Old 08-16-2014, 10:59 PM   #1
Cyracus
Default odometer not working...'90 240
bypassed the temp comp board, thought I put everything back the same it came out, but the odometer isn't working, was working great before, and everything else is fully functional still. Double checked that connectors were fully seated, and never removed the speedometer housing from the board so it shouldn't be the gears. Anybody got an idea why my odometer suddenly isn't working?
Addendum: went for a drive again, at one stop noticed my speedometer rose to about 90 then dropped off the right side, then when I was pulling into my driveway my odometer suddenly started working again. Is there some way the transmitter may have got damaged?
I ask stupid questions because I want to avoid having to fix the things I just fixed
Cyracus is offline   Reply With Quote
Old 08-17-2014, 10:09 AM   #2
dbarton
Dejected by Volvo
dbarton's Avatar
In my odometer repair page I outline a small number of the emails I've received from people who have experienced dead odometers after doing work on them. There are many who have then seen the odo mysteriously come back to life after some driving. While the cause is one of those mysteries that may never be explained, the common thread may be disconnecting the power plug on the back of the speedo. Some think there may be some sort of reset breaker that takes some time to reset in some cars.
Dave B
'84 242ti, owned since 2003. Always garaged since brand new. Old-school rounds because. B21FT, SDS EFI/IGN, TD04HL-15G, T5Z trans with 0.73 OD, 3.91 diff with unmodified G80.
Volvo Seeks Divorce from Volvo Enthusiast Community: www.prancingmoose.com/#novolvo
Alternator Idler Pulley Project: https://forums.turbobricks.com/showthread.php?t=350085
Old 08-17-2014, 03:10 PM   #3
Cyracus
ok, any idea about the speedometer acting funny? It topped out at a dead stop, returned to normal as I drove, then noticed it bouncing around a bit while driving, could it be related to the reset breaker or should I be looking somewhere else?
Old 08-17-2014, 03:27 PM   #4
dbarton
Dejected by Volvo
dbarton's Avatar
It's why I said it's a mystery.
Old 08-17-2014, 03:53 PM   #5
eparayno
eparayno's Avatar
I read that on your page Dave. I have a 92 so it has the electric cluster. I replaced the gear for the odometer and it would work for a few miles then stop. I re-installed and re-checked everything three times before calling it quits. It started working after an hour long drive and has been working perfectly since then.
eparayno is offline   Reply With Quote
Old 08-18-2014, 01:18 PM   #6
Cyracus
well, tried the poke and prod method one person suggested on your site, didn't get me anywhere...oh well, here's to hoping it starts up again soon
Old 08-18-2014, 01:39 PM   #7
F*ck 12
One more problem and crush it!
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 08-18-2014, 01:41 PM   #8
n. rippe
n. rippe's Avatar
Welcome to the club! My odometer doesn't like cold weather.
1991 744 Turbo
2008 C70 T5
n. rippe is offline   Reply With Quote
Old 08-18-2014, 01:54 PM   #9
cleanflametrap
cleanflametrap's Avatar
What does it mean when you say "dropped off the right side?"
Are the temp and fuel gauges steady?
Are the warning lights coming on as they should in lamp test mode?
All these items get their power through the L-shaped card edge connector you probably plug in last. It could have loose contacts. But, on to the odometer...
The original gear can fall apart in the presence of an East wind this late in its life. But a broken tooth (it takes two missing to stop it entirely) can jam its progress. If any stress was put on the speedo circuit board, you could have intermittent odo where the motor leads join the board - circular cracks.
Mysteries abound in this world, but this is truly fathomable. The 92 gets its ground in two places: one for the divide-by-4 prescaler is in the transmitter loom -- the black wire on that L-shaped plug. Rest of the gauge is through the cluster board. Did you do the temp faker bypass without removing the speedometer gauge? If not, check the pins and sockets where the gauge mates with the cluster board. Easy to get them misaligned.
-Art
Old 11-23-2014, 10:17 PM   #10
sailorbenjamin
That circular crack is the best tip I've gotten all week. Thanks! Really hard to see. Use magnification.
sailorbenjamin is offline   Reply With Quote
