not yet good enough
![]() Most recent picture:
![]() Current setup: Engine 99 T5 b5234t block with liners "shimmed" 98 T5 b5234t head lightly ported NA cams ME7 intake manifold with plenum shortened to clear PS pump, bung for IAC, brackets for 240 b230 throttle spool 960 3" throttle body modified S70 fuel rail 850 turbo 3 bar FPR ceramic coated ATP C30 cast exhaust manifold 38mm external wastegate dumping into exhaust Garrett GTX3067R with ceramic coated .82 A/R turbine housing CX racing SRT4 2.5" intercooler Gates Racing kevlar timing belt Volvo 260 Diesel passenger side engine mounts 960 e-fan full 3" TIG welded 304SS exhaust with a cat and 2 Vibrant mufflers 92+ 940 NA radiator Mann Provent oil separator Bosch FR7DPP+ spark plugs Engine Management MS3x w/ knock module, 4 bar MAP, dual VR conditioner added in Driveline Getrag 265 transmission One-off adapter plate Volvo 960 bellhousing e46 M3 UUC transmission mounts and enforcer cups Sachs 240mm full-faced clutch disc from BMW e34 M5 e36 M3 / e34 M5 guibo lengthened m47 front driveshaft j9fab 740 turbo driveshaft support bracket modified getrag 265 shifter bracket mounted with e46 m3 transmission mount shortened UUC dual sheer shift selector rod garagistic aluminum shift selector joint BMW e60 shifter Condor racing tall weighted shift knob Tilton 60-1100 hydraulic release bearing with custom lines Suspension Front GAZ Gold coilovers 336lb x 8" springs 6" helper springs Homerbuchka camber plates and spring hats control arms boxed with Yoshifab plates polyurethane control arm bushings Kaplhenke V2 QSRC spacers with adjustable Ackerman GT firewall braces cravingboost big strut brace iPd (Volvo-style) lower chassis braces STS machining 28mm drop swaybar Rear Shortened trailing arms (20mm shorter) Speedway 5" adjustable spring perches 200lb x 5" x 9.5" main springs Gaz adjustable shocks, 40mm shorter than factory spec factory rear swaybar Kaplhenke hybrid torque rods with Volvo bushings iPd adjustable panhard bar Genuine Volvo front trailing arm bushings SuperPro polyurethane larger trailing arm bushings Brakes 94 Ford Mustang Master Cylinder Front 2005 Cayenne V8 front calipers S60R 330mm rotors Homer's caliper adapters iPd braided stainless lines Bosch Quietcast pads Rear 2005 Cayenne V8 rear calipers Homer's caliper adapters iPd braided stainless lines + Homer's adapter banjo lines S60R 330mm rotors Bosch Quietcast pads Wheel/Tires Current: BBS RC305 17x9 et32 w/ motorsporttech adapters (38mm front, 32mm rear) 245/40R17 Pirelli P Zero Nero GT Alternatives: BBS RC304 17x8 et38 w/ motorsporttech adapters (38mm front, 32mm rear) 235/40R17 Falken RT615K OE BMW DS1 17x7.5 et40 wrapped in Michelin Pilot Sports w/ motorsporttech adapters (38mm front, 32mm rear) Interior Recaro LS-B from mkII VW reupholstered in black leather GT door cards flocked '87 dash Momo Mod 69 350mm suede steering wheel on Momo hub with 2.5” spacer Rattletrap (sound deadener) below 1/8" closed-cell foam (decoupler) below 1lb/sq ft mass-loaded vinyl (sound barrier) below carpet (comfy) Exterior 7" round H4 ecodes with relayed 12 gauge harness GT fogs with relayed 12 gauge harness and 100w bulbs ------------ Previous setup: Engine 95 b230ft - stock longblock resealed b21f intake manifold w/ added fuel injector bungs nathaninwa fuel rail 960 3" throttle body TD04HL-20T w/ 11 blade billet compressor wheel, T3 wastegate actuator, ported straight turbine housing with a 3" vband outlet 90+ exhaust manifold w/ ported outlet Grainger valve MBC @ 20 psi CX racing SRT4 2.5" intercooler NGK BPR6ES spark plugs RSI Stage II turbo cam w/ RSI adjustable cam gear (timed straight up) Gates Racing kevlar timing belt 91+ 240 power steering pump mounted on custom bracket 240 OE diesel engine mounts 960 e-fan full 3" 409SS exhaust with 1 dynomax ultra-flo muffler in the rear 92+ 940 NA radiator Mann Provent oil separator Yoshifab vented oil cap Engine Management LH2.4 954 ECU with TLAO 6800rpm chip EZK with Buchka wasted spark board and TLAO chip Mitsubishi J702T ignition amplifier Bosch Motorsport 2x2 coil 012 3" MAF Bosch 42lb injectors (S60R green giants) Driveline Getrag 265 transmission 240 flat flywheel w/ 60-2 pattern Sachs 240mm pressure plate from Saab 9000 aero Sachs 240mm full-faced clutch disc from BMW e34 M5 j9fab getrag adapter plate & centering ring e36 M3 / e34 M5 guibo m47 driveshaft (unmodified) m47 bellhousing & clutch fork w/ BMW TO bearing clutch cable j9fab 740 turbo driveshaft support bracket BMW e46 330xi shifter & knob Suspension Front DIY Short Strut Coilovers - 240 strut tubes sectioned 3" shorter A1 Racing coilover sleeves & adjusters Kaplhenke spring hats Eibach 450lb x 8" springs ~100lb x 4" tender springs Koni Race struts (p/n 8610-1437) scottyd camber plates control arms boxed with Yoshifab plates polyurethane control arm and swaybar endlink bushings Kaplhenke roll correction spacers GT firewall braces cravingboost big strut brace Yoshifab lower chassis braces Rear Shortened trailing arms (20mm shorter) DIY adjustable 2.5" spring perches (ebay accord coil-over kit with custom machined retainer) 250lb x 8" main springs ~100lb x 4" tender springs Koni Race shocks (p/n 30-5436) no rear swaybar iPd adjustable torque rods iPd adjustable panhard bar Genuine Volvo front trailing arm bushings SuperPro polyurethane larger trailing arm bushings Brakes 94 Ford Mustang Master Cylinder Front 2005 Cayenne V8 front calipers S60R 330mm rotors Homer's caliper adapters iPd braided stainless lines OE Pagid pads Rear 2005 Cayenne V8 rear calipers Homer's caliper adapters iPd braided stainless lines + Homer's adapter banjo lines S60R 330mm rotors Wearever Gold pads Wheel/Tires BBS RC304 17x8 et38 w/ motorsporttech adapters (38mm front, 32mm rear) 235/40R17 Falken RT615K OE BMW DS1 17x7.5 et40 wrapped in Michelin Pilot Sports Interior Recaro LS-B from mkII VW GT door cards flocked '87 dash Momo Mod 69 350mm suede steering wheel Rattletrap (sound deadener) below 1/8" closed-cell foam (decoupler) below 1lb/sq ft mass-loaded vinyl (sound barrier) below carpet (comfy) Exterior 7" round H4 ecodes with relayed 12 gauge harness GT fogs with relayed 12 gauge harness and 100w bulbs black GT grille & headlight buckets ------------ New car, new thread. This will be the continuation of my wagon project which you can see here --> http://forums.turbobricks.com/showthread.php?t=257147. Pretty much everything from that car will be swapped into this shell. The primary difference is that now I incorporate the goals of having a nice interior and body. My goal: The car needs to do everything as I personally expect it should to make for an enjoyable driving experience. If something stands out as being subpar, I will attempt to fix it to make it good. This is my all-inclusive, wholly subjective metric. -It needs enough power to get out of it's own way and justify the suspension. ~230-250rwhp should be plenty, but that yet remains to be seen. -It must handle well, but also be street-able enough for me to happily drive to work in the summer, around town casually, and on a long trip to iPd. -It has to look 'good', but in doing so also give minimal concessions to drivability (no scraping, no rubbing, etc). -The interior needs to be a nice place to be (quiet-ish, comfortable, and pleasing to look at). Anyways, this was Brian's (2fast242gt) old shell that was graciously donated to me. A huge thanks to him for this, and for saving me from wallowing in my rusty-shelled misery. Here is my starting point, after rolling off the trailer and a quick wash. ![]() With that, the work begins. Pulled the front apart to begin prepping the engine bay for paint. It was rattlecanned black, and was in really poor shape. ![]() ![]() Spent a good portion of the day removing the paint. Not fun. ![]() ![]() I pulled the dash the other night. I will be swapping in the dash from the 87 after I fix it up. ![]() And now it's time to replace the destroyed window scrapers. Thanks Ken for shipping so quickly. ![]() Last edited by The Full Banana; 12-30-2020 at 02:23 PM.. |
#2 | |
Home Schooled
![]() I'm excited to see Brian's 242 live on, but I reeeeally love your wagon.... That color/wheels/ overall fitment, it's just right.
Good luck with this beastie, ill keep an eye out for this
'81 242t, DD, project, epic funmobile. build thread; http://forums.turbobricks.com/showthread.php?t=251729 '92 244. 601 red, stock, awesome. http://forums.turbobricks.com/showthread.php?t=292524 '92 245. 601 red, b230ft/aw71, 16t. '89 780. Fine Corinthian leather. |
![]() This is gonna be good.
#4 |
Do you have a cobalt?
![]() Join Date: Nov 2005
![]() Yeah the rattle can job sucked. I just touched it up as I scratched it.
That car is a engine slut. Is this your basic goal? It was a fun setup. ![]()
1983 242dl *6.0 lq4 swaped* Build thread http://forums.turbobricks.com/showthread.php?t=282323 Last edited by 2fast242gt; 09-15-2013 at 01:52 AM.. |
#5 |
![]() Subscribed
'00 XC70 SE - Slow '11 XC90 V8 - Torque Monster ‘12 Mazda5 - Work Car ‘06 E350 Ambulance - Work Car |
#6 |
I Roll
![]() This will be a cool project! What's wrong with the wagon.
#7 |
Moar Volvos than Queen B
![]() I like the shave-ed-ness on the exterior.
Ben 12 WRX Hatchback 10 Subaru Outback 93 245 m47 |
#8 |
Abnormally Aspirated
![]() Great angle in the pics. Keep that hood up and fender off, haha.
Let me know when you need a hand with the engine and stuff! Also, what happened to 50 shades of grey as the thread title? |
#9 | |
not yet good enough
![]() Rust and just a generally haggard shell.
Anyways, cleaned up and painted the valve cover. This was in this car the last time it had a 8v redblock in it. Brian modified it to work with a 530 head years ago. ![]() I took Redwood Chair's advice and ordered SprayMax 2k primer and clear coat. I used the POR Prep & Ready to take care of some flash rust that showed up in the past couple days. I'll reapply it to prep before priming. ![]() I used the clear coat on the GT grille and headlight surrounds after repainting them black just now. That stuff is pretty great. Tomorrow I'll finish prepping the engine bay, and then lay down the SprayMax 2K epoxy primer. Last edited by The Full Banana; 09-20-2013 at 10:45 PM.. |
#10 |
![]() Sand off the Volvo letters. That'll make that valve cover bitchin'
#11 |
not yet good enough
![]() I'm thinking about it.
I like the letters sanded on the newer style valve covers with the larger lettering, but on these old covers with small lettering I think it might be best as-is. |
#12 |
I Roll
![]() Dang, whats the address, I am shipping you a valve cover for you do do for me! Look forward to more from this thread!
#13 |
![]() where did the car get flash rust? engine bay? i have some ooolldd pictures of this car and I when i was like 17, so I may photobomb this thread sometime. if you need help anytime or just want to hang out let me know! id love to help.
#14 | ||
not yet good enough
![]() Quote:
I've been ordering so much stuff for this lately. Lots of little stuff, but quite a steady stream. Excited to get everything in! Last edited by The Full Banana; 09-22-2013 at 11:38 AM.. |
#15 |
not yet good enough
![]() Car is now safely tucked away in the garage.
![]() Almost time to put that Spray Max epoxy primer to work. ![]() The pile of parts in queue is growing: ![]() Last edited by The Full Banana; 09-22-2013 at 12:02 AM.. |
#16 |
![]() Awsome! Did you score a new grill? Or did you paint my old one? Looks very nice I like the progress.
#17 |
#18 |
![]() Really nice job!
![]() The rust/crash fix on the driver side doesnt look so nice, planning on changing that while your at it? |
#19 | ||
not yet good enough
![]() Quote:
Thanks! I would like to change it, just trying to figure out the best way to go about it. Some day I will have to buy a welder and learn to use it. |
#20 | |
![]() Quote:
![]() But ofcourse you need a welding machine first ![]() Keep on going! |
#21 |
![]() If you get a new innerfender I'd be glad to repair that the right way for you. Its always bothered me, that repaor was done when I was 17 by a local guy I knew. It would be easy to make it look like nothing ever happend.
#22 |
![]() Diggin it!
Joe Bieda V.C.O.A. Midwest Chapter President. 1984 242 M46 GLT. -Couple of things done to it ![]() 1998 S70 Auto. -LONG history. 1983 242 M46 Check out http://JJFAB.net For your K24 CBV blanking plates and oil feed/return flanges!! |
#23 |
not yet good enough
![]() This stuff showed up:
![]() ![]() 50 sq ft of Fat Mat Rattle Trap & 100 sq ft of Mass Loaded Vinyl. Started on the passenger door. 25% minimum coverage is all I am shooting for with the Rattle Trap. ![]() |
#24 |
#25 |
not yet good enough
![]() More progress this weekend.
Measured and cut out the strut tower opening to make room for camber plate adjustment. Finally wrapped up the prep and sprayed the engine bay with Spray Max 2K epoxy primer. For an aerosol can, this stuff is pretty great. Then I pulled the dash out of the wagon. This is in way worse condition than I realized. Not sure what I'll end up doing with this. I'll be using some of the blue interior trim from the wagon for this car, so I tried out Duplicolor interior paint. Seems to be pretty good. Last edited by The Full Banana; 09-29-2013 at 10:44 PM.. |
