 board, ms1 chip
LH 2.2 block mount distributor.
Some sort of external ignitor. Probably BIP373, but I have a spare 960 ignitor. Not sure If I can just use one channel of the 3-channels, but that would be sweet.
From DIY's article:
MegaSquirt-I PCBv2.2 Mods Required:
Remove D5, D8, and R10. Also remove the jumper between XG1 and XG2.
Replace D8 with a 1K resistor. this is currently jumpered
Run a length of wire from XG1 to the right hole of D5.
Run a wire from the bottom hole of R10 to the top of R11.
Run a 750 ohm to 1K, 1/4 watt resistor from the right (5v) side of R23 to the negative (top) leg of D17.
Run a wire from the negative leg of D17 to X11.
That's it!
Thoughts?
From DIY's article:
That's it!
Thoughts?
