Old 12-12-2004, 05:04 PM   #1
JimG
Default Tightening M46 bellhousing top bolt
1986 740T M46, J-type o/d
I stumbled on to a way to install the top bellhousing bolt with a minimal amount of blood and profanity.
I had all the other bellhousing bolts installed (starter - 2, bottom pan - 2, others - 3). I had tried to install the **** thing from the top - forget it - too many wires and a/c tubing. I tried the "extension thru the shifter hole" approach solo - nobody to guide the socket - not gonna happen.
I was laying under the car on my creeper contemplating what I would like to do to some anonymous Swedish auto engineer - my feet sticking out under the front bumper. I found that I could get both arms around the bellhousing so I could get to the bolt with either hand. Em, grabbed a 19 mm 12pt offset box end wrench in the left hand and the bolt in the right. I could finger tighten the bolt with my right (new bolt). I could position the box end on the bolt with my left - using my right to keep the box on the bolt head. Surprise, surprise - I had over 90 degrees of free swing with the wrench to tighten the bolt. I found that I had pretty decent leverage to apply some good torque as well.
The bolt's in and tight (it's there for some reason).
hth,
JimG
JimG is offline   Reply With Quote
Old 12-12-2004, 05:07 PM   #2
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
you can also either:
1. Not put the top one back in
2. Get about a 2-3' long extension and a swivel, works fine too.
Old 12-12-2004, 05:07 PM   #3
Volvo Dan
Volvo Dan's Avatar
When all else fails... Hug the Volvo and all will be well again...
Dan Wildey
1991 940 Turbo Wagon 'Daily Driver'
1999 C70 Convertible, NGK Iradium's, IPd Sways, IPd SR5T Intake, EuroSport Exhaust
1996 855 (Wifey)
1988 744 Turbo... Soon to be done...
Rebuilt B230ft (.030 over), T3/T4, 3" Exhaust, B-G Springs, Bilsien Shocks/Struts, IPd Sways, IPD Chasis Brace, Custom strut brace, Bar & plate IC, MBC, Autometer Boost and A/F ratio gauges,K&N Cone filter w/ heat shield, Blaupunkt Head unit w/ JBL 12", 850 Front Seats
www.volvospeedshop.com
Volvo Dan is offline   Reply With Quote
Old 12-12-2004, 05:21 PM   #4
pwschuh
Rolling...
That bolt is the reason I own a 30" extension and a swivel joint...
Old 12-12-2004, 05:24 PM   #5
JimG
I have 2 extensions 18" and 30" - neither worked real well with a universal. My mechanical charma was really suckin' this weekend.
JimG
Old 12-12-2004, 05:57 PM   #6
Inc3pt
Inc3pt's Avatar
When I pulled my engine to swap, I made the mistake of not pulling the tranny with it. Needless to say, I chose option #1
Inc3pt is offline   Reply With Quote
Old 12-14-2004, 12:02 AM   #7
245gti
Adapting Stuff
245gti's Avatar
If the shifter is out and you have the right extension, you can do it without even getting dirty. Well...sort of anyways. Get a buddy to lay under the car and put the socket/extension on the bolt. You sit inside the car and stick the ratchet handle through the shifter hole and snap it into the extension. Voila....told you that you wouldn't get dirty
Your buddy under the car? Depends how clean your garage floor is, I suppose....
Dale
Old 12-14-2004, 12:26 AM   #8
740Weapon
Traitor
740Weapon's Avatar
a mechanic forgot some pin on a transmission belhousing once in my jeep and it cracked the bell housing all the way around. and the damn guy took zero responsibility for it too.
'90 744 16 Valve. 16.317@85.55. Sold.
'92 244. Sold. http://pbase.com/740weapon
Old 12-14-2004, 01:48 AM   #9
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
It's considered bad form, but from underneath the car by the driver's side, use a 19mm socket on a swivel, connected to a 4" extension, connected to a swivel, connected to a 6" extension. I wouldn't under any circumstance use and impact gun on that combo but with a ratchet it will work.
-Kenny
Old 12-14-2004, 01:52 AM   #10
Dan
TQ>HP
Dan's Avatar
Basically what i use, except I use wobble extensions and impact swivels (not as floppy). Never a problem to get to those bolts on top. The right tools make working on the car so much easier.
Old 12-14-2004, 01:55 AM   #11
swedefiend
Yeah, this bolt is a non-issue with a 1/2 inch breaker bar and a 3 foot long 1/2 in extension. I also have a 1/2 inch 19 mm swivel bought just for this purpose.
edit:// In all fairness though, ^^^ is a $300 setup. You need that kinda thing though when you do it day in and out.
Old 12-14-2004, 09:44 AM   #12
11110000
11110000's Avatar
I just jack up the tranny to tilt the engine forward a bit and go at it from the top - never had much of a problem with that.
11110000 is offline   Reply With Quote
Old 12-14-2004, 10:53 AM   #13
740Weapon
Traitor
740Weapon's Avatar
i think this one sounds the best
