Old 02-16-2015, 03:42 AM   #1
Xeroni
MPG?
Xeroni's Avatar
Default The Other Battlewagon, Part 2?
Current 4/24/17 details:
1985 245
'76 B21F+T
460cc Racetronix injectors
RSI Stage 1 cam
'76 M46 w/ Spec stage 2 clutch/pp
90+ with a 19t
3in downpipe > resonator
MSnS 2.2
Geminis w/ 225/50/16 Bridgestone Potenza RE-71Rs
Innovate wideband
Ben's coilovers and top plates w/ koni red in front
Cut IPD springs w/ S10 billies in rear
poly bushings all around
23/19 sway bars
GT and strut tower braces
SunPRO boost gauge
Kenwood KDC-BT558U headunit with fancy features
Front late model flush glass
Rear tailgate from a late model 240
A few older pictures:
I bought this 245 from Mike (thebornotaku) in May of 2014 after my 760 caught on fire and I gave up trying to get the 740 to keep all it's fluids in and running.
It didn't run very well or get over 15 mph without lots of bad noises thanks to a dead mopar ignition box. I drove it a couple miles at running speed until I was close enough to my house to have it towed home for free, thanks AAA!
Got it home at around ten.
Those stickers had to go, sorry Mike.
For an awesome price of $1240 it came with 90% of the parts to turbo it and a bunch of spares. First thing I did was wire up ezk to it and after going to the yard to get a working ezk box this happened:
https://www.youtube.com/watch?v=iaame9fS9cw
Listen to the M cam smooth as butter idle.
Got it smogged after that
and then immediately swapped in the A cam that came with it.
Drove it for few weeks like that, swapped out the slipping and trashed AW70 for the AW71 that also came with the car. No pictures because the 70 had been leaking fluid under the car for years and we were a horrifying mess during and after the swap.
Turning over 310k:
Got bored of how freaking slow it was and decided to +t it over the weekend before Western Meet 5.0:
https://www.youtube.com/watch?v=kAlCouEIr-4
After WM I swapped the maf to the correct side and put on a garret 740 bypass valve:
Idle controller started dying around then. Can also see the old 2.5 scrap exhaust side exit:
https://www.youtube.com/watch?v=epXuTBmArs8
In November 2014 a truck pulled out in front of me and promptly went 20 mph in a 35. I slammed on the brakes but still tapped him. Insurance straight out told me since I rear ended him and there was no witnesses that it would be declared as my fault if I filed a claim. Luckily(?) the other driver didn't care about his truck so I got off with a smushed front end.
https://www.youtube.com/watch?v=rnU4Sw5q-bk
The next day I went to the yard and pulled the only decent looking right fender and the headlight/radiator support frame off a blue 242. Someone had already taken the driver side so I was still stuck with the dented one there. Luckily the car had also came with the original quad squares with H4 low/highs on the outside. Picked up the 81 DL surrounds from Mike a few days later too.
During a rain storm I managed to lose the bumper lip. And I cut down the broken flathood grill to fit the quad squares.
Sometime after that I got tired of 2.2 so I swapped the megasquirt/harness/wideband from the 740 into the 240 in a couple hours. After that there wasn't enough fast for me so I also took the ebay turbo from the 760/740, 90+ manifold, and 3in turbo back exhaust.
Broke the brake booster check valve, then found the top and fixed it with gorilla glue.
Broke a cheap ebay vband clamp.
Max'd out the 850 turbo injectors I was running, swapped to some 42 lb/hr ones. (Also from the old 760)
Turbo seals started leaking something fierce. I rebuilt it with an ebay kit but it didn't help much.
https://www.youtube.com/watch?v=n4d144Vvlg8
To make sure I didn't lose it on the next guy who cut me off I picked up a dash cam. (Warning: BORING)
https://www.youtube.com/watch?v=f5G7MHYGbhU
At the end of Jan 2015 I bought a driver fender and lip from Gary (gstellr).
Then this weekend me and a few friends sanded down any rust and painted the car white using some cheap home depot cans. Anything better than the four colors the car was at that point.
Bye bye rust.
Getting there at the end of the first night.
How it looked today (2/15/15) after a couple hours of drying:
There's a few spots that need to be cleaned up but so far I'm impressed by how it came out, especially since it was a couple guys drinking, bbq, and painting with spray cans.
In the future I hope to get a new turbo and find some sticky tires for the Geminis (also came with the car) for Davis in a couple months. Oh yeah and get some tintz.
Any questions?
1990 765T; sent off
1989 744T; parted out
1985 245; The Battlewagon;+t, B21/AW71L, back at it again with the megasquirt
1994 940; it's 16v
2019 Fiesta ST; DD
Xeroni is offline   Reply With Quote
Old 02-16-2015, 03:48 AM   #2
thebornotaku
( ͡° ͜ʖ ͡°)
thebornotaku's Avatar
Unless you changed the front bar, I was running a 23mm front bar from a turbo car.
Check out A Shade Darker for the tint, they've quoted me totally reasonable prices for all the windows that would keep me CA legal. I think it was like 250ish.
also get the damn rear shocks changed out man, I know you haven't yet
2009 Volkswagen Rabbit 2.5 "Snowbunny"
thebornotaku is offline   Reply With Quote
Old 02-16-2015, 03:59 AM   #3
Xeroni
MPG?
Xeroni's Avatar
23mm, 25mm, what's 2 mm?
I'm hoping the shop across from Mark's will be doing tinting again if he is doing the Davis pre-party again. Got the 760 done there for $160.
Shh, I'm putting in all the new poly stuff this week, including the shocks.
Old 02-16-2015, 04:00 AM   #4
thebornotaku
( ͡° ͜ʖ ͡°)
2mm is a pretty significant difference in swaybars, It was notable when I went from 19->21mm (GT bar) and then from 21->23.
Old 02-16-2015, 04:06 AM   #5
Xeroni
MPG?
Xeroni's Avatar
I'm just glad it's not 25/25. I had that in the 760 and it would just lift the inside tire and peel out for days.
Not that that wasn't fun.
Old 02-16-2015, 04:16 AM   #6
thebornotaku
( ͡° ͜ʖ ͡°)
well wagons came with larger rear sway bars as factory anyway I think. AFAIK sedans were like 17mm rear sway. Just putting the Bilsteins in there made it way nicer out back, and sway bars are a band-aid for not enough spring anyway.
Old 02-21-2015, 11:34 PM   #7
Xeroni
MPG?
Xeroni's Avatar
So TB it hurts.
Old 02-22-2015, 12:01 AM   #8
^ Nice JURBO badge.
Nope the Turbo wagons had smaller stock sized rear sways from the factory.
Old 02-22-2015, 12:05 AM   #9
thebornotaku
( ͡° ͜ʖ ͡°)
^ Nice JURBO badge.
Good thing this wagon was factory n/a then, right?
Old 02-22-2015, 12:10 AM   #10
Xeroni
MPG?
Xeroni's Avatar
So weird thing. Before I did this the wipers wouldn't work in intermediate and the blinkers would all blink like a bulb was out. Afterwards the intermediate setting is back and none of the blinkers work but the hazards do.
Old 02-22-2015, 12:14 AM   #11
Any questions?
When are you going to put the side trim back on?
Old 02-22-2015, 12:16 AM   #12
Xeroni
MPG?
Xeroni's Avatar
Mike had some Pepboys tape on trim on there before. Don't know if I want to go that route or repaint some of the stock chrome trim black.
Old 02-22-2015, 12:19 AM   #13
Find some nice DL trim in Windsor?
Old 02-22-2015, 12:32 AM   #14
Xeroni
MPG?
Xeroni's Avatar
Front fender trim the same 86+? I haven't seen an -85 at Windsor in a long time.
Old 02-22-2015, 12:34 AM   #15
thebornotaku
( ͡° ͜ʖ ͡°)
lolwut
**** it, just hit the hazards every time you need to turn and let people guess which way. bonus points if you wire in a wig-wag circuit
Old 02-22-2015, 12:35 AM   #16
122power
dude
122power's Avatar
The white looks pretty good.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 02-22-2015, 12:44 AM   #17
Xeroni
MPG?
Xeroni's Avatar
lolwut
I never use them because they blink so fast you can't even tell they're on. I'm thinking about getting one of those $10 aftermarket electronic blinker relays and see if that helps.
It does! Needs tint and black trim though.
Old 02-22-2015, 01:09 AM   #18
79-83 DL
AKA the good stuff.
Old 02-22-2015, 10:55 PM   #19
Xeroni
MPG?
Xeroni's Avatar
I hope one of those shows up at Windsor soon. What would I do without row52.
On another note, the blinkers work again and I did absolutely nothing, so that's a win for me.
Old 02-23-2015, 11:23 PM   #20
Xeroni
MPG?
Xeroni's Avatar
Pulled the last of the stuff I wanted off the 740 before PnP grabs it tomorrow.
Installed the transmission cooler off it, had to do some interesting bending of the cooler lines to make it fit. Need to drill through the radiator support to mount the cooler down.
Installed the sunpro boost gauge that I kept from the 760. Matches the other gauges and doesn't rest +-3 psi around zero like the harbor freight one did.
Old 02-26-2015, 04:52 AM   #21
Xeroni
MPG?
Xeroni's Avatar
740 oil cooler re-locator arm is installed, fits even with the 3in downpipe and it looks like I'll have enough room to remove the filter even. Getting the hard lines around the alternator was not fun. Cooler is zipped tied behind the vents in the belly pan. Lines weren't long enough after bending to reach up where I wanted it to be up in the stock n/a airbox spot. I'll either have to get new hoses and adapters for the sandwich plate and cooler or run it to a new cooler if the cooler adapters (BSP threads if I remember right) are too expensive.
Old 03-02-2015, 02:15 AM   #22
Xeroni
MPG?
Xeroni's Avatar
I still haven't put on the new control arms that have poly pressed in.
Spent a couple hours today finally finishing off the exhaust. 3in all the way, cat, and a straight through resonator at the back.
Old 03-02-2015, 03:33 AM   #23
pat244ti
pat244ti's Avatar
Any Parker Store should be able to get BSP adapters. I got some to -8 AN for $15 or so a pop a lot cheaper than Pegasus Racing
- Patrick
83 244ti - rally
73 1800es - resto mod cruiser
83 244ti - road race
79 262c - road race in the works
08 c30 T5 - daily recce car - M66, Lifted 1.5'', 215/65/16 Falken All Terrains on Method MR502's, iPD skid plate
97 Dodge Dakota 5.2 4x4
70 Ford F100 2WD 351M/C6
Old 03-02-2015, 03:38 AM   #24
Xeroni
MPG?
Xeroni's Avatar
Sweet, I was trying to convince myself to spend the money on the ones from Pegasus. Thanks Pat.
Old 03-09-2015, 09:50 PM   #25
Xeroni
MPG?
Xeroni's Avatar
Had a problem with the map signal being too noisy. Fixed that by teeing into the vacuum line to the fpr. Had another problem with misfires about 10 psi. Fixed that by gapping the plugs down to the correct gap.
She feels nice now, finally got to do a wot pull.
Feels pretty good at 12 psi.
Oh yeah, we also did a boost test and the drunk flux core welded bov pipe was leaking pretty nicely. I swapped over to the 740 head mounted cbv vented to atmosphere and some combination of pipes I had laying around.
