#26 |
In too deep
![]() Your progress is looking great. The braided k-jet fuel lines are high on my list of purchases to be made. It's nice seeing someone else interested in keeping the original fuel system alive.
#27 | |
I do my own stunts
![]() Quote:
Unfortunately the steel braided lines will have to wait. I have other non Volvo related projects that also tap into my resources. With warmer weather approaching I will be stretched to have this project road worthy in 7 weeks!
1983 242 Turbo w Tremec T5 160,000 km's B230FT LH2.4 2019 VW Golf R w 6 Speed w 8500 kms NEW DD @smoothdurban on IG |
#28 |
I do my own stunts
![]() I received the car back from the paint shop. . . . well at least most of it. The painter still owes me the rad support, bumpers, sunroof and front air dam plus he will need to perform some touch ups. I would say I am fairly pleased with his work. He wasn't the cheapest nor the most expensive but his work turned out decent. The attached photos make the color look grey but I the car is in fact silver.
![]() ![]() Tomorrow will be a busy day ![]() ![]() My plan is to have this think back together in 7 weeks. Keep in mind I do have a day job, a wife and an 8 month old! We shall see how it goes. wish me luck. |
#29 |
Chubfest 2009 Survivor
![]() Join Date: Nov 2002
![]() Looks good from here!
Hank Scorpio is from the Simpsons. You can call me Doug ;) Will trade guitars/guitar parts for go fast goodies or stuff I need. Just PM. www.kauerguitars.com the second best way to upset neighbors and alienate people. History: Car 1 (242) | Car 2 (t5r) | Car 3 (255) |
#30 |
I do my own stunts
#31 |
![]() Is a red pin stripe in the works?
#32 |
I do my own stunts
#33 |
I do my own stunts
![]() Its been a few days and I have had the time to begin to reassemble the engine bay. I had to repair a bunch of wires which had crumbling insulation but for the most part things have moved along fairly well.
I have attached a couple of photos from my project. ![]() ![]() I have found I needed a couple piece of side molding (Pass Door, Drivers Fender) as well as a couple of Rain gutter trim junctions. In addition I am not sure how the wires for the engine bay lamp (mounted to the hood) and the after market intercooler harness was routed through the fire wall. I have highligted what I know goes where which doesn't leave any open access ports that I am aware of. Perhaps one of you can chyme in? ![]() I should be on track to install the engine this weekend. |
#34 |
![]() "Intercooler harness" ?
#35 |
I do my own stunts
![]() Probably bad wording.
When the aftermarket intercooler was installed from volvo it came with a wiring harness which connected to the ignition coil to a relay which switches on a solenoid value which bleeds some pressure to the waste gate at a specific RPM. This "harness" needs to be routed through the firewall to pin fuse 12. I cant seem to remember how it was routed. The installation instructions are fairly vague. ![]() |
#36 |
I do my own stunts
![]() The project has progressed well the past few days. I was able to finish assembling the doors which included the; window regulator, latch, striker, door handles, key cylinder, weather strip seal, glass, window scrapers, mirrors, and black surrounding trim as well as the always fun task of aligning the latch and striker.
The interior trim panel will have to wait until I get a couple of 4" speakers. The window scrapers where a major pita to separate the rubber from the steel but after a light sanding and wash the came out looking really good. Installing the new window scrapers (courtesy of Mr. Redwood Chair) may have given me a little carpel tunnel but once they were in they looked great. here a photo of the drivers side door. ![]() I still need to sand and paint the "b" pillar as well as finish painting the mirrors I bought from PunKKnuckle24. This weekend the motor will be going back into the engine bay! ![]() In addition, the door and fender molding I was able to get for free ![]() |
#37 |
Jackstand lifestyle
![]() Incredible turn around time! The paint looks really nice!
#38 |
I do my own stunts
#39 |
I do my own stunts
![]() Well I finally got all the vacuum connects, wiring, and coolant and oil lines connected.
I had to repair a few broken wires, bypass a faulty boost overpressure switch (I may be looking for a new one) and find out the ins to the distributor have pulled out of the connector, to get this. Broke in the new cam and found out the reman power steering pump leaks. Last edited by smoothdurban; 08-05-2014 at 08:11 AM.. |
#40 |
I do my own stunts
![]() After 9 months of work my 242 is back on the road . . . . more or less.
Saturday was a final garage day for my car. Between Friday night and Saturday afternoon I was able to complete some finishing touches.
I still need to
Here she is at home ![]() and the engine bay ![]() ANd this is what I started with ![]() ![]() Not bad for nine months. She is fast but working with the spec clutch will take some getting used to as it grabs all or nothing. I may need to get some stiffer engine mounts. |
#41 |
![]() Great project and a very nice result!
#42 |
![]() Looks really good!
#43 |
![]() Awesome!
#44 |
![]() Congratulations! That'll make a fine summer DD in Ontario and will surely turn heads.
Where did you get the replacement floor pans by the way? I will be needing some of those!
1971 145 Express Rally Car Restoration Project |
#45 |
![]() Now come finish my car. Please.
My feedback: http://forums.turbobricks.com/showth...hlight=didenpx 1970 1800E (Project Roedluvan:http://forums.turbobricks.com/showth...highlight=1970) 1977 242DL "Senf" (Summer Cruiser) 2x1973 1800 ES (Project Snoevit; http://forums.turbobricks.com/showthread.php?t=363278 |
#46 | |
I do my own stunts
![]() Quote:
Summer DD with working AC I might add ;) hehe I wish I could but after this last build I don't think my wife will approve. |
#48 |
![]() Awesome. For some reason, the coffin hood has been growing on me lately.
2009 Toyota 4Runner SR5 4WD - Inefficient Daily 1991 BMW 318i E30 - Reborn & Re-shell Project 1983 Peugeot 505 STI - Weekend Cruiser 1992 Volvo 245 Euro spec'd |
#49 |
![]() Thanks for the lead on fixmyrust.com; that's a new one for me. The prices for the 240 repair panels are insanely cheap!
#50 |
I do my own stunts
![]() Just as an update
I have just driven over 5,000 km (3,000 miles) since putting this car back on the road and as expected I have had a couple of hiccups as well as some upgrades. Voltage Regulator My rebuilt alternator had the voltage regulator came loose causing me to lose electrical charging. I guess the guy who rebuilt my alternator didn't tighten the two screws that hold the regulator to the alternator and as one of them completed backed out. Fortunately the car has a voltage gauge and I was able to notice the problem before my battery was completely drained. Universal Joints I replaced all three U joints on the drive shaft as well as ensured the shaft was installed in the correct balanced and phased positon. The car drives smooth with no vibration at highway speeds. Alternator Pulley I noticed my voltage dropping again followed by a ridiculous metal on metal sound coming from the engine. It turns out my trusty alternator rebuilder did not install the woodroff key so the pulley spun loose on the shaft. I was able to install a key and I have not had any problems since. Gas Tank I replaced the original, internally rusted gas tank with a good used one and after a few hundred miles it began to leak :(. Needless to say I had to replace the tank with a new one I got from Cross Canada for about $200. Fortunately all of the clamps and hose were new so this didn't take a long time. Engine Mounts After a few weeks of use I notice the cheapo engine mounts I had just wouldn't cut it and I needed to replace my engine mounts with something a little more robust. I ended up going with the 240 volvo OEM diesel mounts for $50 from Tasca. Muffler & Tail Pipe The baffling inside my muffler had come loose and created an annoying ratting sound (Kind of like a vibrating heat shield). The tailpipe was fine but for $20 I wasn't going to try to wrestle it loose from the old rusted muffler so I bought a new one. I was able to get a muffler and Tailpipe from FCP for around $50! Suspension Bushings I replaced all the suspension bushings with polyurethane bushings from IPD. The original bushing were still in driveable condition but I figured after 30+ years it might be a good idea to replace them. This was a major PITA as some of the bolts were seized to the inner part of the bushing which resulted in me needing to burn out the old rubber and cut out the bolt. Has anyone noticed that if you buy the bushings individually from IPD they are cheaper then the whole kit? Radiator The day I was working on the bushings I noticed a little coolant on the splash guard so I traced where it could be coming from at sure enough it was leaking from the upper radiator port. I thought perhaps I didn't tighten the clamp so I tried to tighten it a little more and sure enough the plastic port broke. Fortunately I had a spare 2 core sitting around to keep me running while I keep my eyes open for an all metal 3 core. Grille Some one stole the grille off my 240 but I was able to get a replacement off of the form for under $50! Wiper Motor The wiper motor would at times, not shut off or return to proper home position. I had a good used one and since then have not had a problem. Upgraded Lighting I upgraded the lighting system to use the H4 type light bulbs for low beam lights. I also got some white H4 bulbs that really make early morning driving a little more visible. A huge improvement over the old style sealed beam lights. LED Dash Lights I changed the instrument panel and dash lights to LED lights and they have really brightened up some rather dull gauges. Things I am thinking of doing. . . . . . . B21FT Cold Air Intake I have been thinking of performing this upgrade but I can't seem to find 2.75" ID PVC piping anywhere. I have looked at possibly using silicone piping to do this but it comes out to around $30. Wheel Spacers I have noticed that the rear wheels sit a little to far in the to the well (for my liking) and I was thinking of getting some 1" spacers to push them out a bit. I am curious how this would look or if it would be at all doable without rolling the fenders. Any input would be appriciated. The above list of repair items should be an eye opener to anyone that wants to take a 30+ year old car and use it as a DD. I was prepared for additional repairs but I think a lot of people buy $1000 Brick and expect it to run forever without sinking a buck into it. These cars will run for a long time but the need to be maintained. Below is a current photo of the car ![]() |
