Old 08-22-2013, 05:45 PM   #1
BryantTF242
BryantTF242's Avatar
Default 240 LED dash light Q's
so I am looking into swapping all my dash and gauge lights in my 82 242 over to LED, I am on superbrightleds.com looking at what I could get, im guessing either one of these #74 or #24 will work for everything? I cant find any results in the search option on what others did and I know there are threads up about this. let me know of what I should get!
1982 242 Turbo - The Fun One, K-Jet, 3in Turbo Back, RSI Coilovers, BBS LM Reps, Awesome.
http://forums.turbobricks.com/showthread.php?t=280461
1990 240 Wagon
BryantTF242 is offline   Reply With Quote
Old 08-22-2013, 06:03 PM   #2
volvogeek
I wrote this up over on OVT, it's still a WIP but it's fairly complete:
I haven't seen this posted comprehensively anywhere, even though people ask about doing it fairly often. So here's what I've found you'll need to convert your 240 over to using LED lights (both interior and exterior). STILL A WORK IN PROGRESS.
Exterior:
You'll need 1156 and 1157 single element bulbs, plus a set of 1157 double element bulbs if you're running fog lights in the rear.
4x 1157 single amber (front turn/running)
2x 1156 single amber (rear turn) (use white if non-clear housing)
4x 1156 single white (rear backup/brake)
2x 1157 double white (rear running/fog)
2x 41mm festoon bulb (wagon)
2x BA9s bulb (sedans/coupes)
Running side markers? No problem: 2x T10 #168/194 wedge base
This assumes you're running brake lights in the upper location with a single filament connector. Connections are the same regardless, but if you're using the single pole connectors and buy the 1157's you'll have to mod them (solder or aluminum foil) to bridge the gap.
You will also need an electronic flasher module, as the lack of load on the turn signals will cause the OEM flasher to not flash. You'll need CF13GL-02 or equivalent european 3-pole flasher. Pinout looks like this:
I picked one up from my local Autozone for about $12. Just make sure the pinout is the same, the PN won't matter.
Interior:
2x 40mm Festoon bulbs (overhead/tailgate)
2x T10 #168/194 wedge base (main cluster illumination)
3x T5 #74 wedge base (center console)
?x T5 #74 wedge base (1x per 52mm gauge or console switch, lower center console light)
2x BA9s base (fasten seatbelt, center and lower center console)
?x B85d twist-lock (turn signals, warning lights) NEEDS VERIFICATION
If after installing them all, the light levels are acceptable and you don't feel the need to dim them, then you're done. If you'd like to be able to dim them at some point, pick up a PWM dimmer. I found one on eBay for ~$15 that looked like a near drop-in replacement for the stock dimmer.
You'll also want to make sure you don't buy exceptionally long bodied T5 #74 bulbs. They tend to either go too far into the receptacle and don't disperse light, or bottom out in a gauge before grounding to the body - and then not turning on. You might find that the upper center console LED isn't anywhere near bright enough even after taking these precautions, in which case an 'accent light' module might do the trick. Also do not buy 'super bright' or even white LED's for the turn signal indicators, they will be extraordinarily bright and blind you at night while making turns.
Your bulbs should look something like this:
1156/1157 tail/turn
reverse/running
volvogeek is offline   Reply With Quote
Old 08-22-2013, 06:10 PM   #3
BryantTF242
you, my friend, are awesome hahaha I have no more questions.
Old 08-22-2013, 06:33 PM   #4
BryantTF242
I cant seem to find a lot of superbrightleds.com, at least with the T5 #74's
what website do you recommend?
thanks.
Old 08-22-2013, 07:09 PM   #5
volvogeek
I used eBay for the most part, it was a little more work but I have a TON of LED's available for projects now.
Old 08-22-2013, 08:00 PM   #6
BryantTF242
any brand in particular you like?
Old 08-22-2013, 08:23 PM   #7
Old Iron
I Roll
Old Iron's Avatar
Make an extra set up for me too!
Turbobricked
Originally Posted by Anonymous View Post
No sarcastic replies from Redwood Chair necessary
Old 08-22-2013, 08:57 PM   #8
c
c's Avatar
Anyone know if these will work for the idiot lights?
http://www.ebay.com/itm/120959718169...84.m1423.l2649
c is offline   Reply With Quote
Old 08-22-2013, 09:12 PM   #9
centason
Knipex=welfare queen
centason's Avatar
I used superbright leds on my Volvo, and VLEDs on my Lincoln. Both companies have great customer service, and their products last. I have 4 years total on my on my current LED swap on my Lincoln with no issues.
Member: TBCCS
"Democracy is a pathetic belief in the collective wisdom of individual ignorance.” -H.L. Mencken
Old 08-22-2013, 09:23 PM   #10
c
c's Avatar
thanks.
I've had good luck with these:
http://www.ebay.com/itm/400404658540...84.m1497.l2649
Shipping is slow - literally a slow boat from China. They are cheap, have had a few duds and few that burn out quickly but for price...
Old 08-22-2013, 10:10 PM   #11
BryantTF242
so i dont need to do anything right? like i just pull out the old bulb, put this in, and go? I realize that LED's only work one way in terms of power flow, but other than that, thats all right?
Old 08-22-2013, 10:12 PM   #12
centason
centason's Avatar
Except for the turn signals, yes you only need the LED. You may need resistors for the brake light. That will have to be confirmed.
Old 08-22-2013, 10:13 PM   #13
centason
centason's Avatar
Who wants to wait for a bathtub full of rowing immigrants to bring them to you?
Old 08-22-2013, 10:14 PM   #14
Jon P.
Jon P.'s Avatar
I have had good luck with these as well. Direct replacement with no modifications.
Jon P. is offline   Reply With Quote
Old 08-22-2013, 10:17 PM   #15
Simi
Upsetti Spaghetti
Simi's Avatar
Man volvogeek, where were you when I did this a year ago?
Notes for a 240
Only thing I have to add is that some of the #74 housings like the shifter and center console backlight, will short out if you put in the bulb as is, you will have to bend the wires on the bulb to be on a single side instead of both.
Other thing is that for my instrument cluster backlights, I hammered out the old bulb and soldered really bright #74s in there.
1989 240 Turbo
1988 745 Turbo - SOLD
1991 940SE - SOLD
1995 850 T5-R
1991 740 Turbo
1987 240
Leave Me Feedback
Simi is offline   Reply With Quote
Old 08-22-2013, 10:23 PM   #16
BryantTF242
anyone use these? it has the wire single sided, looks like it will work?
http://www.ledlight.com/t5-74-wedge-...led-light.aspx
also i cant find 40mm festoon lights, only 39mm, 41mm and 42mm lol would all of those work?
Old 08-22-2013, 10:51 PM   #17
c
c's Avatar
hmmm.... that explains why I keep on burning out the shifter light.
Notes for a 240
Old 08-22-2013, 10:52 PM   #18
c
c's Avatar
I think the 39mm will work - ive ordered them but haven't gotten them yet. We'll see and I will post the results.
Old 08-22-2013, 10:54 PM   #19
centason
centason's Avatar
VLED sales adjustable festoon ones that haven't failed yet on my cars. Bright as shizz too.
Old 08-23-2013, 04:39 AM   #20
+Kardboard+
Chinese guy/Swedish rides
+Kardboard+'s Avatar
Write-up is awesome. Thank you for that!
'88 245DL Uncle Sven|'95 945T Darth Haul|'82 242GLT B23E Lumpy the Angry Viking/sold|'77 244DL, red/sold.|'90 744T, gold/sold
mtd240: I suspect "the wives" have a super-secret forum to discuss whether or not they will let us buy Volvo parts.
DavidSamuels: Not a website, a panel discussion/reality show. Real Housewives of Gothenburg.
-Feedback-
+Kardboard+ is offline   Reply With Quote
Old 08-23-2013, 02:28 PM   #21
volvogeek
LOL writing this up - I did it back in Jan of 12.
Anything between like 35 and 45 will probably work, you'll just have to bend the tab inside a little more (or less) depending on the size.
Welcome!
Old 01-05-2014, 04:58 AM   #22
c
c's Avatar
39mm festoons work you just have to bend in the contacts a little. I went with 6 smd lights http://www.ebay.com/itm/300913748802...84.m1497.l2649 but wish I would have gone with the 16s http://www.ebay.com/itm/331054422095...84.m1423.l2649
Old 01-05-2014, 03:58 PM   #23
MikeSr.
What, me worry?
MikeSr.'s Avatar
Anything for 142? I literally cannot see my gauges at nite.
I coulda had a V8!
Old 11-26-2017, 10:25 PM   #24
schaff70
schaff70's Avatar
Need to bump this for some assistance.
I've ordered the LEDs I need for the instrument cluster, but for the life of me I can't get the old bulbs loose from the twist lock holder. After soaking one in hot water I was able to get it out, but the LED will not fit. Anyone able to throw some tips my way?
schaff70 is offline   Reply With Quote
Old 11-26-2017, 11:19 PM   #25
+Kardboard+
Soaking in hot water?! Pics? You're talking about the two main 194 bulbs for the cluster?
